For those with After market UCA's (Camburg, TC, All Pro)
Discussion in 'Technical Chat' started by chris4x4, Feb 15, 2009.
  1. Feb 15, 2009 at 10:07 AM
    chris4x4
    chris4x4 [OP] With sufficient thrust, pigs fly just fine. Moderator
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    DO NOT USE A PETROLEUM BASED LUBE ON THE UNIBALL.
    I dont care what anyone says, this causes much more harm than good. the lineing in the Uniball cup is Tefflon. Petrolium based lubes will carry fine dirt particles into the cup, and it will wear out FAST. Use a Dry Lube, like Tri-Flow, or some other quality Tefflon dry lube.
    lynyrd3 likes this.
  2. Feb 15, 2009 at 11:00 AM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Great wisdom as always. Thanks Chris. :cool:
  3. Feb 28, 2009 at 1:44 AM
    Y0TA
    Y0TA Well-Known Member
    Zac
    Central MT
    05 BLK TRD Sport 4X4
    good to know. i just got in on the GB for some TC. thanks chris. you da man!
  4. Jul 10, 2009 at 3:15 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    just saw today that lowes carries a teflon dry lube made by dupont. picked me up a can today
  5. Jul 10, 2009 at 4:15 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    That stuff is awesome. I use it to lube my cams and carabiners on my climbing rack, and it always works like a charm.
  6. Jul 10, 2009 at 4:20 PM
    Brunes
    Brunes abides.
    Rotorhead
    Damn it- I was at Lowes today....
  7. Sep 27, 2009 at 9:24 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    55w HIDs, 16" Countersteer Offroads, Yokahama All Terrains, Demello Sliders
    How do I know when my UCA's need lube? I had a squeaks coming from my life springs but now theres a higher pitch squeak thats coming from up front. Just got my UCA's on this week, but also went offroading this morning and its starting acting up after. Also, how do I lube, just put the lube on the uniball?
  8. Sep 27, 2009 at 9:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    What UCA's are they?
  9. Sep 27, 2009 at 9:29 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    Total Chaos
  10. Sep 27, 2009 at 9:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    When you installed them, did you rub grease all over the bushings before instalation into the UCA?
  11. Sep 27, 2009 at 9:31 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    I didnt installem, I had a shop do it. Damnit. I wish I was genius like you chris, I could just install my own shit and make sure everything is done right
    lynyrd3 likes this.
  12. Sep 27, 2009 at 9:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL, Dont worry. Are you good with tools?
  13. Sep 27, 2009 at 9:34 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    Not sure what you mean by good but Ive been trying to do my own work lately, at least what seems "doable". I can work a screwdriver and a socket wrench. Dont have an impact one tho.
  14. Sep 27, 2009 at 9:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ok... What Im going to tell you to do is pretty easy. If you are uncomfortable doing this, get a friend to help, or a Member in your area.
    Jack up the front of the truck, and position a jack stand under the frame. Remove the front tire. Loosen the UCA bolt. Its the long one that attaches the UCA to the frame. After the UCA bolt is loose (do not remove the nut), pump some grease into the bushing. both sides. Then, Tighten the bolt to 90 lb-ft. Do the same for the other side, and see if that fixes the squeak. :)
  15. Sep 27, 2009 at 9:41 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    sounds pretty easy to me. definitely will do tomorrow evening when I get home from school. BTW, Im guessing I would need an impact wrench to get it to 90Lb-ft?
  16. Sep 27, 2009 at 9:42 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    With a 1/2" drive socket wrench, you should be able to get it. You'll need a wrench on the other end to make sure it doesnt turn. Like I said. If you have any doubts, get someone to help ya.
  17. Sep 27, 2009 at 9:47 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    Alright, thanks chris. Ill keep you updated.
  18. Sep 27, 2009 at 9:48 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  19. Sep 28, 2009 at 12:10 PM
    dysfunctnlretard
    dysfunctnlretard Hi
    Manny
    CA
    2010 FJC
    anybody know what kind of grease I need for the bushings? Or should I be using the same lube that goes on the uniball?
    opteron likes this.
  20. Sep 28, 2009 at 1:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I use Mobil 1 grease.
    opteron likes this.
