? for those w/ ext travel 5100's(BE5-110)
Discussion in 'Suspension' started by Zac808, Apr 26, 2012.
  1. Apr 26, 2012 at 9:55 AM
    Zac808
    Zac808 [OP] Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    What are you guys using for extended bumpstops?
    I've read to use a lift block on the topside of the leaf. What size block?
    If you gerry rigged yours, post a pick so I can get an idea.
    Gonna throw my shocks on, but wanna make sure I have all the parts for the bumpstops as well.
  2. Apr 26, 2012 at 10:01 AM
    nfs257
    nfs257 Well-Known Member
    Menifee, Ca -> Tucson, Az -- April
    09 DCLB PreRunner MGM SR5 Debadged
    Trac Performance built Prerunner
    UH... Im not running any bumpstops... :eek:
  3. Apr 27, 2012 at 2:19 AM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I had some 1/4" flat steel laying around and cut 4 (per side) 2.5" long plates to put under the bump stop (2 on each side of the leaf bolt)! Kind of ghetto but raised the bumps 1/2" and also have superbumps so they compress to stock height but have 1.5" of softer compression before they bottom out! I think AP's u bolt flip plate is 1/4-1/2" thick and could be used as well!
  4. Apr 28, 2012 at 2:53 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I guess I could remove my overload leaf, shorten it up a bit and throw it under the bumpstop plate.
  5. Jun 24, 2012 at 5:22 PM
    greenrustic
    greenrustic Well-Known Member
    NY
    2012 DCLB 4x4 TRD SPORT
    Access LTD Tonneau Cover, Weather Tech Digital Fit Mats, Weather Tech Rain Guards, 35% Tint up Front, AFE Dry Power Intake Filter, Debadged, GrilleCraft, OME 884x, OME 9000 NitroChargers, Icon 3 Leaf Progressive AAL
    Bump because I am trying to find info about this too.
  6. Jun 24, 2012 at 5:25 PM
    Zac808
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    Im still rockin the factory bumpstops. No problems here.
