Ford working with Toyota on a truck???? NOOOOOOO!!!
Discussion in 'General Automotive' started by acdronin, Aug 22, 2011.
  1. Aug 23, 2011 at 12:41 PM
    #61
    mjp2
    Milton Juevo Portimous II
    NJ
    Current: '21 Bronco Badlands. Previous: '06 TRD Access Cab, v6, 6-speed
    I'm still wrestling with my 6.0. Plugged up EGR cooler and oil cooler led to catastrophic failure. Total top-end rebuild with new heads (both were cracked), ARP studs to replace the crap TTY bolts, Black Onyx head gaskets, EGR delete, cooling system filter, etc. and it's been running solid for the last 12k miles.
    Only problem is that the oil cooler is plugging up again. The shiatty design combined with the silica-containing Ford Gold coolant (required or Ford wouldn't warranty the heads) will destroy the engine in under 30k miles.
    I'll be flushing the system soon with an iron scale remover and then a cleaner to remove most of the build-up before swapping coolant to what that engine should have come with -- the extended life coolant recommended by International and used in the 6.0s that they deliver in their own trucks.
    PITA engine that requires a lot of upgrades, but once they're done it should be good for several hundred thousand more miles.
  2. Aug 23, 2011 at 12:50 PM
    #62
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    my friend and I replaced a plugged egr valve on his 03 6.0. F-ing sucked. We ended up doing the EGR delete. He is gonna do the ARP studs later next month.
  3. Aug 23, 2011 at 12:53 PM
    #63
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    You could not give me a 6.0/6.4L. Not worth the massive hassles IMO. There's a reason why every diesel magazine I read talks about entire businesses dedicated to putting Cummins engines in every other fullsize domestic.
  4. Aug 23, 2011 at 12:55 PM
    #64
    mjp2
    NJ
    It's a nightmare. To do it right you either have to pull the engine or remove the cab from the frame. On my truck the cab came off.
    It was an option I was considering, and the route I should have taken.
  5. Aug 23, 2011 at 1:03 PM
    #65
    Lucario Runner
    Robert
    06 Toyota 4Runner
    Yep we pulled the cab off. Took us about a 3 ( we started saturday ended monday night!) days to finish in his dads shop in helotes. Needless to say it was weird to me pulling the cab to do engine work, although it was what we were told to do in order to do the job right. I do remember his dad saying that the cummins was in the wrong truck.
  6. Aug 23, 2011 at 1:05 PM
    #66
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    It's never too late!
  7. Aug 23, 2011 at 1:08 PM
    #67
    ViperJay
    ViperJay These are the voyages...
    El Paso, TX
    05 Radiant Red DCLB Sport 4x4
    URD CAI, DTLT Headers, Vibrant Ultra Quiet Resonator, Aero 2540i muffler, NST Pulleys, URD MAF Calibrator, Icon 2.5 Coilovers , Bilstein 5100s in rear with All Pro 3" Leaf pack, Total Chaos UCAs, 2 Kicker 12" CVT Subwoofers w/Kicker ZX350.2 Amp, JVC KD-AVX77 stereo, ARE Camper Shell, 1 20" LED bar and 2 7" LED bars in front, 4 KC 6" HID Slimlites mounted on Bajarack roof rack, sliders, Cobra 29 XLR CB Radio, Icom IC-207H UHF/VHF Radio, Bed Lighting, Fog light mod, Projector Retrofit Headlights HID 5000k, HID fog lights 4300k, BHLM, LED taillights and turn signals, Glassworks front fenders, Blue Sea Fuse Box, Mil-Spec Battery Terminals, Odyssey PC2150 battery, Satoshi Grill, All-Pro Front Bumper
    So instead of a Ford Tacoma we're gonna see more of a Toyota F-150? Hybrid? :confused:
  8. Aug 23, 2011 at 1:09 PM
    #68
    Tylerm5000
    Tylerm5000 Well-Known Member
    Tyler
    Oregon
    1995.5 2.7l reg cab 4x4 5-speed red pearl
    Alcan stock height 4-leaf springs, greaseable main eye bolts, OME greaseable shackles, all energy suspension bushings, 2-row extra deep radiator, KYB gas-a-just shocks. ALL LED exterior and interior lighting including custom tail lights and blinkers.
