For those with single batteries.....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Icepuck72, Sep 16, 2019.
  1. Sep 17, 2019 at 8:29 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Thanks! Just what I needed. Do you have the discount code handy? Winter's coming and my OEM battery is almost 6 years old. Might be time to jump to the Northstar
  2. Sep 17, 2019 at 8:31 AM
    941tech
    941tech Well-Known Member
    Advance auto also does online ordering and discount codes. Usually RMN25 (retailmenot25%) is what I use. If you have "speedperks" coupons you can stack them on top of the discount when ordering too. Everyone should keep in mind that there are just a few battery manufacturers and they produce many things under different names. For example, Johnson Controls makes Walmart batteries, Optima, Interstate, etc. Don't quote me on it as I don't stay up to date on it. However, I can say that they were sold to a venture capitalist firm in 2018... meaning that things are about to get super shitty when profit is put ahead of quality or reputation. Hold on to your receipts! Haha.
  3. Sep 17, 2019 at 8:32 AM
    Muddinfun
    Muddinfun Well-Known Member
    It's on the Batteries+ website. A big splash that jumps out at you.
  4. Sep 17, 2019 at 8:35 AM
    Muddinfun
    1 more thing. When you order online, it will charge you the core charge. When you take in your junk battery and pick up your new battery, you give them the same card you used, and they correct the total.
    MolonLabeTaco likes this.
  5. Sep 17, 2019 at 8:39 AM
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Thanks for the good info and help!:thumbsup:
    Icepuck72[OP] and Muddinfun like this.
  6. Jun 18, 2020 at 6:35 AM
    NH Baker
    NH Baker Member
    Nick
    Vermont
    2019 TRD Pro Auto Black
    Mountain Hatch Prinsu cab and cap rack Total Chaos Fabrication bed stiffeners ARE Cap Goose Gear 100% rear seat delete MESO third brake light, stage 1 tail lights, interior lights, turn signals Dometic CFX35 Fridge MLO Front Center Bumper MLO Sliders Warn m8000s winch Factor55 recovery items Falken Wildpeak 265/75/16 RoadShower Medium Roofnest Sandpiper MaxTrax
    New guy and definitely not an electrical savvy person. 2019 Taco Pro. Just bought a X2 (Northstar) 27F AGM. Intend to run my Dometic CFX 35W on it. Gonna hard wire (10awg from battery) a voltmeter/outlet in the bed to plug the fridge into. Will have an in-line fuse.
    Any concerns I should have about running my fridge while the truck is off? My “battery guy” buddy is convinced this is a terrible idea and I’ll be left stranded with a dead battery
    MattCowsmasher likes this.
  7. Jun 18, 2020 at 6:38 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    Have a better suggestion that's been around for years:
  8. Jun 18, 2020 at 6:39 AM
    MattCowsmasher
    MattCowsmasher ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Temple, Tx
    O3 Rubicon wrangler
    The dometic will have a Low voltage Cutoff so it’ll leave you enough power to start the truck but I’d highly recommend investing in a quality jump starter from a reputable brand like noco just in case.
    NOCO Boost Plus GB40 1000 Amp 12-Volt Ultra Safe Portable Lithium Car Battery Jump Starter Pack For Up To 6-Liter Gasoline And 3-Liter Diesel Engines https://www.amazon.com/dp/B015TKUPIC/ref=cm_sw_r_cp_api_i_9526EbXSZ0KWE
    NH Baker[QUOTED] likes this.
  9. Jun 19, 2020 at 8:12 AM
    Dometic
    Dometic Well-Known Member Vendor
    2016 Tacoma
    Like @MattCowsmasher mentioned, the battery protection on the CFX should be set to high or medium with a single battery set up given you'll have a direct wiring set up. Before going out to the woods, load the cooler like you plan to have on your trip, and experiment in your driveway where you can jump it if needed. The load coming from a CFX35 won't be a lot, but the type of battery you have, it's age, parasitic draw from other parts of your vehicle's system will all contribute. Trying it out and developing a "feel" for everything in your driveway will increase your confidence so you won't be surprised out on the trail.
    DOMETIC
    mobile living made easy
    shop.dometic.com
    Use promo code TacomaW20 for $25 off your order of $75+
  10. Jun 19, 2020 at 8:15 AM
    MattCowsmasher
    Temple, Tx
    O3 Rubicon wrangler
    :fistbump:I’ve got the CF80 and cover great product you guys make.:thumbsup:
    Dometic[QUOTED] likes this.
