Ford Fusion Fog Light Retrofit DIY
Discussion in '2nd Gen. Tacomas (2005-2015)' started by escuimein, Dec 28, 2015.
  1. Dec 28, 2015 at 7:36 PM
    escuimein
    escuimein [OP] Well-Known Member
    I just completed the install of ford fusion fog lights on my taco. Thanks to boltstaco for the idea ( https://www.tacomaworld.com/threads/fog-light-retrofit-done.319008/ ).
    Here is my install...
    Parts Needed:
    1) Pair of 06-12 ford fusion projector fog lights. They are used on many ford products. Mine had part number 9E53-15K200-AA or 6E5Z15200A . Got a pair of new old stock on ebay for $40.
    http://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=6E5Z15200A&_sacat=0
    2) Pair of PVC 4" to 2" reducers from hardware store.
    3) 9006 to H11 wire adapter
    http://www.ebay.com/itm/111195056501?_trksid=p2060353.m2749.l2649&ssPageName=STRK:MEBIDX:IT
    4) Black satin paint. I used Krylon Color Master Satin black paint for the diy shroud. It looks really close to the black plastic area of the grille.
    DIY Steps:
    1) Trim the mounting brackets of the Ford Fusion fog lights. The ford bracket needs to be trimmed in order to fit the Tacoma fog light area. The idea is to use the OEM Ford bracket for alignment and mount of the fog lights.
    2) Trim the PVC reducer to fit the fog light holes on the Tacoma. I also expanded the center hole in order to give the fog light a recessed look.
    3) This is how they fit together.
    4) Sanded and painted the pvc reducer.
    5) Glued together with high temp rtv silicone. They do get HOT!
    6) Light pattern alignment. The ford fog lights use a torx T15 bolt for alignment. I used zip ties to mount them to the bumper.
    7) Final results and comparison.
    boltstaco and 12TRDTacoma like this.
  2. Dec 28, 2015 at 7:41 PM
    Nimble9
    Nimble9 visit squareonecreations.com Vendor
    Lebanon, PA
    2006 4x4 DCSB
    enough to have fun
    Nice writeup!!! Sub'd for future mod!
  3. Dec 28, 2015 at 7:55 PM
    steveo27
    steveo27 Ask me about my weiner
    Pittsburgh
    '11 TRD Off Road & 1992 VW GLI
    The same shit everyone else has.
    Nice. My buddy used a set of those to retrofit his GTI foglights
  4. Dec 28, 2015 at 8:32 PM
    MSU Taco
    MSU Taco More cowbell
    Roger
    Mississippi
    05 DCLB 4x4
    OP any particular model fusion or are they all the same
  5. Dec 28, 2015 at 8:51 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Great job OP! You get a +1 for ingenuity and that beam pattern though! :thumbsup:
  6. Dec 28, 2015 at 9:06 PM
    MSU Taco
    Roger
    Mississippi
    05 DCLB 4x4
  7. Dec 28, 2015 at 10:16 PM
    08TRDOFFROAD
    08TRDOFFROAD Well-Known Member
    Dan
    21' Tundra Platinum & 08' TRD Offroad DCSB 4x4
    Bilstein 5100's w/front's set at 1.75", TRD exhaust, Colormatched grill, Illuminated 4wd selector switch, BAMF Bolt on Sliders w/kickout.
    ManBeast likes this.
  8. Dec 29, 2015 at 3:54 AM
    escuimein
    Updated the original post. I believe mine had part number 6E53-15K200-AA but also saw part number 6E5Z15200A
    They are used on the fusion and other ford products 06-12.
    Here is an example of the one i bought, but way too expensive: http://www.ebay.com/itm/NEW-OEM-LH-OR-RH-SIDE-FOG-LIGHT-LIGHT-LAMP-2010-2012-FORD-ESCAPE-MERCURY-MARINER-/321535806989?fits=Make:Ford|Model:Fusion&hash=item4add070e0d:g:VMYAAOSwjVVVuAxr&vxp=mtr
  9. Dec 29, 2015 at 4:13 AM
    ManBeast
    ManBeast Well Feared Member
    Zach
    Orange Park FL
    2015 DCLB:TOTALED-> 2014 4R TRAIL
    Does this work on 12 to 15 tacos?
  10. Dec 29, 2015 at 4:19 AM
    escuimein
    Not sure if possible and could take some more fabrication. I think the 12-15 taco fog light cutout is way too small to fit the ford fog light assembly. The 05-11 cutout is about 4" - 4.5" and the ford fog light fit snugly after trim out.
  11. Dec 29, 2015 at 7:11 AM
    ManBeast
    Zach
    Orange Park FL
    Sigh.
  12. Dec 29, 2015 at 7:32 AM
    Bishop2Queens6
    Bishop2Queens6 Well-Known Member
    SoCal
    2009 DCSB SR5 4x4
    Icon 2.5 RR/w CDCV 700# springs Front Shocks JBA UCA's Wheeler's Offroad Superbump Front Bump Stops Icon 2.5 RR/w CDCV 4"+ Rear Shocks AllPro Expo Rear Leaf Pack Timbren Rear Bump Stops ARB Front Bumper @Shmellmopwho Rock Sliders w/ Kickout RCI Aluminum Front Skid Plate Prinsu Roof Rack Roll-N-Lock Tonneau Cover CBI Ditch Light Brackets Cali-Raised LED Ditch Lights Cali-Raised Amber Fogs Cali-Raised Flush Mount LED Pods
    Great write up!!
  13. Dec 29, 2015 at 5:35 PM
    boltstaco
    boltstaco Well-Known Member
    eric
    oceanside, ca
    panty droppa
    AFE intake, 3" spacer w blocks in rear
    Good work man, different approach but glad I could help. Looks great!
  14. Dec 29, 2015 at 7:28 PM
    Tacotrd311
    Tacotrd311 Well-Known Member
    Nice job man, @boltstaco actually helped me when I made mine a few months back. I went with the shrouds and it came out nice. Probably will try to sell them in a few weeks as I bought a plate bumper and won't be able to use them once I get it.
    boltstaco likes this.
  15. Dec 29, 2015 at 8:17 PM
    08TRDOFFROAD
    Dan
    How much?
  16. Dec 29, 2015 at 8:24 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I am so doing that! Great write-up.
  17. Dec 29, 2015 at 8:57 PM
    boltstaco
    eric
    oceanside, ca
    panty droppa
    Did you do what I did and dremel off the upper shield of projector? For anyone doing this in future doing that will let even more light out of those suckers. Just a thought
  18. Jan 3, 2016 at 2:06 PM
    Tacotrd311
    @08TRDOFFROAD I will send you a message, don't want to derail the thread.
  19. Jan 3, 2016 at 3:25 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    So are these sealed? Would a clear cover lens be better to be used to prevent the glass from chipping/cracking?
  20. Jan 3, 2016 at 11:05 PM
    TxStVanWilder
    TxStVanWilder The Pale Horse
    Tx
    2013 TRD Sport
    Exactly what I said. I wonder is the GM Trailblazer SS (I used to own one) fogs would work. It's much smaller and similar design.
