For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. Aug 23, 2021 at 5:16 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
  2. Aug 23, 2021 at 5:21 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Brother....if you were closer....
    Sig45[QUOTED] likes this.
  3. Aug 23, 2021 at 5:22 PM
    Plain Jane Taco
    USA
    Hello Johnny
    Taco critter likes this.
  4. Aug 23, 2021 at 5:24 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Love my Cooper Discoverer AT3 LT's. Highly recommend.
  5. Aug 23, 2021 at 5:27 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I was actually looking at a very similar tire; the Cooper Discoverer AT3 4S in a 265/70/16. Little spendy, but on something like that I don't want to cheap out too bad.
  6. Aug 23, 2021 at 5:27 PM
    Sig45
    Mark
    Maine
    I'm really in no rush. Haven't touched the fluid and I'm approaching 150K miles. Figured I ought to do a series of drain & fills. That whole temp mode process freaks me out.
    Plain Jane Taco likes this.
  7. Aug 23, 2021 at 5:28 PM
    Sig45
    Mark
    Maine
    Bump up to 265/75/16!
  8. Aug 23, 2021 at 5:29 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Uhm, then it wouldn't qualify here as stock :D
  9. Aug 23, 2021 at 5:29 PM
    Sig45
    Mark
    Maine
    Those are great too.
  10. Aug 23, 2021 at 5:30 PM
    Sig45
    Mark
    Maine
    :gossip:
    I run those and control the algorithm. You're good.
  11. Aug 23, 2021 at 5:33 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    No lift? Hmmmm I might try that...
  12. Aug 23, 2021 at 5:34 PM
    Sig45
    Mark
    Maine
    I average 15K miles per year. I get 3 years/45K miles out of a set. Even with the 60K tread like guarantee, I still swap out every 3 years. Don't want 1/4" of tread going into hunting season & winter. I just ordered 4 for a change in Sept.
    907rx7, Plain Jane Taco and Delta09 like this.
  13. Aug 23, 2021 at 5:34 PM
    Sig45
    Mark
    Maine
    No lift, they easily fit.
  14. Aug 23, 2021 at 5:38 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Apparently he's getting many hands!
  15. Aug 23, 2021 at 5:39 PM
    Sig45
    Mark
    Maine
    I need to grow a set of balls to do it myself.
  16. Aug 23, 2021 at 5:46 PM
    Plain Jane Taco
    USA
    Study the how-to thread and watch the linked video on the temp check procedure. Practice it a couple of times before doing the actual DAF. Put about a 1/2 quart more in than came out and adjust the level during the check.
    WS fluid is made by ExxonMobil and is a good ATF. But it's expensive and not synthetic. If you can get a really good deal on it then use it. But don't hesitate to use Valvoline Maxlife ATF. You can get a 4 quart jug at Wallyworld for less than $20. Excellent fully synthetic fluid and 100% compatible with WS.
    https://www.tacomaworld.com/threads/how-to-drain-refill-automatic-transmission.63851/
  17. Aug 23, 2021 at 5:49 PM
    Plain Jane Taco
    USA
    The fox watches over the henhouse
  18. Aug 23, 2021 at 5:50 PM
    Tacoma Mike
    Tacoma Mike [OP] 48 Year Chrysler/Toyota/ASE/ Master Tech.RETIRED
    Southern Maine
    Just do a overflow flush like I do.
  19. Aug 23, 2021 at 5:51 PM
    Sig45
    Mark
    Maine
    :notsure:
    15
    BananaMan and Plain Jane Taco like this.
  20. Aug 23, 2021 at 5:51 PM
    Plain Jane Taco
    USA
    You'll have no issues with a 265/75/16.
    Delta09[QUOTED] and Sig45 like this.
