For the TW members set up correct/approved or concerns
Discussion in '3rd Gen. Tacomas (2016-2023)' started by baboltin, Feb 26, 2025.
  1. Feb 26, 2025 at 11:31 AM
    baboltin
    baboltin [OP] New to the 3rd gen world!
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Stock with a camper shell for now.
    So I am getting ready to purchase a number of items for my truck and would like to know what everyone’s thought is? If there is any additional items I should purchase to install while doing the process of skids, suspension and wheels. I have already installed the bushing in the diff to take care of the lift.
    Also with my tire/wheel/suspension set up does anyone think I will have any type of rubbing issues. I have not done and didn’t plan on doing a cab mount cut or install, but building a set up that would clear without any modification in that area.
    looking for any advice or suggestions if from the research I have done this won’t work.
    Exhaust re-route( happening this Friday to prepare for skids)
    Skid plates
    Rci
    Engine skid - steel
    Transmission skid - steel
    Transfer skid- steel
    Gas tank skid- aluminum
    A-arm skids- steel
    (All from rci)
    will install rubber washer and flat washer for reported squeaky with these skids during installation.
    Suspension
    Front
    Bilstein 6112 clip 11/9- 2” lift shocks
    Old man emu upper control arms
    Rear
    OME 2” lift 661 LB leaf pack
    Bilstein 5160 shocks
    Wheels
    Black rhino chamber 17” 17x8.5 0 offset
    QUESTION -should I or do I need new lug nuts? From research I’m thinking yes and should purchase gorilla ET lug nuts (M12x1.5 flanged and ET lug nuts) this sound correct ?
    Tires
    255x80-17
    QUESTION- with this set up will I rub? From my research this set up seems to not rub but maybe I’m wrong?
    what is everyone’s thought ?
  2. Feb 26, 2025 at 11:52 AM
    K9tacoma
    K9tacoma Well-Known Member
    Austin
    Central Ohio
    2023 Tacoma TRD Off Road - Lunar Rock
    Looks like a good setup to me, 255/80/17 won't rub at stock height so you'll be more than good on clearance.
  3. Feb 26, 2025 at 11:54 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    My thoughts; why would anyone spend this kind of money altering a perfectly capable off road vehicle as is? Save your money brother as there will come a day where you will regret doing this.
    jwctaco, 23MGM, Phlogiston and 3 others like this.
  4. Feb 26, 2025 at 12:06 PM
    Spuds509
    Spuds509 Active Member
    Nick
    Spokane Wa
    2018 TRD Off-Road
    Some stuff
    The poors are out again
    musicisevil likes this.
  5. Feb 26, 2025 at 12:13 PM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2018 Silver Sky Tacoma SR Access Cab 4X4
    SnugTop SuperSport shell CaliRaisedLED light bar BFG K0 AT’s Bilstein 5100's up front, (#2) & 4600 in rear N-2 Designs remote start/keyless entry Anytime 12v outlets... one by shifter & one in bed Daily driver....
    You might want to do the ECGS (needle Bering) being your doing a lift.
  6. Feb 26, 2025 at 12:27 PM
    airforceb2cc
    airforceb2cc Well-Known Member
    Don
    KCMO
    2021 DCSB Nightshade
    Ironman FCP; 315/75R16; KDMAX; Skids; Sliders
    I would hold off on the LCA skids. I bought them and immediately took them off. They take a lot of clearance away and will hang you up more than you would think. And they don't protect much at all...the factory LCAs can take an absolute beating and still be golden. If you plan on wheeling hard, get cam tab gussets and weld them on before getting the new alignment after your lift.
  7. Feb 26, 2025 at 12:28 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    I did this already.
    monoman[QUOTED] likes this.
  8. Feb 26, 2025 at 12:29 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    I decided to do this after I have off roaded my truck hard enough to bend a crossbar member and would like to use my truck without concern.
    Spuds509[QUOTED] likes this.
  9. Feb 26, 2025 at 12:30 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    I appreciate the advice and was on the fence for a arm skids glad I made this post
    Spuds509 likes this.
