Fork Seals... DIY??
Discussion in 'Motorcycles' started by MotoTacoma, Nov 18, 2010.
  1. Nov 18, 2010 at 6:41 AM
    MotoTacoma
    MotoTacoma [OP] Adrenaline Addict
    Pencilveineeya
    14 tundra crewmax trd
    tacoma sold 11/13/13 Not much on Tundra yet, just Husky Weatherbeaters front and back
    Anyone in here ever change fork seals themselves? When I was younger I always paid the dealership to do it, but they charge quite a bit to do it. I found this video on youtube and I'm thinking of buying the tools and doing it myself... for those that have done it, is it a lot harder than this video makes it look?? Have any suggestions for me??
    (2001 cr125)
    http://www.youtube.com/watch?v=Y43k1qFVGW4?fs=1
    Here is part 2..
    http://www.youtube.com/watch?v=C9ICr-DOmdk?fs=1
  2. Nov 18, 2010 at 6:53 AM
    Pugga
    Massachusetts
    '13 Ford F-150 SCREW
    F-150 Mod
    My dad and I stumbled our way through it once, both first timers. It was an older dirt bike though so I'm not sure what would be different with your set-up. The right tools will make all the difference! It wasn't an overly easy process and there were a lot of 4-letter words uttered throughout, but I'd do it myself again if needed.
  3. Nov 18, 2010 at 7:04 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I just had a buddies mechanic fix my right side one when I bought my bike.
  4. Nov 20, 2010 at 4:43 PM
    MotoTacoma
    Pencilveineeya
    well if i do it i'll post how it went... prob won't order the stuff until after the holidays though..
  5. Nov 20, 2010 at 4:52 PM
    MotoXdoer
    MotoXdoer taco?
    Nate
    San Luis Obispo, Ca
    06 Prerunner 4.0 a/c beast
    k&n cai 63 series intake, blacked out headlights, blacked out tailights, magnaflow pro offroad 17115 dumped, URD competetion y-pipe, total chaos 3.5" long travel, fox 2.5x8" remote resevoir shocks, allied 4" spindles, toytec 2" AAL, 20% tint up front and 5% rear, satoshi grille, ddm 50w 6000k hid's. wet okole custom trd seat covers with heaters. 4:56 nitro gears with arb rd129 air locker, arb ckmta12 dual air compressor.
    get a fork seal driver to install them correctly and tusk seals. fyi they are the same seals as race techs. mine havent leaked yet. i had independent race susp do them twice and the right fork always leaked.....
  6. Nov 20, 2010 at 4:57 PM
    MotoTacoma
    Pencilveineeya
    good info thanks
  7. Nov 20, 2010 at 5:03 PM
    MadTaco461
    MadTaco461 Jack May Hoffer
    Murrieta, CA
    99 turbo 5 lug long travel
    Kinda stock
    they are pretty straight forward, just make sure you don't scratch the shafts. Also check for burrs in them. Get the tool to press in the seals. Takes about an hour the first time around. Good hint, put saran wrap around the shaft to slide the seal on instead of that condom looking thing.
  8. Nov 23, 2010 at 9:35 AM
    GoatFiddyone
    GoatFiddyone Well-Known Member
    Altamonte Springs, FL
    '17 DCLB TRD OR
    I do mine all the time. I use the wrapper from the seal and place it over the end of the fork stanchion. Grease the inner "dish" of the seal and slide it over the wrapper. Pound them in with a seal driver and put them back together. The most time consuming part of it was getting all the oil out. I can do both seals in about 20 minutes with the forks already off the bike. Make sure you clean the inner part of the outer fork stanchion, where the seal will sit.
  9. Jan 21, 2011 at 7:26 PM
    psmcn
    psmcn Well-Known Member
    Paul
    Rockville Md
    Well? Did you ever try to put the seal in??
