Form tail lights work but not doing start up sequence
Discussion in 'Lighting' started by Muerymrl, May 11, 2023.
  1. May 11, 2023 at 11:53 AM
    Muerymrl
    Muerymrl [OP] New Member
    Mason
    Tacoma 2023 TRD OFF ROAD
    Installed some new form tail lights and everything seems to work perfect except no start up sequence Mabey I’m doing it wrong
  2. May 11, 2023 at 11:56 AM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Have you attempted to contact Form to help you troubleshoot? I'm pretty sure they're open until 5pm CST today. 636-748-4444
  3. May 11, 2023 at 11:58 AM
    Muerymrl
    Mason
    Called them no answer left a message
  4. May 15, 2023 at 12:22 PM
    mcdizzle
    mcdizzle New Member
    Connecticut
    2023 Tacoma TRD OR DCLB
    Same issue for me. But it seems to work if the headlights are "on" when I start up, rather than on "Auto." I don't get it....
  5. May 15, 2023 at 1:23 PM
    Muerymrl
    Mason
    They only do the start up sequence if I have the lights in DRL off and switch them to auto or the 2 pictograms above auto. But I feel like as described in in multiple videos and descriptions of the product. It should come on when you “start up” the vehicle.
    Grand Inquisitor likes this.
  6. May 15, 2023 at 2:36 PM
    in2seconds
    in2seconds Well-Known Member
    Edmonton, AB
    2021 TRD Offroad Premium
    Morimotos also have a start-up sequence -- I find that it would take a while for the DRL to turn on without doing anything at truck start up. The start-up sequence would only trigger when the DRL would come on but not the headlamps, i.e. during daytime. If the headlamps turn on as the truck turns on, i.e. during night time if auto headlight is enabled, then the start-up sequence would be overrode by headlights at on position.
    You can manually engage the start-up sequence on truck start by hitting the turn signals -- this would trigger the DRLs to come on, and also engage the start-up sequence.
  7. May 15, 2023 at 6:17 PM
    Rsg83
    Rsg83 New Member
    Same issue, startup sequence don’t work when on auto or if I do automatic start with key fob - I have a 2023 TRD Sport
  8. Oct 25, 2023 at 6:50 AM
    GrEeN WeEnY
    GrEeN WeEnY Well-Known Member
    Aaron
    Behind Enemy Lines, OR
    2023 TRD Sport DCLB, my sixth Tacoma
    Im actually glad to hear this, i was searching for how to disable that
