Forced Induction and tuning
Discussion in 'Performance and Tuning' started by sloancallaway, Aug 26, 2009.
  1. Aug 26, 2009 at 5:20 PM
    sloancallaway
    sloancallaway [OP] Well-Known Member
    Sloan
    Spruce Grove Alberta Canada
    Hey Guys I am new to the tacoma world but by no means new to modding vehicals. I am curious as to different options Regarding Forced induction I am familiar to both turbo and supercharged vehicals. I am also curious as to what is being used to the 2009 tacoma with the V6 4.0l what options are available for the trd KIT (LIKE SMALLER PULLEYS, INJECTORS, COOLING ECT) AND WHAT KIND OF GAINS YOU GUYS ARE SEEING. tHANK YOU FOR YOUR TIME
  2. Aug 26, 2009 at 6:34 PM
    Brunes
    Brunes abides.
    Rotorhead
    Check out URDUSA.com and/or PM Gadget@URD on here to get the straightest dope you can about FI and tuning...
  3. Aug 26, 2009 at 6:41 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    Totally Correct!!!:cool:
  4. Aug 26, 2009 at 7:32 PM
    sloancallaway
    Sloan
    with my little gm there is a program on your labtop that you can tune using its called HP tuners is there a program like that for the tacoma where you can tune your stock pcm rather then running a chip or a piggy back system
  5. Aug 27, 2009 at 1:47 PM
    XrunnIT
    XrunnIT Well-Known Member
    Austin, TX
    1GR-GZE X-Runner
    Built Motor by LC Engineering Boosted by TRD
    The 09 model is going to have the support that the 05-08's have. Toyota changed the ECU a bit. So we can't use the ECU controller that is currently being used for custom tuning for boosted applications.
    Here is a quick cheat sheet, i'm sure i'm forgetting some things, let me know and I'll add them.
    Options:
    Tuning - APR X-1 ECU controller
    TRD Supercharger - Eaton MP90 (roots)
    Stock boost 6-8lbs, 10lbs+ in summer, haven't seen winter boost numbers with aftermarket pulleys, but should see as high as 12psi.
    Comes with:
    -425cc Injectors
    -Option of ECU reflash from the dealership.
    -water to air intercooler & front mount heat exhchanger
    Upgrades Available
    - APR X-1 Stage I Kit (ECU controller, exhaust timing gears, 170° T-stat)
    - lots of pulley options (upper and lower)
    - APR 7th injector kit
    - APR 668cc e85 injector
    - Any CAI
    - Exhaust
    - Fuel pump upgrade
    URD MKII Supercharger - Rotex (centrifugal)
    Stock boost of 6-7lbs, pullied up to 9lbs+
    Comes with:
    - Integrated intake system
    - Front mount air to air intercooler
    - 670cc Injectors (non e85)
    - URD Fuel Pump upgrade
    Upgrades Available
    - 2 pulley upgrades
    - Exhaust
  6. Aug 27, 2009 at 4:09 PM
    sloancallaway
    Sloan
    Alright thank you my friend, and that is a pretty fast taco, My little saturn doesnt even run quite that fast... what does your mod list look like man? is that on drag radials?
  7. Aug 27, 2009 at 4:31 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
    Street tires, stock pulley.
    Basically, TRD S/C, X-1, bolt-ons (I/H/E + 7th inj) and a tune.
    I plan on running mid-low 12's this winter. As I have added 3-4lbs of boost. And hope to finally have a set of drag radials
    heheheh
  8. Aug 27, 2009 at 4:39 PM
    XrunnIT
    Austin, TX
    1GR-GZE X-Runner
