For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. Aug 26, 2021 at 9:01 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Not that it matters any to you with a turd gen :rolleyes:
    Edit: dang autocorrect. I totally meant "third" :D
  2. Aug 26, 2021 at 10:56 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Nice
    BananaMan[QUOTED] likes this.
  3. Aug 26, 2021 at 10:56 AM
    Plain Jane Taco
    USA
    :fistbump:
    Taco critter likes this.
  4. Aug 26, 2021 at 12:06 PM
    Tacoma Mike
    Tacoma Mike [OP] 48 Year Chrysler/Toyota/ASE/ Master Tech.RETIRED
    Southern Maine
    Locked, loaded, and ready for a winter action.
    5 snowblowers. Check. (Two for sale)
    2 chain saws. Check.
    2 generators. Check.
    2 trimmers. Check.
    Things are coming together…
    BTW.
    92° and a heat index of 100°
    She’s a bit dangerous up here
    Plain Jane Taco, Sig45 and 907rx7 like this.
  5. Aug 26, 2021 at 1:54 PM
    Plain Jane Taco
    USA
    I'm getting ready to mow in that Buttercup. :D
    Sig45 likes this.
  6. Aug 26, 2021 at 2:00 PM
    Delta09
    Delta09 OSHA Violator
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Well looks like I've been a plumber today. :angrygirl:
    Someone shoved paper towels down the sink and it got stuck in the "P" trap. That was a nasty mess to tear apart. Then they busted the valves on another sink...
    BananaMan and Plain Jane Taco like this.
  7. Aug 26, 2021 at 2:02 PM
    Tacoma Mike
    Southern Maine
    It’s easy in a air conditioned tractor
  8. Aug 26, 2021 at 2:02 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    "Someone" needs a punch to the throat.
    Delta09[QUOTED] likes this.
  9. Aug 26, 2021 at 2:03 PM
    Tacoma Mike
    Southern Maine
    Plus we are not use to that type of climate…….
  10. Aug 26, 2021 at 4:11 PM
    Plain Jane Taco
    USA
    I don't own one of those. :p
  11. Aug 26, 2021 at 4:12 PM
    Plain Jane Taco
    USA
    Oh I know. Just chappin' ya a little.
    :fistbump:
  12. Aug 26, 2021 at 4:21 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Pretty sure the heats chappin' him already :rofl:
  13. Aug 26, 2021 at 4:32 PM
    Tacoma Mike
    Southern Maine
    Hey I use axle grease. Nothing chafes through that.
  14. Aug 26, 2021 at 4:34 PM
    BananaMan
    Let's not talk about what's chapping after the weather today... double wall carhart pants today and it was a busy day. Hydraulic pump on one of our German machines died. Pulled it off the motor and the lovejoy came out in six pieces. It's a metric european lovejoy that we of course didn't have any spares of. Boss jigsawed it back together with rtv well enough for us to put it on the new pump. Which after spilling two gallons of hydraulic fluid, spending an hour changing fittings between the old and new pumps, then getting it all back together... the new pump didn't work. At all. Not even the mechanical bypass that manually moves the shuttle valve over to run the chains. Nada. But the gear pump that piggy backs off the shaft did work, which means the lovejoy somehow worked. Swapped valve bodies between the old and new pump. Still nothing. Now I have to go in at 4:45 tomorrow morning to try checking and resetting the pilot pressure. If that doesn't fix it, I have to put the old pump back in that still partially works. And swap valve bodies back. Woooo more hydraulic mess!
  15. Aug 26, 2021 at 4:35 PM
    Tacoma Mike
    Southern Maine
    I just came in from dropping a tree with the new next door neighbor.
    His words were “Don’t you ever slow down”? Yea we were drenched…
  16. Aug 26, 2021 at 4:36 PM
    Plain Jane Taco
    USA
    :thumbsup:
  17. Aug 26, 2021 at 4:37 PM
    Plain Jane Taco
    USA
    o_O
    High temp bearing grease? :D
  18. Aug 26, 2021 at 4:39 PM
    Plain Jane Taco
    USA
    @Sig45
    Mark....you got any advice on this one?
    :D
  19. Aug 26, 2021 at 4:41 PM
    BananaMan
    I've got some advice for myself... "SUCK IT UP BUTTERCUP"
  20. Aug 26, 2021 at 4:47 PM
    Tacoma Mike
    Southern Maine
    Hey, I’m losing power but my rpm’s are still red line. :benchpress:
