For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. Oct 18, 2022 at 4:29 PM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 Tundra TRD OR inferno
    BananaMan, Sig45, MQQSE and 2 others like this.
  2. Oct 18, 2022 at 4:32 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    This is like plucking balls hairs one at a time with tweezers. I give up.
  3. Oct 18, 2022 at 4:36 PM
    PennSilverTaco
    PennSilverTaco Encyclopedia of useless information...
    Charlie
    Central Bucks, Pennsylvania
    2010 Zombie Truck 2002 PT Cruiser
    You're about to learn something, my friend... :);)
    All of your vents are in the ceiling, 1st and 2nd floor?
    Well, cold air is more dense, so it falls. This makes ceiling vents the most efficient setup. Hot air is lighter, so it falls, which is baseboard/radiator heat is considered to be so efficient. Sure, a forced air system with vents in the floor will be fine when you have the heat on, but if that system has A/C as well then it won't be as efficient as a system with vents in the ceiling.
  4. Oct 18, 2022 at 4:36 PM
    kwanjangnihm
    kwanjangnihm Timeout Terminator
    Jeff
    Central Florida
    13 DCLB TRD SP PR OTT
    "If it ain't a longbed it ain't shit! :)
  5. Oct 18, 2022 at 4:38 PM
    PennSilverTaco
    Charlie
    Infrared flatulence! :rofl:
  6. Oct 18, 2022 at 4:40 PM
    Tacoma Mike
    Tacoma Mike [OP] 48 Year Chrysler/Toyota/ASE/ Master Tech.RETIRED
    Southern Maine
    ROFLMAO…
    I worked mark’s shifter very hard…..
    :anonymous::anonymous::anonymous::anonymous:
    Pulled the console
    Lubed the shift cable and shifter assembly
    Lubed the trans shift pivot and cable ball
    Lubed the prndl switch and cross through rod.
    Tapped on the cross rod for about a min.
    Ran the shifter about 100 times through full range of motion.
    Sprayed FF on all previous lubed areas.
    Put the console together.
    Scanned the truck.
    Cleared the code
    Checked the cable alignment and switch sync.
    Sent it…
    OK??? Lol
  7. Oct 18, 2022 at 4:41 PM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    150
  8. Oct 18, 2022 at 4:42 PM
    Tacoma Mike
    Southern Maine
    You gotta consider the source……
  9. Oct 18, 2022 at 4:43 PM
    kwanjangnihm
    Jeff
    Central Florida
    was this the problem or solution?? :rofl:
    Plain Jane Taco and Sig45 like this.
  10. Oct 18, 2022 at 4:43 PM
    PennSilverTaco
    Charlie
    Of the gas?
    FlyingWolfe and Plain Jane Taco like this.
  11. Oct 18, 2022 at 4:44 PM
    Tacoma Mike
    Southern Maine
    And he didn’t have to wait two weeks for a appointment lol
  12. Oct 18, 2022 at 4:45 PM
    Tacoma Mike
    Southern Maine
    Yes and no…
    MQQSE, Plain Jane Taco and Sig45 like this.
  13. Oct 18, 2022 at 4:46 PM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
  14. Oct 18, 2022 at 4:49 PM
    Tacoma Mike
    Southern Maine
    I did.
    It needed it.
    It was all stiff and dry..
  15. Oct 18, 2022 at 4:50 PM
    PennSilverTaco
    Charlie
    That's what she said! :D
  16. Oct 18, 2022 at 4:54 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Glad you were able to lube it up for him...
  17. Oct 18, 2022 at 4:55 PM
    Tacoma Mike
    Southern Maine
    Yea I didn’t want him to pay for something he didn’t need.
  18. Oct 18, 2022 at 4:58 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Butt he definitely needed some lubing up... :D
  19. Oct 18, 2022 at 5:01 PM
    Tacoma Mike
    Southern Maine
    Yes, yes he did.
    If it happens again maybe you can scrape and clean his infection.
  20. Oct 18, 2022 at 5:05 PM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    If he gets the green crusties it's shot time, I'm not getting near anything like that again with a 10 foot pole!
