For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. Apr 17, 2024 at 3:45 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    Anybody with a dog that lays around nice and peacefully is lucky :rofl:
    kidsmoke and jwctaco[QUOTED] like this.
  2. Apr 17, 2024 at 3:49 AM
    Tacoma Mike
    Tacoma Mike [OP] 48 Year Chrysler/Toyota/ASE/ Master Tech.RETIRED
    Southern Maine
    We adopted 2 older mutts and they were the best dogs ever..
    One I ran over and the other one I washed to death.
    Never got another one.. to painful…
    BananaMan[QUOTED] likes this.
  3. Apr 17, 2024 at 7:01 AM
    BananaMan
    Top tool tip today. Unscrew the plug on your drain pan before starting to drain oil into it. If you don't, you'll have a minor brown pants moment and have to reach into hot oil to do it.
    Sig45, jwctaco, 50Buck and 1 other person like this.
  4. Apr 17, 2024 at 8:24 AM
    BananaMan
    @Tacoma Mike this is the proper tightness for an oil filter right? Ended up having to use a 12"strap wrench to get it off.
    Sig45 likes this.
  5. Apr 17, 2024 at 8:34 AM
    Tacoma Mike
    Southern Maine
    I only used my hands to put it on, I swear…
    Maybe a dry install…
    I have had to use two wrenches in tandem to avoid crushing the housing.
    That was a good un
  6. Apr 17, 2024 at 8:37 AM
    BananaMan
    I'm also guessing it's been there awhile since it started rusting and flaking paint. But, changed the air in a couple tires (slow leakers over the winter) and changed the oil. Charged up the four year old battery I took out for the winter and she fired up with no complaints. Maybe I'll give it a bath...
  7. Apr 17, 2024 at 8:42 AM
    Tacoma Mike
    Southern Maine
    Oh no, not a bath….I use slime in the tires. Helps keep them sealed
  8. Apr 17, 2024 at 8:44 AM
    BananaMan
    I replaced a front tire last year (what a saga that was) and if this rear one proves to be a fast leak I'm just going to put a tube in it. The tire is nearly new with plenty of tread left so I'm not going to go buy a new tire again.
  9. Apr 17, 2024 at 11:03 AM
    BananaMan
    Considering I'm home sick today, I've now discovered what my dogs do all day while I'm gone.
    Sig45, CTSpruceMica, kidsmoke and 3 others like this.
  10. Apr 17, 2024 at 11:04 AM
    Tacoma Mike
    Southern Maine
    Better than ransacking the house.
  11. Apr 17, 2024 at 11:15 AM
    kidsmoke
    kidsmoke Well-Known Member
    Flyover Country
    '13 BR AC SR5 4x4 AT
    fuckers.
    wait...you guys change oil in your mowers??? :crazy::der:
  12. Apr 17, 2024 at 11:16 AM
    50Buck
    50Buck Living rent free Timmy the Tool's head
    2025 Tundra Crew Max
    :anonymous:
    CTSpruceMica, Delta09 and BananaMan like this.
  13. Apr 17, 2024 at 11:19 AM
    kidsmoke
    Flyover Country
    todays to do.
    pump swap on the coolant system fo a V12 Natural Gas generator. Frickin' LOUD and frickin' HOT. My knees aint what they used to be.
    But these things are cool. Single room with three of these bad boys running full tilt.
    Had hell of a time gettin' the old gasket material off. This circuit runs hot and bakes everything.
    Sig45, jwctaco, Delta09 and 1 other person like this.
  14. Apr 17, 2024 at 11:30 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Bro...
  15. Apr 17, 2024 at 11:33 AM
    50Buck
  16. Apr 17, 2024 at 11:34 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    :anonymous: :anonymous: :anonymous: :anonymous:
    50Buck[QUOTED] and BananaMan like this.
  17. Apr 17, 2024 at 11:34 AM
    BananaMan
    I'm more likely to change the oil in my mower than I am in my differential :rofl:
    Delta09 likes this.
  18. Apr 17, 2024 at 11:35 AM
    BananaMan
    160
    Sig45 likes this.
  19. Apr 17, 2024 at 11:35 AM
    50Buck
    :rofl::rofl::rofl:
    Delta09[QUOTED] likes this.
  20. Apr 17, 2024 at 11:46 AM
    kidsmoke
    Flyover Country
    I just thought you're supposed to run the shit out of 'em til the blades are bent or dull, carb clogs, or it siezes. Then you push it to the curb where the mower fairies make them disappear and @Tacoma Mike somehow turns them into bait money.
    no?
