Forest Road Naming Convention
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RobotTheDog, Dec 16, 2022.
  1. Dec 16, 2022 at 12:24 PM
    RobotTheDog
    RobotTheDog [OP] Well-Known Member
    AZ
    21 TRD OR DCSB CEMENT
    All encompassing layer of dust
    So I know I’ve seen an explanation to this in the past but can’t for the life of me find it. Forest Roads that are written vertically within the red box (on a USFS map) are designated for high clearance vehicles. But I know there is additional meaning to it if there are 4 digits and another meaning if a letter is appended to the end. Attached is a random picture of the USFS map near of Sedona. You can see some roads are three numbers, some four, some with a letter. Anyone know the answer? Bonus points for citing your source!
  2. Dec 16, 2022 at 12:28 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    And here I thought the most recently designated road has the highest number. :notsure:
  3. Dec 16, 2022 at 2:24 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
  4. Dec 16, 2022 at 2:33 PM
    snickers
    snickers My new, overpriced heaping pile of shit
    2024 Tacoma Tailhunter 5ft bed Bronze Oxide
    USFS Naming Conventions
    These naming conventions may help you understand the online GIS maps and PDF maps available from USFS.
    Naming is typically recursive based upon road stubs. For instance, if a main road has name "33" then stubs from that road may be, 33A, 33B, 33B1, 33B2, 33C, etc. using alternating designations (letters, numbers). The third level of “33B1” is road 33, stub B, secondary stub 1. The exact choice is of this format is picked by different road engineers. See the image to the right for a pictorial of this concept.
    https://wazeopedia.waze.com/wiki/USA/Forest_Service_Roads
    If you zoom out in your provided map, maybe you can see the base roads.
  5. Dec 16, 2022 at 3:07 PM
    RobotTheDog
    AZ
    Good find on the stub routes. Still not seeing anything on number of digits yet.