    Give me a Hilux-like Tacoma turbo diesel that is 100% compatible with biodiesel and I will be a happy camper. We get 500 miles to a tank in the 2500HD with it and it purrs like a kitten. I hate hybrids. They aren't good for someone like me who has to drive 20 miles on a rural road before I get into real stop and go traffic that hybrids love.
  9. Aug 23, 2011 at 1:10 PM
    #69
    Toyota Tacoma
    Toyota Tacoma Well-Known Member
    Brady
    Kelowna, bc
    dbl cab long box
    Suspension: -Bilistien 5100's all around -Add a leaf -Firestone ride rite air bags Performance: -K&N cold air -Borla cat back Stereo: -Pioneer AVH-X2500BT head unit -Kenwood 1400 shallow mount 12'' sub in custom box -Alpine 1100 amp -Alpine 400 4 channel -4 energy component 6.5's Wheels/tires: -17x9 with 4.5 backspacing XD hoss rims with 33'' bfTreadwright gaurd dogs and spidertrax spacers Looks: -Satoshi grille made by myself -Hood, front bumper, grille, roof, tailgate and rear bumper plasti-dipped. -BHLM -eyelids -matted out tailights -Tacoma bed mat Small mods : -Trailer 7 pin replaced and moved into bumper beside licence plate -Removed mud flaps -Repainted frame/lower a-arms, skid and rear diff/housing with por15 -Led bulbs -Interior lights replaced with blue led's -Beep on lock added
    I'm disappointed in Toyota.
  10. Aug 23, 2011 at 1:24 PM
    #70
    jjew18
    jjew18 the Nightman cometh!
    Alliance Airport
    05 PreRunner SR5
    Added extra awesomeness to its original awesomeness.
    X2, OZ get your facts together before throwing shit.
  11. Aug 23, 2011 at 1:24 PM
    #71
    Johns Taco
    Johns Taco I'm not 4x4, and have an open diff. So i'm 4x1
    Albuquerque, NM
    05 DSM Base SR5 Slug Taco
    Full custom stereo, onboard air compressor, train horns, spacer lift, 30" tires, optima yellow top, rear slider window & tailgate anti-theft mod, pop & lock, class 3 tow hitch, lights in bed, Ultra Gauge, Weather Tech mats, yellow fog lights, camper top, air lift rear airbags, rear diff breather mod, soon to be more...
    The thought of all of this really doesn't sit well with me, this is my first Toyota and been my best vehicle ever. My dads Nissan Titan is awesome, I will be getting one if this goes through.
  12. Aug 23, 2011 at 1:33 PM
    #72
    jjew18
    Alliance Airport
    05 PreRunner SR5
    Why? It's not as if Toyota is going to scrap everything they know and start fresh with Ford at the helm. You are taking the leading American and Japanese auto makers and combining their knowledge towards a new technology. I am a big time Toyota fan, it would take a long time of consistent reliability and quality for me to change from that, but that does mean they can't grow and learn together. Besides, this is on hybrid technologies, you don't have to buy a hybrid (yet).
  13. Aug 23, 2011 at 1:46 PM
    #73
    horwitzs
    horwitzs Well-Known Member
    Seth
    Dayton, WA
    TX Pro
    Supercharger, OME lift w/ LR UCAs, running boards, toolbox, extinguisher mount, skidplate, N-Fab light bar, 40" R.I. LED bar, WO seat covers, TRD intake, Weathertech mats and visors, stubby antenna, hood struts, LED interior lighting, Hella Supertones, and other stuff I'm forgetting.
    I work for a construction company that always works in rural areas, so we are driving a lot of miles off-road every day.
    Last year the higher ups in head office decided it was more in-line with our company values to switch from Dodge 2500 diesels to Ford escape Hybrids. It's been a disaster, these things aren't meant to hold up to this type of use.
