ford focus brake lights/cluster
Discussion in 'Technical Chat' started by rab89, Jul 27, 2009.
  1. Jul 27, 2009 at 6:16 PM
    rab89
    rab89 [OP] Well-Known Member
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    hey, my gf has an 01 focus, recently we found that the brake lights were not coming on. they are brighter than normal as the driving lights but dont get brighter when the brakes are engaged.
    we also found that the dash lights have gone out unless you are on the brakes...
    all of the problems seem to be brake related, i'm thinking a relay? what do you think?
  2. Jul 28, 2009 at 10:16 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    help me!
  3. Jul 28, 2009 at 10:22 AM
    bobwilson1977
    bobwilson1977 Well-Known Member
    KaliFORN-I-A
    96 Tacoma 2WD ( pizza delivery model)
    none except for crappy hub caps and floor mats.
    Sounds like one or more of the bulbs might be burnt out. Some brake lights have dual filaments. Check those first. As far as the dash lights... no clue what that is. It could be a short.
  4. Jul 28, 2009 at 10:26 AM
    NAAC3TACO
    NAAC3TACO Middle aged member
    Just east of crazy, NV
    2014 SR5 DCLB 4x4
    Color matched door handles, Weathertech floor liners, bed mat, Durafit seat covers, tailgate clamp, 2016 TRD Sport 17" wheels with Yokohama Geolander AT tires , Toyota exhaust tip, Toyota/Yakima bike rail mount, Toyota wheel locks, Toyota hitch cover, Redline hood struts, unifilter on air pump.
    You might check the brake light switch that the pedal hits when you depress it. Does the third brake light work? If it does, then the switch is working.
  5. Jul 28, 2009 at 10:27 AM
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    Have to checked all the fuses? Always start with the easy stuff first.
  6. Jul 28, 2009 at 10:30 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    checked fuses, all good, i'll go check the third.
  7. Jul 28, 2009 at 10:36 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    third brake light is NOT working. so it's probably the brake light switch?
    which is behind the pedal?
  8. Jul 28, 2009 at 10:51 AM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Yes, it should be a grey and black switch with a black plunger that hits the brake pedal. They usually run about $20.
  9. Jul 28, 2009 at 11:01 AM
    98tacoma27
    Ben
    Not Beech Creek
    should be
  10. Jul 28, 2009 at 11:52 AM
    Reznor88
    Reznor88 Well-Known Member
    Northern California
    '06 PreRunner DC Off Road
    Dash lights went out on my wife's focus and it drove me crazy trying to track down the reason. After ripping the car apart I noticed when I shoved in on the light switch when turning it the dash lights would come on for a second. Something loose in their or a bad connection. Couldn't take the damn thing apart so I just got a new (used) light switch off eBay and everything works perfectly now.
    I've read that the brake lights and dash lights can be effected by one another so it's worth a shot checking the switch.
  11. Jul 28, 2009 at 12:04 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    I know what the problem is....
    really tho, i have no idea..
  12. Jul 28, 2009 at 12:24 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    i guess we'll try the new brake switch first
  13. Jul 28, 2009 at 2:16 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
    Here's a picture of it from autopartswarehouse.com
  14. Jul 28, 2009 at 2:22 PM
    NAAC3TACO
    2014 SR5 DCLB 4x4
  15. Aug 23, 2009 at 8:41 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    Ok to bump this up and get some more help, Still no luck, but the brake pedal switch seems to be working fine, things have changed since last time, here are the new symptoms.
    car is running, headlights are off, the cluster lights are off and come on when the brake pedal is depressed, the brake lights come on, and the FRONT turn signals come on as brake lights.. weird.
    with the car running, headlights on, cluster lights are not on, but come on when the brake pedal is depressed, rear running lights are off and come on when the brake pedal is depressed, again along with the front turn signals coming on as brake lights.
    So, I have checked all the fuses in the car, everything is good, I dont know where to start to find a short, cant tell if relays are good, could a relay be the problem?
    if anyone has some ideas let me know, I have tomorrow off and i want to get this finished.
  16. Aug 23, 2009 at 8:59 PM
    jfr02
    jfr02 Well-Known Member
    2012 dcsb 6spd sport
    i think i would start to look at you brake light bulbs.since they are daul filiment check to see if one of the filiments are broke and touching the other.take one bulb out press the brake and see if the probem is still there.if it is not swap the bulbs from side to side this will tell you if it's the bulb or the socket and wiring.hope that helps alittle
  17. Aug 23, 2009 at 9:05 PM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    would a broken or backwards bulb cause issues with the cluster though?
  18. Aug 24, 2009 at 12:09 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    bump some more
  19. Aug 24, 2009 at 10:50 AM
    rab89
    Ross
    Kelowna b.c canada
    2017 DCLB TRD Sport
    anyone got some info for me today?
  20. Aug 24, 2009 at 8:39 PM
    BlueTaco
    BlueTaco Well-Known Member
    Long Beach, CA
    08 Tacoma Speedwayblue
    had a 05' Focus ST before my Taco, had all sorts of wiring problems with it (hence why i got rid of it) Focus's are well know for their horrible wiring...wish i could help
