Ford help
Discussion in 'General Automotive' started by BlueTaco07, Oct 16, 2011.
  1. Oct 16, 2011 at 4:19 PM
    BlueTaco07
    BlueTaco07 [OP] Super Mod!
    Cody
    Panama city, Florida
    Looking
    My girlfriend has a 2005 Ford Focus zx4, and her key is stuck in the ignition. I unhooked the battery and it came right out. Of course blondie put the key back in before I could figure out what was wrong :rolleyes: . Anyways its the only key that cranks the car so could it possibly be a problem with the chip? Ford says its a 300$ Dollar repair whatcha guys think?
  2. Oct 16, 2011 at 4:58 PM
    Tacoma Mike
    Tacoma Mike 43 Year Toyota Master/ASE Master Tech.
    Southern Maine
    2011 Double Cab V6
    Large Storage Box, 02610 intermittent switch swap, "Hot Wire" Power Outlets, DRL Shut Off, Disable Fob Beep, Disable Seat Belt Buzzers, Parking Light Mod, Battery Tender, 4 Leaf Spring Pack, Rear Headrest Removal, Custom Ultragauge Mount, Factory Tow Package (7 Pin) Rear Diff Mod, Taco Lean Mod
    nope.
    there is an issue with the lock cyl.
    i towed plenty of these.
    If the key won't come out or gets stuck or won't turn we use to take a pair of regular pliers and tap like a hammer lightly on the key. 75% of the time it would release the key or allow it to turn to start the car and have them drive it to the repair facility. I don't remember it going to a recall but i did enough around here to warrant one. Anyway, it needs to be addressed asap. So i'm thinking a new lock cyl and key set with updated parts and maybe some other items that you may not think of.
  3. Oct 18, 2011 at 6:42 PM
    McBride513
    McBride513 Well-Known Member
    Luke
    Cincinnati
    04 4x4 TRD
    Ran into this at work. It could be a problem with the shift interlock wiring. If the comes out when you disconnect the battery, its most likely not the cylinder.
