For those with TSB AAL:
Discussion in 'Suspension' started by roxspin72, Jan 30, 2009.
  1. Jan 30, 2009 at 4:08 PM
    roxspin72
    roxspin72 [OP] Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Any problems installing the toytech AAL to your four pack TSB Leafs. Will I need the longer U-Bolts. I looked under my truck and there is not that much thread showing past the nut.
    Need some assurance and advice wether I need to puchase these..
    Thanks.
  2. Jan 30, 2009 at 4:15 PM
    jhodge83
    jhodge83 They all float down here... Moderator
    SC
    17 XLT Sport
    3rd gen forum caused me to get a Ford
    u should need the longer u-bolts. should be included w/ the AAL though, right?
  3. Jan 30, 2009 at 4:20 PM
    roxspin72
    NC
    Oh Yeah!!!
    I saw center pin included, not U Bolts. Saw them on ToyTech site for like 39.99...
    Kind of confused. I read somewhere to never reuse the U Bolts:confused:
  4. Jan 30, 2009 at 4:29 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Kaplan, Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners.
    I have reused u-bolts in the past without incidence. Normally I leave about a 1/4" thread below the nut, just to be on the safe side.
  5. Jan 30, 2009 at 4:34 PM
    roxspin72
    NC
    Oh Yeah!!!
    See, thats my concern, I got about a 1/4" now, so imagine one more leaf.
    Hey JHODGE, remind me to show you tomorrow.
  6. Jan 30, 2009 at 4:36 PM
    jhodge83
    SC
    17 XLT Sport
    u can get a set of u-bolts from autozone and all, but make sure that they are the right length. i'd definately run e wones if they are barely out of the nut
  7. Jan 30, 2009 at 4:53 PM
    IB Slingin
    IB Slingin Well-Known Member
    I just got the OME 3" lift kit with the AAL for the TSB springs and the kit came with the center pins only. NO U-bolts.
  8. Jan 30, 2009 at 5:24 PM
    jhodge83
    SC
    17 XLT Sport
    my pro comp AAL from EZ lift had the u-bolts w/ it
  9. Jan 30, 2009 at 5:36 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    If you had the TSB done, and the U bolts are not 1/2" or more thread showing, the dealer re used the old U bolts. They tried this shit with me, and I demanded the new U bolts. I had to go back and get them. As for the AAL install, its easy, just make sure the ground your on is level, and the front wheels are chocked.
  10. Jan 30, 2009 at 8:06 PM
    Neubs
    Neubs Sold my Tacoma. Goodbye TW.
    Maryland
    06 TRD Offroad DC 4X4
    ToyTec 5100 Bilstein Adjustable Coilovers w/ Eibach Springs | OME Darkar Leaf Springs | 5150 10" Bilstein Rear Shocks| Light Racing UCAs | All Pro U-Bolt Flip Kit | Timbren Rear Bumps | Extended Stainless Steel Rear Brake Lines | ARB CKMA12 On-Board Air Compressor | Method 16" Race Wheels | Goodyear 285/70/16 MTR | 48" Hi-Lift Jack | ToyTec Diff Drop | Warn Hitch Shackle | TRD Cold Air Intake | PIAA Intense White Bulbs | PIAA Silicone Wipers | Toyota Bed Mat |Sockmonkey Graphics | 20% Tint | Sport Hood | Scan Gauge II & Blend Mount | Shrockworks Sliders | ARB Bumper | Warn M8000 Winch | Viking Synthetic Winch line | 12-Volt Guy In-Dash Winch Controller | Viking Delrin Rollers | Daystar Winch Isolator| ARB/IPF 900XS Lights | Weather Tech Liners | Rock Lights | Diff Breather Mod | Extra Bed D-Rings | Misc. LED bulbs throughout
    I have done this (AAL w/ TSB install) twice and it is not difficult at all. Yes, you have to reuse the U-Bolts but like others have said if you have had the TSB done they should have installed longer ones for you. Mine are a good 1/2" past the bolt. The center bolts are included with the AAL.
  11. Jan 30, 2009 at 8:38 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    I had a shop install my AAL from ToyTec and didn't need new longer Ubolts.
  12. Jan 30, 2009 at 8:41 PM
    jhodge83
    SC
    17 XLT Sport
    but u probably didnt have the 4 leaf tsb pack either, right?
  13. Jan 30, 2009 at 8:48 PM
    roxspin72
    NC
    Oh Yeah!!!
    Yeah, I'll measure again tomorrow, and double check with JHODGE. As far as dealer error, I doubt it, the bolts are brand spankin new...
    Just dont want to spend $40 on something I dont need, and then again, dont want to be empty handed when it comes to install.
    Thanks to all for the input though.
