Forgot to Reconnect the MAF Sensor Cable...
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeezix, Jan 14, 2011.
  1. Jan 14, 2011 at 5:21 PM
    skeezix
    skeezix [OP] The Voice of Experience (mostly negative)
    Colorado
    1998 Limited
    After changing spark plugs I forgot to reconnect the cable and when I fired up the truck it barely ran. Felt like it wasn't getting enough fuel to the engine. Then the Check Engine light came on.
    So I found the dangling cable and reconnected it. Light is still on. I guess it will stay on until something resets it, right?
  2. Jan 14, 2011 at 5:23 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    disconnect the battery for a few minutes, but you could go to auto-zone too and get it cleared there.
  3. Jan 14, 2011 at 5:24 PM
    CopDoctor
    CopDoctor Well-Known Member
    Colorado Springs, CO
    08 335i
    BMS Intake, JB4 chip, Plastidip everywhere
    few minutes = about 10sh :)
  4. Jan 14, 2011 at 6:04 PM
    Rozz
    Rozz Well-Known Member
    Sturgis, SD
    '98 TRD SR5
    Toytec/Eibach 3" coils, 5100's front shocks, Light Racing UCA's, Allpro 3" leaf springs minus 2 leaves, 7100 SB rear shocks, 15x10 slots, Yokohama Geolanders 32x11.5 tires, 4 runner seats
    I did the same thing when I did the deck plate mod. It went away after starting it about 10 times. Many vehicle computers will clear a code if the condition that caused it doesn't reappear multiple times.
  5. Jan 14, 2011 at 7:45 PM
    skeezix
    Colorado
    1998 Limited
    All is back to normal. Thanks for the tips!
