Fort Worth B.S. Thread
Discussion in 'Texas' started by Kavik, May 23, 2013.
  1. Oct 13, 2015 at 9:08 PM
    #2021
    ThomasMore66
    Dallas/Fort Worth & Durango
    I've got chrome steps, chrome grill, TRD OR wheels and a full TRD OR suspension that needs a new home.
  2. Oct 14, 2015 at 6:28 AM
    #2022
    silvershark2012
    silvershark2012 Member
    Fort Worth, TX
    2012 Prerunner
    How much for each?
  3. Oct 14, 2015 at 6:45 AM
    #2023
    silvershark2012
    Fort Worth, TX
    2012 Prerunner
    :mad:Man literally yesterday morning I just bought some cheap aftermarket alloy wheels on Craigslist just to get me by and replace the stock wheels I had. I wish I would've waited until I read your message.
  4. Oct 14, 2015 at 7:00 AM
    #2024
    elgringoloco
    elgringoloco Well-Known Member
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Anybody up for a meet Friday night the 30th? A friend from CA is coming out and we haven't had one in a while. There's plenty of open parking here for a lot of us, and the bottomless fries are tasty.
    Where: Red Robin
    820 NE Mall Blvd, Hurst, TX 76053
    When: Friday October 30th, 7pm -?
    Who: Anyone that wants to hang out
    Why: Because we can
    richardbui23 likes this.
  5. Oct 14, 2015 at 11:09 AM
    #2025
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Will it be spooky?
  6. Oct 14, 2015 at 1:11 PM
    #2026
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    That's normally the following day
  7. Oct 14, 2015 at 2:17 PM
    #2027
    CowboyTaco
    North Georgia
    11 TRD Sport
    yeah, but what if the party goes past midnight?
  8. Oct 14, 2015 at 2:18 PM
    #2028
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    We all turn into pumpkins
  9. Oct 14, 2015 at 5:58 PM
    #2029
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Gonna make it to this one?
  10. Oct 14, 2015 at 6:01 PM
    #2030
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Yes.
  11. Oct 14, 2015 at 6:43 PM
    #2031
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Dobinsons D59-318 Coil Springs.* Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit.* Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Shocks and Struts.* KPOffroad Alignment Cam Upgrade Kit.* Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler . Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    I'll do my best to show up.
  12. Oct 14, 2015 at 6:49 PM
    #2032
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    If you want to bring the mats then- beers on me.
  13. Oct 14, 2015 at 6:56 PM
    #2033
    Hilborn
    Michael
    Utah
    Can do. They are in the back right now.
  14. Oct 14, 2015 at 6:57 PM
    #2034
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    You're the man. I've got people coming up from Austin staying on Wednesday and the in-laws a few days later.
  15. Oct 14, 2015 at 6:57 PM
    #2035
    Hilborn
    Michael
    Utah
    leave the in-laws at home.
  16. Oct 14, 2015 at 6:58 PM
    #2036
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    I lucked out on them, they're way cool. But they fly home on the 29th.
  17. Oct 14, 2015 at 7:00 PM
    #2037
    Hilborn
    Michael
    Utah
  18. Oct 14, 2015 at 7:08 PM
    #2038
    ThomasMore66
    If that was for me, pm me.
  19. Oct 15, 2015 at 11:49 AM
    #2039
    silvershark2012
    Fort Worth, TX
    2012 Prerunner
    y'all know anyone who wants these lol.
  20. Oct 16, 2015 at 11:35 AM
    #2040
    CowboyTaco
    North Georgia
    11 TRD Sport
    Did you ever get your lift on?
