Forgot to Re-tighten
Discussion in 'Suspension' started by Xperivent, Jan 15, 2017.
  1. Jan 15, 2017 at 10:52 AM
    Xperivent
    Xperivent [OP] Well-Known Member
    ‘24 Supersonic ORP & '04 Impulse Red DC OR
    So, forgot to re-tighten after however many miles, nuts backed down U-Bolts slightly and are crooked.
    Should I just be good to get new nuts and re-do the bolts?
    http://imgur.com/a/vEqtf
    Thanks. :rofl:
  2. Jan 15, 2017 at 10:57 AM
    scocar
    scocar Patron of the Farts
    You should not work on your own truck if you are that careless. You are putting yourself, and more importantly the public, at risk.
    DrFunker, EDDO and 303tacoma like this.
  3. Jan 15, 2017 at 12:10 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Good grief man, replace all that hardware and torque them down.
  4. Jan 15, 2017 at 12:12 PM
    DrFunker
    DrFunker Well-Known Member
  5. Jan 15, 2017 at 12:14 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    How does that happen? Did you take a break and just forget about it? I've been careless before, but not with something like u-bolts.
  6. Jan 15, 2017 at 12:17 PM
    DrFunker
  7. Jan 15, 2017 at 12:18 PM
    Xperivent
    You right, fam
    Glad embarrassment is your main goal
  8. Jan 15, 2017 at 12:21 PM
    Xperivent
    Checked the next day after a ~25 mile drive and little offroad, everything was still tight. I don't understand how nuts got past 2 inches if thread, though.
  9. Jan 15, 2017 at 12:22 PM
    DrFunker
    I don't think anyone here is looking to embarrass you. I think people are letting you know that it is not safe and there was potential to do harm to yourself or others.
  10. Jan 15, 2017 at 12:22 PM
    ZachPrerunner
    Southeast TN
    There's no way the nuts could thread down that far if they were installed properly. Sounds like someone has messed with your truck or you got a ghost roaming around your neighborhood.
  11. Jan 15, 2017 at 12:23 PM
    SV134
    SV134 Well-Known Member
    Commerce CA
    Yes, what he said.
  12. Jan 15, 2017 at 12:23 PM
    DrFunker
    Did you use a torque wrench?
  13. Jan 15, 2017 at 12:23 PM
    SV134
    Commerce CA
    They actually will come loose, it's recommended to retighten everything you work on after 50 miles.
  14. Jan 15, 2017 at 12:24 PM
    Xperivent
    Yes, did torque to spec.
  15. Jan 15, 2017 at 12:25 PM
    DrFunker
    Seems like there was some play left, if those came loose.
    Double and triple check after tightening after you drive a bit.
    Shops that change wheels will always tell you to retorque after 25 miles.
  16. Jan 15, 2017 at 12:28 PM
    Pushincaskets
    Pushincaskets Well-Known Member
    High Point, NC
    07 PreRunner DCSB
    4" Maxtrac Spindles, Dakars and extra leaf, SOS Concepts bed rack, Lund tonneau cover, RTT,
    BS if they come loose due to not being torqued and re torqued they WILL thread all the way off of a new u bolt with vibration of normal driving. No corrosion or anything to stop it. Remember U bolts stretch, thus the need to re torque, also the reason you should never re-use u bolts.
    DrFunker likes this.
  17. Jan 15, 2017 at 12:29 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Must have used a harbor freight torque wrench? In all seriousness, people in here praise cheap tools, but I've been around around many people with different torque wrenches, and I've seen a lot of brand new Harbor freight, craftsman, and other cheap brand that were way off.
  18. Jan 15, 2017 at 12:33 PM
    Xperivent
    Torque wrench is my new scapegoat. It was 20 years old with a twist cap that probably has its internals broken.
  19. Jan 15, 2017 at 12:35 PM
    DrFunker
    Glad there was no serious damage OP. I am sure you won't let this happen again. :thumbsup:
  20. Jan 15, 2017 at 12:36 PM
    Xperivent
    Yay learning experiences!
    DrFunker[QUOTED] likes this.