  10. Feb 26, 2025 at 12:31 PM
    RichochetRabbit
    RichochetRabbit Ping Ping Ping
    Engine and transmission skid ... yes. Get the catalytic converter guards that bolt to the transmission skid.
    Exhaust re-route ... that is OK. Usually around $100 so get it done since it is scheduled.
    The rest ... why? Do you plan on serious rock-crawling in the near future? Do you plan to cross deep rivers soon (get a schnooorkull too, then)?
    Prove the need, then spend the money ... when spending money on that level.
  11. Feb 26, 2025 at 12:31 PM
    airforceb2cc
    Don
    KCMO
    I went with the Marlin Crawler cam tab kit and holy crap it is beefy...and acts as a "skid" for your cam bolts/frame attach points. And the same price as other gusset kits.
    t0p_d0g and baboltin[QUOTED][OP] like this.
  12. Feb 26, 2025 at 12:49 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    I have already hit the undercarriage with rocks and would like some ground clearance and my shocks are tired and need to be replaced anyway, and the leaf in the rear is flat and saggy since I have a camper shell. So I figured while I need protection for the undercarriage of my truck to protect it since I have already hit rocks under there and the other parts are tired or worn I could spend a little extra and upgrade while I’m at it.
  13. Feb 26, 2025 at 12:50 PM
    RichochetRabbit
    If you can justify it, feel free. Catalytic converter guards, though.
    baboltin[QUOTED][OP] likes this.
  14. Feb 26, 2025 at 12:54 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    I appreciate the advice and will look into those from rci. I know a lot of people will say why are you doing all this work, blah blah blah but I need new shocks and leafs so I’m upgrading while replacing. I’m not replacing new shocks off of a truck with a few thousand miles I’m replacing shocks, leafs that are beat after 85k plus miles. I understand i could get the bare minimum but that isn’t my style I like to improve on things within reason. I wouldn’t go spend 3-4K on shocks but a couple hundred extra over it for a better set up I think it’s worth it.
    Spuds509 and t0p_d0g like this.
  15. Feb 26, 2025 at 1:00 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    Hoping to get some insight and experienced knowledge on these questions from individuals that know and have experience.
    QUESTION- is zero offset for wheels the best route or offset to pick ?
  16. Feb 26, 2025 at 1:01 PM
    baboltin
    Brad
    Tehachapi,Ca
    2019 Toyota Tacoma
    No I would like to know if the set up I built will work out and work properly. I can give two shits of your negative opinion.
  17. Feb 26, 2025 at 1:10 PM
    FunknNasty
    FunknNasty Well-Known Member
    San Jose
    2022 Pro
    Buck, I love you man, but….
    The Op appears to have been around awhile, and more to the point, has had his truck for awhile. It's not like he's new to TW and just bought his 1st Tacoma with its $40k+ price tag. -cheers!
    Go OP! :)
  18. Feb 26, 2025 at 1:21 PM
    airforceb2cc
    Don
    KCMO
    I would get new lugs for the black rhinos...yes
    You should not rub at all, even at full stuff.
    I'm more of a -15 offset guy but I have cut fenders and a CMR running 37X13.50R17s when I wheel so I need to keep the tire off the UCA. 0 with skinny 33's will stay inside the flare and you will have plenty of room to clear the UCA and cab mount.
  19. Feb 26, 2025 at 1:22 PM
    Buck Henry
    You're right, I am out of line. Apologies OP! I am kind of a financial guru and thus hate seeing people waste money. In this case I guess it's justified. Carry on!
    Taco23SR, RushT, baboltin[OP] and 3 others like this.
  20. Feb 26, 2025 at 1:26 PM
    Lsears558
    Lsears558 Member
    Landon
    2021 MGM Tacoma trd off road
    zero offset is the way to go. that is what my wheels are and i have 33's. i barely rub so you should be plenty fine with that tire size. i would also get lug nuts just incase the stock ones dont fit your new wheels.
