For those w/ P0420 code
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Vince05Taco, Jan 2, 2020.
  1. Jan 2, 2020 at 6:21 PM
    Vince05Taco
    Vince05Taco [OP] Member
    Vincent
    05 Tacoma
    Swapped my spark plugs, and goodbye check engine light. Everybody say ‘goodbye check engine light!’
    Bye!
    V6 Engine over here. Also I just used spark plugs that are for a lawnmower. jk
  2. Jan 2, 2020 at 6:51 PM
    KickAss
    KickAss Well-Known Member
    Chuck
    Florida
    2015 Limited 4x4 DCLB
    Big body sittin on chrome
    Goodbye check engine light! Yea the smaller spark plugs are cheaper, whatever fits
  3. Jan 4, 2020 at 4:18 AM
    Wattapunk
    Wattapunk Stay lifted my friends !
    Uncle K
    TX
    2005 DCLB 4WD
    Welcome to TW. ..
    A P0420 code is usually not spark plugs related error. It's likely a failing O2 sensor or cat. Don't be surprised if it comes back.
    12TRDTacoma and Vince05Taco[OP] like this.
  4. Jan 4, 2020 at 5:17 AM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    I thought that code came on when it was time to buy a bag of weed?
    But seriously, it will be back....
  5. Jan 4, 2020 at 7:29 AM
    JustAddMud
    JustAddMud Professional Grease Monkey
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    Yup what he said, I wanna say that one is the drivers side (v6) and p0430 is passenger side (v6). I'm feeling too lazy right now to google it. The fact that changing the spark plugs removed that code just tells me that your cats are right on the brink of failing. You can get ahead on it by removing your o2 sensors and cleaning the carbon off of them and plop them back in. That should get you some more time on those sensors before the code comes back.
    -J
    Vince05Taco[OP] likes this.
  6. Jan 4, 2020 at 1:48 PM
    fixnfly
    S.W.PA
    After mine failed, I took it to a local scrap yard that pays well for converters. The guy looked up the numbers and it fell under a category called "LOW GRADE FOREIGN ". Toyota makes them to last up till the warranty is up. Still got $30 for it !!
  7. Jan 4, 2020 at 1:55 PM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    For your cats? I got 40$ each for mine. That was a few years ago though. I got more for the Cats than the 700lbs of scrap, lol.
    -J
  8. Jan 4, 2020 at 3:00 PM
    fixnfly
    S.W.PA
    I also took in a smaller cat off of a civic and got $60 for it. :thumbsup:
  9. Jan 4, 2020 at 7:01 PM
    Vince05Taco
    Vincent
    05 Tacoma
    One plug was loose, so maybe that coulda caused the code? Not loose, but def not tight tight. Ez to pull out with socket wrench
  10. Jan 5, 2020 at 9:52 AM
    Vince05Taco
    Vincent
    05 Tacoma
    Yep, y’all called it. CE light back on. I have the seafoam spray to clean them. Do you know if the o2 sensors need to be dried well before I reinstall them?
  11. Jan 5, 2020 at 9:53 AM
    Bishop84
    Bishop84 Well-Known Member
    You need a catalytic converter.
    eon_blue likes this.
  12. Jan 5, 2020 at 10:06 AM
    Vince05Taco
    Vincent
    05 Tacoma
    What I need is money, so trying to hold off on a catalytic converter otherwise I wouldn’t be in here.
    Thyces likes this.
  13. Jan 5, 2020 at 10:20 AM
    MGtaco2.7
    MGtaco2.7 MEMBER
    NW Ohio
    18 DCSB 4X4 SR5 Silver Sky Metallic V6 AT
    I'd spray sensor let it dry a little and reinstall. If the CE light doesn't bother you don't worry about it. If it starts to run like shit, then weigh your options then.
  14. Jan 5, 2020 at 10:26 AM
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Do you have a bore scope?
    When I did my a/f and 02 sensors I could see the ends of the cat with the scope.
    I did the 02 cleaned and dried and also disconnected the battery for like an hr.
    Code returned I replaced both sensors on my 4 banger.
    Cleared codes again it’s been good since.
  15. Jan 6, 2020 at 4:26 AM
    JustAddMud
    J
    Summerville SC
    12 4x4 TRD OR
    Yes
    I plan on using either a spritz of MAF cleaner or carb cleaner on the plugs before I reinstall them. They'll dry fairly fast just sitting out, I'll wipe them with a shop cloth prior to reinstalling them. Additionally, I plan on doing the Spark Plug Non-fouler mod prior to reinstalling my sensors. As a side, my configuration isn't stock hence the route with the non-foulers to fix my issue.
    -J
