For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. Oct 7, 2024 at 2:25 AM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Nothing, you're perfectly fine using 0w16. The thinner the oil, the better the fuel economy is....at least on paper. That kind of stuff matters here in The States where we have CAFE. Also, here in The States the EPA mandates that a manufacturer "recommend" whatever viscosity the engine is certified on. If you read the manual though, it will say it's fine to use a heavier oil under certain conditions.
    Generally speaking a more viscous oil (heavier) will provide a bit more protection. I use 0w20 in both our Corollas that recommend 0w16. The viscosity difference is not that dramatic at operating temperature and I still have the winter weight (0w) for quick cold temperature flow.
    Charlie Bravo and MQQSE[QUOTED] like this.
  2. Oct 7, 2024 at 2:26 AM
    Plain Jane Taco
    USA
    He cut you off at the pass. :laugh:
    Charlie Bravo, Delta09 and MQQSE like this.
  3. Oct 7, 2024 at 2:35 AM
    Tacoma Mike
    Tacoma Mike [OP] 48 Year Chrysler/Toyota/ASE/ Master Tech.RETIRED
    Southern Maine
    Morning @MQQSE
    Bill can explain it better than I can but it’s the flow of fluid at a certain temp.
    The less resistance the easier the engine rotates which equals more mpg.
    But there are specs for each manufacturer and IIRC some overlap other weights. that’s why if you change your oil when it’s warm it’s like water.
    Bill will slap my hand if I’m wrong.
  4. Oct 7, 2024 at 2:43 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    :laughing:
    So here's my thought interpreting what you've posted. I might sacrifice a likely negligible MPG amount for longer engine life by running 0W-20 vs 0W-16. I just as soon use 0W-20, as that is what I've been using in the Truck and Highlander.
    Straight up, am I interpreting your words correctly. Knowing your background, I truly value your opinion here.
    Thank you, Good Morning, yada-yada-yada :hattip:
  5. Oct 7, 2024 at 2:43 AM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
  6. Oct 7, 2024 at 2:45 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Nothing wrong with 0w16 and with the cold temperatures and all the miles you put on it's perfectly fine. I use 0w20 in the Camry (where it specs 0w16) is to have a little buffer for oil dilution due to short trips and idling.
  7. Oct 7, 2024 at 2:47 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    Thank you Mike. :fistbump:
  8. Oct 7, 2024 at 2:50 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :cool: Thanks Adam
  9. Oct 7, 2024 at 3:18 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  10. Oct 7, 2024 at 3:23 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    My current Turbo Taco specs 0w20 and if I were changing the oil myself I'd bump it up to 5w30 like I did with my 3rd gens. It's going to be a dealer baby till I turn it in, and they use Mobil 1 0w20 in their bulk tanks. I'm more worried about the transmission grenading over the engine :laugh:
  11. Oct 7, 2024 at 3:41 AM
    lynyrd3
    Bill
    East Central Upstate NY
    Morning Stockville
  12. Oct 7, 2024 at 3:49 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    What's this trans grenading shtuff? I've ignored all things 4th Gen so far ... they lost me at "Turbo."
  13. Oct 7, 2024 at 3:50 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
  14. Oct 7, 2024 at 3:52 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    :hattip: Deputy
  15. Oct 7, 2024 at 3:57 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    More casting debris apparently in the transmission which renders gears 1-6 useless leaving only 7-8. I think vin dates up to 5/24 can be affected. Of course mine is a 1/24 build. I was initially going to keep the truck as it's my favorite one so far, but if the trans doesn't fail within my 3 years and gets replaced they can have it back. It has been shifting funny recently so who knows :goingcrazy:
  16. Oct 7, 2024 at 4:17 AM
    Tacoma Mike
    Southern Maine
    First day back at the Gym since spring..
    Had way too many projects. Paying the price now.
    Heart Rate was still good though..
    I might survive yet.
  17. Oct 7, 2024 at 5:08 AM
    Knudsen
    Knudsen Well-Known Member
    Jon
    2008 Access Door TuRD
    To bet installed: bling grill, headlights, fog lights.
  18. Oct 7, 2024 at 5:08 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Never buy first year regen" confirmed. Contributing factor in my not buying my 3rd Gen 'til 2019. Which also caused my biggest truck buying mistake ...
    that POS Ram. :bananadead:
    Also contributed to My Chief buying his 2023 3rd Gen vs 2024 4th Gen. :cookiemonster:
  19. Oct 7, 2024 at 5:10 AM
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    No worries Sunshine ... the "Grumpy Deniers" die last. ;)
  20. Oct 7, 2024 at 5:11 AM
    Plain Jane Taco
    USA
    In theory yes. Regardless, using 0w20 in Sumbitch will be perfectly fine if you want to standardize your oil stash. It will flow just has quickly as 0w16 and any MPG loss will negligible. 0w20 is also less prone to icing than 0w16.
    But don't lose a moment of sleep over any of this. Continuing 0w16 will be just fine if that's what you want to do.
    Adam and I have just spent too much time hanging out on BITOG site. :laugh:
