For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. Sep 13, 2022 at 3:50 PM
    Tacoma Mike
    Tacoma Mike [OP] 48 Year Chrysler/Toyota/ASE/ Master Tech.RETIRED
    Southern Maine
    You won’t like it.
  2. Sep 13, 2022 at 3:51 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    I can't think of many people that would like a predator with a turbski
    MQQSE and Plain Jane Taco like this.
  3. Sep 13, 2022 at 3:53 PM
    Tacoma Mike
    Southern Maine
    No just the t. Delay, will kick in halfway through a corner. Better off with a charger. IMHO
  4. Sep 13, 2022 at 3:53 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Still ain't gonna be as fast as a 3.5 V6 :D
  5. Sep 13, 2022 at 3:55 PM
    BananaMan
    I'm fitting a td05H sized for a 2.0, so in theory with all the head+flow work I should be able to spool it into positive boost by 2500-3000 or so?
  6. Sep 13, 2022 at 3:55 PM
    BananaMan
    Oooh that makes me sick....
  7. Sep 13, 2022 at 3:56 PM
    Tacoma Mike
    Southern Maine
    To much weight. To much torque.
  8. Sep 13, 2022 at 3:58 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I can assure you, it doesn't have torque at all... :laugh:
    But it will shit n' git' if need to be...
    MQQSE, Plain Jane Taco and BananaMan like this.
  9. Sep 13, 2022 at 3:58 PM
    Tacoma Mike
    Southern Maine
    Better have a set of gears in it to keep the rpm up
  10. Sep 13, 2022 at 3:58 PM
    BananaMan
    If I wanted to drive a minivan, I'd put that engine in there.
  11. Sep 13, 2022 at 3:59 PM
    Tacoma Mike
    Southern Maine
    You don’t understand. So,we will leave it as is..
  12. Sep 13, 2022 at 4:00 PM
    BananaMan
    With the current gear set, second gear, and an rpm limit raised to 7800, I should be able to stay in second gear for the entirety of most courses.
  13. Sep 13, 2022 at 4:02 PM
    Tacoma Mike
    Southern Maine
    When I was doing it they had a granny corner all the time. Apparently you have the ability to keep rpm’s up..
  14. Sep 13, 2022 at 4:05 PM
    BananaMan
    I am slightly hampered by the granny corner. But my trans also refuses to go into first unless I'm doing 7mph or less, which means unless I spin out and stop I typically can't use it. I usually have to find a line through that one corner that acts more like a momentum line, and keep as much speed up with some trailing brake normally.
    Plain Jane Taco likes this.
  15. Sep 13, 2022 at 4:09 PM
    BananaMan
    I mean, I know I'm not in a Miata, so I accept that and try to find ways around it. I really think a shorter ratio steering rack would help immensely.
  16. Sep 13, 2022 at 4:13 PM
    Tacoma Mike
    Southern Maine
    If you could figure out the Ackerman, shorter tie rod ends would help also..
  17. Sep 13, 2022 at 4:14 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    It definitely needs some Deputyin'
    BananaMan likes this.
  18. Sep 13, 2022 at 4:15 PM
    Plain Jane Taco
    USA
    So true
  19. Sep 13, 2022 at 4:16 PM
    Plain Jane Taco
    USA
    Predator? :laugh:
    It's better than the Hobo Fright special for sure
  20. Sep 13, 2022 at 4:17 PM
    Plain Jane Taco
    USA
    Wow...preemptive score. That's faith
    Sig45[QUOTED] likes this.
