For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. Jul 6, 2022 at 4:28 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    If anyone remembers my "everything I own is broken" post, you can add my lawnmower partially to that list. After reaching maturity, it now identifies as a standard push mower instead of self propelled. Little plastic gears go boom...
  2. Jul 6, 2022 at 4:39 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    https://www.lowes.com/pd/Honda-HRN216VKA-21in-Smart-Drive-Lawn-Mower/1002960678
    I love mine. Just sayin' :D
    In before the money doesn't grow in trees response... :crapstorm:
  3. Jul 6, 2022 at 4:39 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Guessing it's solar powered?
    FlyingWolfe[QUOTED] likes this.
  4. Jul 6, 2022 at 4:40 PM
    Plain Jane Taco
    USA
    Was it the ring gear inside the wheel?
    FlyingWolfe likes this.
  5. Jul 6, 2022 at 4:43 PM
    Plain Jane Taco
    USA
    Not a fan of Honda mowers. They're clumsy, typically have needlessly complicated controls and aren't usually very maneuverable.
    Honda engines on someone's deck I could probably live with.
    I'll take a Toro and Troy-Bilt over a Hondud any day.
    FlyingWolfe and Delta09[QUOTED] like this.
  6. Jul 6, 2022 at 4:49 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    This one is the newer redesigned models. Much more maneuverable and simple compared to other versions.
    Only Toro I could get locally at the time had a Briggs engine and those are a no go for me...
  7. Jul 6, 2022 at 4:49 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 Tundra TRD OR inferno
    No, AC. I put an outlet in the coop.
  8. Jul 6, 2022 at 4:50 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    Mike will fix it! :rolleyes:
  9. Jul 6, 2022 at 4:51 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    :spy:
  10. Jul 6, 2022 at 4:54 PM
    BananaMan
    I would be more in favor of that option really.
    @Plain Jane Taco the casing broke and a bunch of little plastic pieces came out/poked out so I have no idea. At least it free wheels still?
  11. Jul 6, 2022 at 5:01 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Well, now ya got a push mower :D
  12. Jul 6, 2022 at 5:11 PM
    BananaMan
    I did say it identifies as such now, thank you for using its preferred terms! :rofl:
  13. Jul 6, 2022 at 5:15 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
  14. Jul 6, 2022 at 5:18 PM
    Plain Jane Taco
    USA
    I've had good luck out of all my B&S.
  15. Jul 6, 2022 at 5:18 PM
    Plain Jane Taco
    USA
    Nice :thumbsup:
  16. Jul 6, 2022 at 5:21 PM
    BananaMan
    Yeah, amazingly fast at growing more grass that needs to die.
    Plain Jane Taco likes this.
  17. Jul 6, 2022 at 5:21 PM
    Plain Jane Taco
    USA
    I would have to see a pic. But typically the drive gear is metal and the ring gear inside the wheel is plastic. The plastic almost always loses the battle to the metal. Drive wheels are plentiful on the ol' interwebs.
    Is it FWD or RWD? And what brand?
    BananaMan[QUOTED] likes this.
  18. Jul 6, 2022 at 5:23 PM
    BananaMan
    It's a craftsman, rwd, and it's old enough/broke enough that I've cut it off from the bank account. Except for when it needs a drink that is... the search for a half okay used riding mower has begun.
  19. Jul 6, 2022 at 5:26 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Too bad you're so far away. I could hook you up with my old 30" Craftsman rear engine rider. It does need a new camshaft due to the compression release has failed, but does start, we just put a bigger CCA battery in it. Those Briggs camshafts are on back order till November at the earliest... o_O
  20. Jul 6, 2022 at 5:27 PM
    Plain Jane Taco
    USA
    Then it's probably a rebadged Husqvarna/AYP. Parts are available. But I understand ya gotta draw the line somewhere
