Force Clearing Learned AT Settings
Discussion in '3rd Gen. Tacomas (2016-2023)' started by .jake, Sep 14, 2017.
  1. Sep 14, 2017 at 5:15 PM
    .jake
    .jake [OP] Ex-Lion Tamer
    Discharged from the Whale’s Vagina into Mesa, AZ
    0x07E1 4x4 DCLB TRD Sport
    2" Lift on 16x8 -12 SCS Ray 10's w/ 265/75 Wildpeaks
    Is there a for-sure way to wipe the "learned" AT settings? I see the OVTune thread talk about how after loading the tune it's better but they can't (without problems) stop the learning from creeping back in. But without a tune to load how can this be cleared?
    I would think Toyota has some unlikely-to-be-guessed sequence for their Techs to do, like most all electronics these days, there's some button press or process to do hidden things.
  2. Sep 14, 2017 at 5:32 PM
    Baerskin
    Baerskin Rocking in the Free World
    Manitoba
    TRD Sport Premium 4x4
    Stock
  3. Sep 14, 2017 at 5:52 PM
    peppinoss
    peppinoss Well-Known Member
    Los Angeles
    2016 TRD OR 4x4
    ToyTec Boss 2.0 lift TRD Pro Wheels 265/70/R17 KO2s Mobtown Offroad Sliders
    techstream. buy the cable off ebay. i have started clearing my trans every few thousand miles
  4. Sep 14, 2017 at 5:55 PM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Some people say disconnect the battery for about a half hour.
  5. Sep 14, 2017 at 6:10 PM
    .jake
    like this?
    Maybe you could explain the process? 30,000' overview?
  6. Sep 14, 2017 at 6:43 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    You need a windows laptop, install the "cracked" software that came on the CD (or download from net) info on tundrasolutions on all the install nuances. Plug laptop into truck, with cable, run the Toyota diagnostics software, Techstream. Its the same stuff the dealer uses. Lots of stuff to play with.
  7. Sep 14, 2017 at 7:05 PM
    .jake
    Ok, maybe it's easier than I thought. Hopefully there's a clear shit option. Thanks.
  8. Sep 14, 2017 at 7:25 PM
    mutely
    It's super easy, but can be a painful driver & software install. There is a large thread with everything you need to know on tundrasolutions, read that first and see if it's for you. Think I paid $15 from Amazon for the right cable, so not much of a loss if you giveup on it.
    Edit,
    This is the one I use, but the CD had a bunch of unneeded shit on it, so I didn't trust the ccontents and downloaded the software from one of the links in the thread mentioned above
    https://www.amazon.com/gp/product/B00W97K7O6/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
  9. Sep 15, 2017 at 11:19 AM
    toytec2
    toytec2 Member
    2017 Tacoma 2wd sport
    My personal black out Pro shift knob TRD exhaust TRD CAI Bed Extender.
    If you just want to dump all learned / adapted memory disconnect the negative battery cable and connect it to the positive cable for about 30 seconds. Yes this is a factory approved method.
  10. Sep 15, 2017 at 11:23 AM
    Goochwarmer
    Goochwarmer Well-Known Member
    2017 Tacoma TRD Off Road MT
    Yes, by watching and asking the tech while I was there. Take the battery leads off and hold the Pos and Neg together for a minute
  11. Sep 15, 2017 at 11:35 AM
    gamason
    gamason Well-Known Member
    Randy
    2017 F-150 Eco Beast
    My only question is "why"? If you clear the learned behavior and the same driver gets behind the wheel, it will learn the same "bad" behaviors. Perhaps a driving class or two before you reset it and learn better driving techniques, it might work better. Just food for thought!!
    Goochwarmer likes this.
  12. Sep 15, 2017 at 11:54 AM
    Goochwarmer
    Actually I have an answer for "why"...the system is learned by the driving of the individual. When I started driving it I was concerned about fuel mileage and was very light on the accelerator, like eggshells under the pedal. The tech told me driving it like that may have made the computer think I was a wuss and didn't get aggressive so when I would hammer down the accelerator didn't react accordingly. He reset and told me to drive aggressive to see if the computer learned differently. This relates to the "Oh Shit" thread where the truck stalls on aggressive acceleration...turns out it isn't a computer issue but truck issue but we were testing a theory.
    gamason likes this.
  13. Sep 15, 2017 at 11:59 AM
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    Lol
    People have issues with the way it learns... regardless of who is behind the wheel. It "learns" to upshift too early and have you bogging down.
    Resetting it lets it "inefficiently" rev higher and shift later.
  14. Sep 15, 2017 at 12:15 PM
    .jake
    Or perhaps I was going to tow a trailer for the weekend, and just maybe, I thought the truck would do better if it didn't think someone that needs driving lessons was behind the wheel. JFC...
  15. Sep 15, 2017 at 1:01 PM
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    Based on people's experiences, and even maybe mine to a certain extent, I think the term "learning" is a misnomer. Yeah, it's learning how you drive, realizes you're using more fuel and maybe more exhaust emissions, and so after a while it starts to compensate by upshifting early, holding the higher gears too long, etc. Biut it's not adapting the program to drive like you want it, in fact the opposite. I do try to drive for mpg a lot of the time, but find when I want the power, I can access it pretty easily. For example, I rarely accelerate hard off the line, but when I need to, it feels great ... none of the lag people complain about. OTOH, I do drive in the mountains a lot, forcing 5-4-3 downshifts and often using ECT and S3 and 4, and I think it doesn't like that so it's getting lazier in those conditions. Those are my not-so-scientific thoughts after over 37K miles, one trans TSB plus new CPS.
    synaps3 likes this.
  16. Sep 15, 2017 at 2:17 PM
    gearcruncher
    Canadain bumper technician
    Adaptive learning has been around since the mid 1990,s . If you have driven any Chrysler vehicle with an automatic transmission from 1998 and up , you were operating a vehicle with a form of adaptive learning . Back in those days , the programming was more about keeping the driver happy and less concerning about fuel economy .
    With this said , you could essentially train the transmission to shift more aggressive or to the way you liked it to function
    With newer Tacoma,s , Toyota programs the adaptive learning to maintain fuel economy rather than concentrating on how each individual driver believes the transmission should feel .
    Unfortunately , Toyota,s programming eventually reverts back even after a short term memory wipe creating drive ability issues for the person that has to operate the truck on a day to day basis
    dman100 likes this.
  17. Sep 15, 2017 at 2:47 PM
    NerdTaco
    NerdTaco Well-Known Member
    Is there a fuse you can pull that accomplishes the same thing?
    .jake[OP] likes this.
  18. Nov 7, 2017 at 7:52 AM
    .jake
  19. Nov 7, 2017 at 7:54 AM
    prohunter4
    prohunter4 Well-Known Member
    South Ga
    2017 BBP TRD Off Road
    I have driven mine like I stole it from day 1.