    Two people in the company (including me) said we'd pass and collect a monthly allowance to use our personal rigs instead.
  14. Aug 23, 2011 at 11:58 PM
    #74
    acdronin
    acdronin [OP] Well-Known Member
    My understanding is that there is awesome diesel technology that works well in Europe but is banned in the US. I just think the whole thing is bass-ackwards. A turbo diesel would be an awesome choice for a truck who's engine is underpowered anyways.
  15. Aug 24, 2011 at 12:00 AM
    #75
    Konaborne
    Cody
    Kealakekua, Hawaii
    Lifted 00 TRD Off-Road
    Theres huge potential both ways, for win or lose...IMO
  16. Aug 24, 2011 at 12:00 AM
    #76
    acdronin
    Oh jeesh, some knucklehead's bright fucking idea, so of course you guys plow into jobsites like you were in a big Dodge and of course the hybrids are gonna get torn to pieces!
  17. Aug 24, 2011 at 1:50 AM
    #77
    Kelson
    Kelson Well-Known Member
    Kelson
    Honolulu, Hawaii
    08 5-Lug Reg. Cab SR5
    SR5 Exterior/Interior (Color matched Front Bumper, Chrome Grille Surround and Chrome Rear Bumper/Silver Scoshe Dash Kit, A/C Bezel, A/C Vent Surround) LED license plate and white interior lights, Wet Okole Seat Covers, iPad in-Dash, JL CL-RLC, JL 13TW5 sub, JL 500/1 Slash V1 amp, JL XR 6.5 Components, Rockford Fosgate 6X9s in Boxes Front XRunner Coils, DJM Control Arms and Rear 4X4 Leafs, Custom 2" Angled Streetacos.com Blocks Front XR Bilstien Struts and Rear XR Bilstien Shocks, CravenSpeen Antennae, RX-8 Rims w/ Fronts:235/40-R18 Sumitomo HTR Rears:245/40-R18 Goodyear Eagle GT, 35% Tint front windows, OEM Sliding Privacy Glass w/ 5% Ceramic Tint, Flowmaster Super 44 dumped before the axle, URD Short Throw Shifter, Door Sill Protectors, Door Edge Guards, OEM Sport Pedals,The Retrofit Source Morimoto Mini D2S Stage III 35W 5K HID Headlights, OEM Fog Lights w/ piss yellow bulbs, OEM Cruise Control, Porsche 944 Bucket Seats, BeefedTaco Skid Plate, Whale
    x2. Ford's finally getting their shit together, and they do make decent trucks. And toyota makes awesome trucks. So two awesome truck makers making one awesome truck? maybe? or an epic fail.
  18. Aug 24, 2011 at 2:29 AM
    #78
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    x2 to both. ;)
    2nd Gen Tacoma in a Turbo Diesel is my dream truck! :thumbsup:
    I agree ... I'm willing to reserve judgment and wait to see what they come up with ... seems to me there's potential for something decent here. :notsure:
  19. Aug 24, 2011 at 6:34 AM
    #79
    acdronin
    New! in 2017, it's the Tord Facoma!!!
  20. Aug 24, 2011 at 7:19 AM
    #80
    4Wheelin4Banger
    4Wheelin4Banger Supercharged Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Supercharged Silver State Edition 245WHP
    3" OME lift 885s & Dakars riding on 33" KM2s
    I grew up in Milwaukee,WI and now live in Sparks, NV. I have delt with snow for over half my life with out 4x4. In '05 we got six and a half feet of snow on this side of town and seven and a half feet on the other side of town over a two week period when it snowed every day. Chained up the PreTaco put some extra weight in back and away we went.What I love are the people that get a 4x4 to drive in the snow and think "I have 4wd I can do anything". They are the ones that go flying past you doing 70 when every one else is doing 45-50. Then a couple of miles down the road you see them flipped or in the ditch. I hade one almost take me out once. Right after he passed me I saw his rear end get squirly. I down shifted and slowed down watched him do a 540 about 30 feet in front of me before slidding off the road and rolling 2 1/2 times. We got our 4x4 mostly for playing in the dirt, sand and mountains.
