For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. May 2, 2021 at 4:15 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    You never answered, is it AWD?
  2. May 2, 2021 at 4:15 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    165
    907rx7 and BananaMan[QUOTED] like this.
  3. May 2, 2021 at 4:17 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    The Talon? Nah, it's FWD. Subaru, yup AWD, but automatic. :(
  4. May 2, 2021 at 4:17 PM
    Sig45
    Mark
    Maine
    I see everyone is behaving this fine evening. My influence is strong & far reaching. :thumbsup:
    :rofl:
    :fistbump:
    BananaMan likes this.
  5. May 2, 2021 at 4:20 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I'm a couple beers away from that if I so choose :rofl:
    BananaMan and Sig45[QUOTED] like this.
  6. May 2, 2021 at 4:31 PM
    VooDooBob
    VooDooBob Sitting on pins and needles.
    Robert
    21 VDB Off-Road
    Like Elsa, Let it Go.
  7. May 2, 2021 at 4:34 PM
    Tacoma Mike
    Tacoma Mike [OP] 48 Year Chrysler/Toyota/ASE/ Master Tech.RETIRED
    Southern Maine
    Two things.
    One
    disconnect the vac advance.
    Do your run up rev test.
    If it seems ok, bring the timing light out and for a test set the timing at 36° at like 2500 or 3 grand.
    Keep the vac disconnected.
    two
    if the dist thing don’t work, take a piece of duct tape and cover the carb intake like 1/3.
    If it seems to help you know what you need.
    But the disconnecting the vac to start is the easiest
    double check the cap and rotor fit ..... no cracks etc
    On Edit
    did you do a points elimination ?
    Plain Jane Taco likes this.
  8. May 2, 2021 at 4:34 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    That looks pretty damn good in the picture.
    Delta09[QUOTED] likes this.
  9. May 2, 2021 at 4:35 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I feel like you're the only one cheering me on while everybody else is like...
  10. May 2, 2021 at 4:37 PM
    Plain Jane Taco
    USA
    Not sure how Chrysler applied pearls back then, but Toyota pearls like 089 Blizzard Pearl are a white primer/base mica/clear coat....3 stage wet on wet on wet application
  11. May 2, 2021 at 4:39 PM
    Plain Jane Taco
    USA
    Cold starts are usually the loudest
  12. May 2, 2021 at 4:40 PM
    Plain Jane Taco
    USA
    Siped section is the most critical part. Without out that.....meh
    MQQSE[QUOTED] likes this.
  13. May 2, 2021 at 4:42 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    This car was originally just plain white, but at some point was painted. It's got some spiderweb cracking here and there and is chipped, but atleast I can make it shiny! Thought about painting it a cement color, but at this point I'm way too deep in it financially I'd never get out of it then...
  14. May 2, 2021 at 4:43 PM
    Plain Jane Taco
    USA
    I'd throw some M1 HM in it. That stuff is thick and juicy
  15. May 2, 2021 at 4:44 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yes, yes :D
  16. May 2, 2021 at 4:45 PM
    Plain Jane Taco
    USA
    Love cement colors. But you're right. I'd focus on the mechanics and just do what you can with the aesthetics. She's a driver
  17. May 2, 2021 at 4:49 PM
    Plain Jane Taco
    USA
    I only mentione M1 because their 5/30 formula is damn near a light 40. Scores an 11.9 at 100°C. But Valoline is just fine. I have synthetic Maxlife in the daughter's Yaris right now.
    Personally, if not the M1 I would consider regular Maxlife because you can get that in a 10/40. It's a blend....but is robust across the board.
    Both might help the leaks
  18. May 2, 2021 at 4:52 PM
    Tacoma Mike
    Southern Maine
    Axle grease ?
    :notsure:
    :anonymous:
  19. May 2, 2021 at 4:54 PM
    Plain Jane Taco
    USA
    Seems legit :notsure:
  20. May 2, 2021 at 5:11 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Supertech 75w90...
