For the Supercharged wanting Guys and Gals
Discussion in '2nd Gen. Tacomas (2005-2015)' started by metrick1215, Mar 4, 2016.
  1. Mar 4, 2016 at 1:18 PM
    metrick1215
    metrick1215 [OP] Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
  2. Mar 4, 2016 at 1:21 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
  3. Mar 4, 2016 at 1:23 PM
    gordi
    gordi Only had a wheel fall off once
    Josh
    North Idaho
    2011 DCSB trd sport
    Fox 2.5 extended travel, dakars, rear 5125 255/80/17 cooper maxx ST
  4. Mar 4, 2016 at 1:26 PM
    Hardscrabble
    Hardscrabble Well-Known Member
    Scott
    McDonough, GA
    ‘20 Sport M/T AC 4WD & '15 TRDOR DCSB 4WD
    A little of this and a little of that.
  5. Mar 4, 2016 at 1:27 PM
    Sub_Par
    Sub_Par Well-Known Member
    Buffalo NY
    2011 TRD Off Road
    This is not news. Been covered before, LCE Performance has had them on pre-order for a while now. There are 3-4 other threads on this already.
  6. Mar 4, 2016 at 1:27 PM
    jsriolo
    jsriolo Well-Known Member
    Susquehanna, PA
    2015 TRD Off-Road V6 6-Speed 4x4 Access Cab
    The description state that a new pump is included. Was that in the TRD kit? (I don't believe so)
    Anyways that might explain a little bit of the increase.
  7. Mar 4, 2016 at 1:29 PM
    Mclovin80
    Mclovin80 Not Well-Known
    Tampa, FL
    2021 LR TRD Pro
    Lay-away? lol
  8. Mar 4, 2016 at 1:33 PM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    LCE is showing a dyno that seems to be higher than most truck with the TRD version and reflash. @Rock Lobster was yours ever on a dyno?
  9. Mar 4, 2016 at 1:38 PM
    mattgecko
    mattgecko The LED Lighting Guy. MattGeckoLEDs.com
    South San Jose, CA
    2011 DCSB O.R. 4wd TRD Super Charged
    It looks identical to the TRD SC. Why is it $2k more?
  10. Mar 4, 2016 at 1:42 PM
    Glueman
    Glueman Yersinia pestis
    Utah
    The Plague....
    6 inch Douche Bag lift...what else do I need?
    ...because capitalism. :oldglory:
  11. Mar 4, 2016 at 1:55 PM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Yea LCE is now showing 289hp and 291tq for a 2015, someone must have dyno'd a 15 with the kit and Bully Dog flash.
  12. Mar 4, 2016 at 1:57 PM
    Sub_Par
    Buffalo NY
    2011 TRD Off Road
    Yea its weird on Magnusson's site they have the same dyno for a 15. Something doesn't add up because its gonna lose more than 16hp to the wheels.
  13. Mar 4, 2016 at 6:39 PM
    metrick1215
    Habersham GA..
    Sorry if it was a repost i hadnt seen it yet, but i thought it would be good info for all the people that were upset that TRD would no longer have a supercharger for their trucks.
  14. Mar 4, 2016 at 7:39 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Did not include a pump upgrade, with the TRD s/c. Which would also mean that it would have to comes with new hoses, similar to the URD kit. IF this Magnuson kit comes with a new pump.
    The addition of the hand held tuning device. That price I believe is in the BullyDog thread.
  15. Mar 4, 2016 at 7:43 PM
    cseaman
    cseaman Well-Known Member
    Atropia
    2019 RS3, 2019 SQ5
    Lol, you could probably pay $6200 to a competent shop to drop a 5.3 LSx into these trucks.
    thewarriordinghy likes this.
  16. Mar 4, 2016 at 7:47 PM
    Maticuno
    Maticuno Resident Pine Swine
    California High Deserts
    2011 Suburban 2500
    JBA Shorty Headers, Flowmaster FlowFX Sing/Dual Exhaust
    $6k would go a long way toward the down payment on a V8 truck...
    Sugar Silva likes this.
  17. Mar 4, 2016 at 7:54 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    There correction factor was in STD. It will read a little higher than SAE correction. I have no clue if they had an engine on the engine dyno for the BHP numbers, but it is a possibility. What we do see is that the dyno provided is a chassis dyno, and is on two sites. Which means that the dyno chart has been distributed from Magnuson. With a probably correction for sea level as well. Hypothetically but probable. Being that the dyno started before 3K rpms, my guess is that it was a manual.
    The scale is even as idicative of the two curves crossing at 5250 rpms.
    It is still in a percentage range with expected numbers. Different style dynos will have different number outputs. Drivetrain attached being the lowest. Mustang eddy current style, then inertial drum.
  18. Mar 4, 2016 at 8:00 PM
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
  19. Mar 4, 2016 at 8:02 PM
    locster
    locster Well-Known Member
    Luke
    Orange County, CA
    2014 DCSB 4x4
    I doubt it's CARB legal for us CA folks.
  20. Mar 4, 2016 at 8:03 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    It won't be. Fun inducers cause cancer in Cali.
    js312 likes this.
