For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. Sep 4, 2023 at 6:21 PM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Any tips? Ours is a year and a half or so, and he's an absolute wiggle worm when we get home from work. Our vet said they can give him anti inflammatory medicine, but it's pricy for something that should heal naturally.
  2. Sep 4, 2023 at 6:28 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Yeah ours is normally quite the wiggler also. I just cut back on walks and obviously no swimming for a couple weeks. Tried to minimize jumping and stuff like that. Our vet literally said if she got too happy and wagged a lot, it could make it worse :rolleyes:
    I think typically if you just keep physically activity to low-key stuff, it will fix itself. Our dog acted kind of like she had the flu when she had happy tail so it wasn’t too hard to convince her to stay calmer than usual.
    BananaMan[QUOTED] likes this.
  3. Sep 4, 2023 at 11:44 PM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    Bummer. Rimadyl is a common anti-inflammatory for dogs and works well, but lots of it/prolonged use is hard on their liver.
  4. Sep 5, 2023 at 3:21 AM
    BananaMan
    Mornin folks. Here's a look over my empire of stuff. Starting off the day with pumping 90 gallons of hydraulic fluid into a remote trailer. Enjoy your "monday"
    CTSpruceMica, Sig45 and Delta09 like this.
  5. Sep 5, 2023 at 3:23 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    The heck, the sun isn't up here yet!?
  6. Sep 5, 2023 at 3:24 AM
    BananaMan
    I mean technically... just a little foggy
  7. Sep 5, 2023 at 3:25 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    Should be a good time working on that deck this week. :censored:
  8. Sep 5, 2023 at 3:25 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I just remembered yous guys are a little further East than me... :laugh:
  9. Sep 5, 2023 at 3:46 AM
    Tacoma Mike
    Tacoma Mike [OP] 48 Year Chrysler/Toyota/ASE/ Master Tech.RETIRED
    Southern Maine
    Just keep saying that
    Sig45[QUOTED], MQQSE and BananaMan like this.
  10. Sep 5, 2023 at 3:46 AM
    Tacoma Mike
    Southern Maine
    A little??
    BananaMan and Delta09[QUOTED] like this.
  11. Sep 5, 2023 at 3:49 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    I have trouble with distance... :rofl:
  12. Sep 5, 2023 at 3:56 AM
    BananaMan
    Clearly, mister sagsalot
    Sig45, MQQSE, FlyingWolfe and 2 others like this.
  13. Sep 5, 2023 at 4:27 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Your time's coming buddy! :luvya:
    MQQSE and BananaMan[QUOTED] like this.
  14. Sep 5, 2023 at 4:29 AM
    BananaMan
    Hey I've got the going grey issue, I'll live with hair dye instead of clothespins keeping my bits in place.
    MQQSE and Delta09[QUOTED] like this.
  15. Sep 5, 2023 at 4:29 AM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    Mine hit my beard overnight at 55. Head will take longer if I follow my parents schedule. Glad for that I suppose.
    hey crew. Happy work week!
    Sig45, MQQSE, BananaMan and 1 other person like this.
  16. Sep 5, 2023 at 8:19 AM
    FlyingWolfe
    FlyingWolfe Wolfie
    Crystal
    Maine
    2018 Tundra TRD OR inferno
    Hubs and I have already gone through about gallon of water a piece before 11, including some ‘salterades’ we make (lemon and salt in water, helps with the muscle cramps). This week is gonna blow.
  17. Sep 5, 2023 at 8:33 AM
    CTSpruceMica
    CTSpruceMica My driving scares me too
    Dennis
    2014 Spruce Mica
    Brings back memories from late '80s when I ran operations for a truck equipment firm. We did everything from state DOT plow trucks and tri-axle dumps to power company bucket truck builds, digger derricks, and crane installs. Back then used Heil dump bodies, lot of Teco and Mobile Equipment buckets, Heil packers. Forgot whose utility body we used on the buckets. Lots of 2800 gallon fuel delivery trucks also.
    Delta09, MQQSE and BananaMan[QUOTED] like this.
  18. Sep 5, 2023 at 9:52 AM
    BananaMan
    We do Heil dump bodies, they split and call them duraclass now. All our big tri axles are beauroc (Canadian). Reading service bodies as well, so pretty much the same thing as what you did. We tend to leave the state DOT to other guys, they can be a bit picky to deal with. And we don't touch plows. (thank goodness)
    Delta09, MQQSE and Charlie Bravo like this.
  19. Sep 5, 2023 at 10:01 AM
    Charlie Bravo
    Charlie Bravo Well-Known Member
    Charlie
    Coeur d'Alene, Idaho
    2009 Red Tacoma Access Cab 4wd 2.7MT
    RedLine Tuning hood QuickLIFT, Gen3 alloy 16x7J, All Pro Off-road bed stiffeners & IFS skid plate
    20230905_092640[1].jpgExhaust Manifold Laboring Day: The morning after. Socializing in the garage with my new neighbor, after spending the afternoon moving and removing pieces to get at the manifold, then spraying P'Blaster on the nuts periodically (and cleaning that part of the compartment) until late, mentally focusing on having all the nuts turn loose while asleep. Nope, but this morning, I'm happy that there's enough room for a 1/2" drive ratchet and 3/8 adapter to fit around and between primary tubes. They make it look easy in their videos with much use of an air ratchet on a non corroded Arizona Tacoma. Hoping to get 'er done by midafternoon, as I got a crack out of the lower six to loosen so typing this while the penetrant soaks. - My neighbor was troubleshooting his pressure washer, and announced, "I found the problem." One of his crew had apparently tipped it over, so it was full of oil instead of gas, and wouldn't fire. :yay: Progress!
    Delta09, MQQSE and BananaMan like this.
  20. Sep 5, 2023 at 10:14 AM
    BananaMan
    I always love seeing those install videos on brand new/clean vehicles. The thought in my head is always "alright, now come do that on my 200k mile rig..."
    Charlie Bravo[QUOTED] and MQQSE like this.
