For those with a LSD rear......
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chris4x4, Jul 14, 2008.
  1. Jul 14, 2008 at 11:59 AM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Have you changed the oil your self? What oil did you use?
    Im courious, as I changed mine with Mobil 1 75w90 and used some LSD addative the dealer gave me. I developed a horrible groaning noise when turning. I changed the fluid again, using Mobil 1 formulated for LSD's, and the groaning became WORSE. :confused: Puzzled, I went to the dealer, and used their 80w90 with LSD addative, and all is nice and quiet now. I have never run into a rear LSD that didnt seem to like Mobil 1, and I would like to know what athers have used, or have had the same experience.
    Thanks. :)
  2. Jul 14, 2008 at 12:41 PM
    tacoskim
    tacoskim Tuned By Gadget
    Los Angeles, CA
    09 TRD 4x4 Pyrite Mica
    Stock
    i take mine to get service at the dealer.. i know its a couple bucks more but its worth it to have the warranty. i will be having toyota replace my LSD fluid during my service later this week
  3. Jul 14, 2008 at 12:44 PM
    klown
    klown Tacoma World Ring Leader
    Lynchburg, VA
    2008 TRD sport 4x4 double cab 6-speed
    Black, leather and heated seats, borla sport exhaust, side curtain airbags, daytime running lights, all weather mats, JBL premium 6 disk changer system, stainless step tubes, window tint, tow package
    What's the maintenance schedule for replacing LSD fluid?
  4. Jul 14, 2008 at 12:50 PM
    Johnson8537
    Johnson8537 Well-Known Member
    Oregon
    06 TRD SPORT 4x4 Double Cab Long bed
    Revtek Leveling Kit with 1 1/2 block spacer in rear. 17" MotoMetal blacks on 32" tires. Access Lorado Tonneau - Bed mat Billet Grill Tinted Windows Pioneer 700BT with PAC steering wheel inerface. Wet Okole Seat Covers Front and back.
    30K
    I have Valvoline synthetic blend with addative
    NO isses
  5. Jul 14, 2008 at 3:36 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I can't speak for the tacoma.... but from other vehicles with LSD's I've experienced...
    The additive is supposed to cause the LSD to slip (on purpose). If you don't have additive in there or if you don't have enough....the LSD clutches will 'grab' too much causing all sorts of problems/noises. If that's the case - you're supposed to be able to add more additive to queit things down.
    Also...after changing the oil with the additive, you're supposed to do several TIGHT (full lock) 8 turns in both directions. This is supposed to get the oil & additive mixed thoroughly and mixed within the clutch paks.
    My husband and I have used Amsoil Severe Gear lube in our vette. That's got the LSD additive in it. Been working great...
  6. Jul 14, 2008 at 6:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have a couple of other vehicles with LSD's. I have never had a problem with them running the Mobil 1 oil and lsd addative. I was supprised that the new Tacoma lsd's were that sensative to gear oils. A few guys on TTORA had the same problem, and when they used the Toyota oil, the problem went away. Just thought it was a little strange, as I have delt with LSD's from Chevy, Dodge, Porsche, and never had this problem before.
  7. Jul 14, 2008 at 7:13 PM
    Demoncleaner
    Demoncleaner Well-Known Member
    Upstate NY
    05 Dcab 6spd 4x4 TRD Sport w/Tow
    TRD exhaust Homemade bed mat & bed extender, front Drings, Short clutch throw, Summer: Stock 17's Winter: Blizzaks on 16' black steelies
    Same here. 80w-90. No friction mod. Works great, never chatters. Over past 3 yrs read some who were ok, but many who ran 75w-90 full syn and had issues.
    Go cheap. Dino or at most syn blend. Full syn rest of truck if you wish.
