for those that have installed cruise control on a Non Pre-wired tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JEA86, Jan 10, 2013.
  1. Jan 10, 2013 at 7:20 PM
    JEA86
    JEA86 [OP] Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    i am trying to get a grasp on this install i am not super familiar with wiring so i was hoping those that have done this could give me some insight.
    The Cruise control stalk i have is for the tacoma, the wire that plugs into the clock spring terminal just has 2 wires connected to it, it does not have the ground attached (this looks to be my first issue)
    So the next issue i am having is with the clutch switch, i bought the "hardware kit" from brandon distributing but it does not have the "clutch switch wiring harness" from what i can tell so i am not sure if i can actually get that harness kit seperate or if there is a way around it.
    These seem to be my only 2 issues, i have everything else to do this swap even the side piece for the cruise from toyota.
    Any input here would be much appreciated!
  2. Jan 11, 2013 at 5:02 PM
    JEA86
    Jeremy
    WV
    2016 TRD Off-Road
    anyone?
  3. Jan 27, 2013 at 8:35 PM
    W4RWF
    W4RWF Member
    Russ
    Eastover, SC
    reg cab 4x4 5 spd
    JEA86. I too am getting ready to order the parts and do an install with a manual transmission. Here is a link that i found that may clear it up for ya. http://www.toyotanation.com/forum/61-2nd-generation-2005/171992-diy-oem-cruise-control.html
    look at about the 7th picture down and you will see the clutch switch connector. it's already there, just remove the tape and pull it loose. I just went out and looked at my 2013 reg cab and that exact same connector is there just as pictured in the aforementioned post.
  4. Jan 28, 2013 at 6:41 AM
    Bill in Ky
    Bill in Ky Well-Known Member
    Bright White 08 Reg 4X4 2.7 5spd SR5
    I got my first 4x4 in 1972...haven't been without one! I still like Chrome!
