For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. Mar 20, 2022 at 4:32 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    I see what you did there. :rimshot:
  2. Mar 20, 2022 at 4:33 AM
    Plain Jane Taco
    USA
    Kind of like cylinder #3 on an air cooled VDub engine
    Taco critter and Sig45 like this.
  3. Mar 20, 2022 at 4:35 AM
    Plain Jane Taco
    USA
    :quickdraw:
    That said...I'm going out on a limb and saying he uses 15w40, 20w50 or maybe a straight 40.
    Sig45[QUOTED] likes this.
  4. Mar 20, 2022 at 4:35 AM
    Plain Jane Taco
    USA
    :rofl:
    Sig45 likes this.
  5. Mar 20, 2022 at 5:09 AM
    kwanjangnihm
    kwanjangnihm Timeout Terminator
    Jeff
    Central Florida
    13 DCLB TRD SP PR OTT
    "If it ain't a longbed it ain't shit! :)
    Yep 20w50 :bowdown: break-in oil
    Phillips 66 Type M Aviation Oil is an ashless, nondispersant, multigrade engine oil recommended for use in aircraft piston engines where the operator prefers a mineral oil-based engine oil that does not contain dispersant additives. It provides easier starting and quicker oil circulation at low temperatures compared with single-grade mineral oils, while maintaining high film strength at high temperatures and under high loads for protection against wear and piston scuffing. Type M Aviation Oil is available in one viscosity grade: SAE 20W-50. It typically is used as break-in oil for newly overhauled engines where all-mineral type oils are recommended. The multigrade formulation helps reduce cylinder glazing tendency during break-in. Break-in normally is accomplished in less than 25 hours of engine operation.
  6. Mar 20, 2022 at 6:01 AM
    Tacoma Mike
    Tacoma Mike [OP] 48 Year Chrysler/Toyota/ASE/ Master Tech.RETIRED
    Southern Maine
    Oil is Oil
    Your limb broke..
  7. Mar 20, 2022 at 6:10 AM
    Tacoma Mike
    Southern Maine
  8. Mar 20, 2022 at 6:19 AM
    Plain Jane Taco
    USA
    Good morning TC
    Taco critter likes this.
  9. Mar 20, 2022 at 6:20 AM
    Plain Jane Taco
    USA
    :thumbsup:
  10. Mar 20, 2022 at 6:22 AM
    Plain Jane Taco
    USA
    Speaking of oil. This is my only wrenchin' today. Oil change on my buddy's '17 Sequoia. She's a hungry bitch at 8 quarts.
  11. Mar 20, 2022 at 6:23 AM
    Plain Jane Taco
    USA
    You too Johnny
  12. Mar 20, 2022 at 7:54 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Mornin' Bill :hattip:
    Got some upcoming oil changes myself!
  13. Mar 20, 2022 at 11:47 AM
    Plain Jane Taco
    USA
    Buddy....it seems all I have done every weekend is wrench on a vehicle for someone. Hopefully I'm done for a bit. Got my 100k mile service coming up on the Taco. But that's probably a month or more away.
  14. Mar 20, 2022 at 11:51 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yea my vehicle wrenching has gone down a good bit since getting rid of the Talon. Good thing as the house is taking all my time. One oil change on the Camry is due in a month or so and that's about it. One last free oil change on the Tacoma left so I don't gotta worry about that. Gotta get the mowers out and do the oil changes and other Spring items. I can't get my favored Rotella T5 10w30 so I just ordered a 6 qt case of Valvoline VR1 Syn 10w30.
  15. Mar 20, 2022 at 12:14 PM
    Plain Jane Taco
    USA
    I did the mower and pressure washers last weekend
    lynyrd3 likes this.
  16. Mar 20, 2022 at 1:44 PM
    Tacoma Mike
    Southern Maine
    Since I had to wash the frame a bit cause of my off road excursion , figured you’d like to see a
    10 1/2 year old frame from a salt belt with FF protection. Now I need to do a inside frame wash this year and recoat everything.. going to suck without a lift but I gotta do it now…
    225C0A3F-4AA0-4640-BBC6-CFCF932328A8.jpg 225C0A3F-4AA0-4640-BBC6-CFCF932328A8.jpg
  17. Mar 20, 2022 at 1:50 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Looks really good Mike!
    Gonna be an interesting comparison, I went with a cosmoline product on mine. Seems to have held up well and not washed off where I applied it, even after several touchless car washes with undercarriage spray. Fasteners and the diff/transfer case/etc drain plugs still have a nice amber color to them. We'll see how well it does in a couple years. I did not like what FF looked like, so this was an alternative for me.
  18. Mar 20, 2022 at 1:56 PM
    Plain Jane Taco
    USA
    Nice.
    About a week ago Toyota sent me a notice that they have extended the cutoff date from December 2021 to June 2022 for anyone who has not done the treatment. So I guess technically I can get it done if I want to.
  19. Mar 20, 2022 at 2:11 PM
    Tacoma Mike
    Southern Maine
    For mine they were going to inspect and install the plugs and send it. I didn’t want to change what I was doing… That recall will always be open for me..
  20. Mar 20, 2022 at 2:14 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Off road excursion? What did I miss?
    Got some work on the midget done today. Front bumper and grille test fitted, passenger fender nearly done with welding and fitting the turn signal mount. Also fitted the hood, a bit finicky and definitely permanently tweaked. No big deal since it's a driver and not a show car. Also got the 3D printed filler pieces installed under the rear taillights. 69203E95-7751-417B-AB8D-082010175156.jpg7D6A30E4-77C0-4A22-89C5-26CF7CA49D03.jpgAC0A0650-88BB-4C55-8880-1E3CA894CE41.jpg
    Sig45, MoneyMan55, lynyrd3 and 2 others like this.
