For Stock Rigs Only
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacoma Mike, Aug 16, 2019.
  1. Mar 15, 2021 at 9:46 AM
    Yukon DoIt
    Yukon DoIt Opinionated Northerner
    Paul
    Yukon, Canada
    2006 White Tacoma DCLB 4wd Auto, 1988 Blue 4Runner 4wd Manual
    Stock-y
    So in the last 30k miles it doesn't appear to have gotten new plugs, and who knows how long before that. So that solidifies that as a spring project for me. :burp:
    Plain Jane Taco and 907rx7 like this.
  2. Mar 15, 2021 at 9:47 AM
    907rx7
    907rx7 Well-Known Member
    James
    '20 Tacoma DCSB SR 4x4
    From what I remember in Fairbanks -20F was no issue for the 3.4 or 4.0s. I'm guessing it's just time for new plugs. The gap is probably way off by now.
    What does your winterization look like other than the block heater?
    Plain Jane Taco likes this.
  3. Mar 15, 2021 at 9:56 AM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    I haven't done anything special, but it's started fine so long as I had the block heater plugged in. Even started it at -50 once with only a few extra cranks of hesitation.
  4. Mar 15, 2021 at 9:58 AM
    BananaMan
    BananaMan Well-Known Member
    Bumfrick nowhere Maine
    06 2.7 RC 2wd manual "squattytruck"
    I was able to start my 2.7 at -30 with only an extra crank or two, never failed to start for me.
  5. Mar 15, 2021 at 10:00 AM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Yeah, that's me with the 3.slow. This 4.0 is new to me, so I'm learning that it needs to be babied a bit. Hopefully the plugs are worn to crap though. Most folks on this forum are from warmer regions, so it's hard to get a gauge on the 4.0 in extreme temps.
  6. Mar 15, 2021 at 10:40 AM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Well being plugged in for 3 hours it fired up like no one's business. I'm leaning sparkolators at this point, though who knows.
    Plain Jane Taco, BananaMan and 907rx7 like this.
  7. Mar 15, 2021 at 10:54 AM
    BananaMan
    How many miles are on that rig?
  8. Mar 15, 2021 at 10:56 AM
    BananaMan
    Welp, that didn't take long. The clutch is on its way out. Trying to get on the highway I grabbed 3rd, pushed on the go juice pedal, and the rpms came up and up and up while the speedometer barely moved. Backed off the happy pedal a bit and it finally grabbed and the rpms came back down.
    Plain Jane Taco and FlyingWolfe like this.
  9. Mar 15, 2021 at 11:08 AM
    Delta09
    Delta09 Requires Supervision
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    :rofl:
    They're stupid simple on the 4.0. You gotta remove the intake metal bracket on the drivers side, but that's it. That was the first thing I did to my 2009 when I bought it. The 10mm bolt holding the coil pack to the valve cover can be a struggle since it's steel on aluminum. I had to beat a socket on there. I picked up Denso's from the dealer. Those or NGK's are you're best bet, in copper of course.
    That sucks! Well atleast you can go ahead with an upgraded clutch since you're planning on adding power down the road.
  10. Mar 15, 2021 at 11:15 AM
    BananaMan
    :eek::eek::eek: I really hope that was a joke... iridium or platinum at least!
    Yeah I was hoping to get longer out of this clutch and swap for an updated one when the built engine went in.
  11. Mar 15, 2021 at 11:18 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    No, no joke. The 4.0 takes standard copper plugs and seems happiest on them.
  12. Mar 15, 2021 at 11:21 AM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    Yeah, tons of people on here say Iridium give them worse mpg than copper on the 4.0. I haven't heard anything on the platinum ones.
    @BananaMan It's got 175k miles, so hopefully has had at least one plug change...
    Plain Jane Taco and BananaMan like this.
  13. Mar 15, 2021 at 11:24 AM
    BananaMan
    That's nuts, I barely accept copper plugs in my lawnmower!
  14. Mar 15, 2021 at 11:26 AM
    907rx7
    James
    Does it have ngk on one bank and denso on the other? That was the giveaway on the 3.4 they were original, not sure if they did it on the 4.0.
  15. Mar 15, 2021 at 11:27 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Yup same scenario.
  16. Mar 15, 2021 at 11:43 AM
    Yukon DoIt
    Paul
    Yukon, Canada
    Stock-y
    I'll be sure to post about it once I pull them. It won't be for a month probably, supposed to warm up here pretty soon and it's a good springtime activity.
    Plain Jane Taco, Delta09 and 907rx7 like this.
  17. Mar 15, 2021 at 11:44 AM
    Delta09
    Adam
    South Central PA
    2024 SR5 DCSB 4WD
    Damn, you is a youngin' :D:rofl:
  18. Mar 15, 2021 at 1:44 PM
    Plain Jane Taco
    Plain Jane Taco Well-Known Member
    USA
    Hello man and.......just a man :notsure:
    :D
    :fistbump:
  19. Mar 15, 2021 at 1:45 PM
    Plain Jane Taco
    USA
    Sorry Paul
  20. Mar 15, 2021 at 1:46 PM
    Plain Jane Taco
    USA
    I like flaps on a truck :thumbsup:
    Delta09[QUOTED] and six5crèéd like this.
