Ford Escape Rims on 5 Lug
Discussion in '5 Lug' started by Steveshred, Sep 12, 2013.
  1. Sep 12, 2013 at 2:04 PM
    Steveshred
    Steveshred [OP] New Member
    SR5 4 Banger
    I've got a 2013 4 Cyl 5 Lug with the 15" steel rims. I bought some almost new Ford Escape alloy 16" rims off of Craigslist ($250) that match the 5x114.3/67.1 center bore/12mmx1.5 lug size. I'm thinking of putting 235/70/16 or 245/70/16 tires on the Escape rims. Anyone have recommendations or concerns? Thx!
  2. Jul 14, 2025 at 2:10 PM
    spacetiger
    spacetiger Well-Known Member
    Jerry
    99 Tacoma extra cab
    IMG_4719 (1).jpg lmao
    looking through old threads and saw this from 2013...
    here is my pic
  3. Jul 15, 2025 at 1:21 PM
    TheBigKahuna
    TheBigKahuna Well-Known Member
    Doh!
    Just realized I'm responding to a 12 year old thread.
    Your bore center is 60.1mm so you should use bore spacers to keep the wheels centered.
    Make sure the wheel offset is compatible.
    According to this chart, using a 16" Escape wheel (same specs 2000 - 2015) you will lose 24mm (1") of inside clearance
    Screenshot 2025-07-15 at 16-12-18 Wheel Offset and backspacing calculator.png
    I have 235/70R16 tires on my 2013 AC but I'm using Highlander wheels.
  4. Jul 15, 2025 at 3:05 PM
    spacetiger
    Jerry
    99 Tacoma extra cab
    The 01-12 Ford Escape hub center is 67.1mm, so no need for an adapter on 1st gen Taco - mine is a 1999 model.
    I believe the Taco hub center changed to 60.1mm in 2005 on, so your comment to the OP with a 2013 model from a 2013 posting is spot on.
