Fort Worth B.S. Thread
Discussion in 'Texas' started by Kavik, May 23, 2013.
  1. May 23, 2016 at 4:58 PM
    #2701
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    Because 285's look better
  2. May 23, 2016 at 5:07 PM
    #2702
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
  3. May 23, 2016 at 5:12 PM
    #2703
    elgringoloco
    elgringoloco Well-Known Member
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Jack it to the sky and put 40" TSLs on it
  4. May 23, 2016 at 5:15 PM
    #2704
    hoarder23
    Shay
    NJ
    Scratches
    MatthewMay1 and richardbui23 like this.
  5. May 23, 2016 at 5:17 PM
    #2705
    Naveronski
    Fort Worth
    You have a point with the price.
    But is the E vs C load rating, weight, and fuel economy worth it?
    And don't hate on my coffee. :duel:
  6. May 23, 2016 at 5:19 PM
    #2706
    hoarder23
    Shay
    NJ
    Scratches
    Do you need LT tires? They are available in P rated for way cheaper. Unless you're throwing your truck around like I am or starting a landscaping business the LT tires will be an overkill.
  7. May 23, 2016 at 5:25 PM
    #2707
    Naveronski
    Fort Worth
    You mean these?
    http://www.discounttiredirect.com/direct/findTireDetail.do?ra=filterTireProducts.do&fl=&pc=12964
    That's not something I had thought of. Looks like less ply? Wouldn't that be a durability issue?
    Not trying to argue, just curious.
    (I did just have two flats this weekend in Big Bend teaching the wife to drive.)
  8. May 23, 2016 at 6:01 PM
    #2708
    hoarder23
    Shay
    NJ
    Scratches
    Less load carrying capacity, won't hold up to sidewall damage as well at LT tires, but will ride better on pavement. If you are doing most of your driving on pavement and don't plan on serious off-roading P rated tires will work, but as you experienced P rated tires are more prone to failure off-road.
  9. May 23, 2016 at 8:07 PM
    #2709
    Naveronski
    Fort Worth
  10. May 23, 2016 at 8:08 PM
    #2710
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Swaaaaammpppeeerrrsss
  11. May 23, 2016 at 8:08 PM
    #2711
    Naveronski
    Fort Worth
    Once I get a 9" rough country, maybe.
  12. May 25, 2016 at 10:56 AM
    #2712
    Jstaud
    Jstaud Well-Known Member
    James
    2016 Magnetic Grey SR5 4x4
    I'm always looking to save money. But I think the SCS wheels are a good deal and they look good. I'm probably going to end up spending close to 2k from what I've seen in just wheels and tires. I'm doing search and rescue for a civilian group and we have training out in East TX where it gets muddy and sandy with that red sand. So mostly that. Not too much rock but mostly rough dirt/brush terrain. I've got a 4x4 sr5 that I'm slowly building up to take out there. The wheels/tires are next on my list so I'm looking around. My main concern was being able to put bigger tires and wheels on without putting a lift on it mainly to save money, but if I need to I'll do it.
  13. May 25, 2016 at 2:17 PM
    #2713
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    Don't really need a lift to stuff 33's under these trucks BUT you'll need to removed or trim the fender flares and the cab mount chop. I would suggest upgrading shocks for more flex but if your looking for bigger tires no lift its no problem. How big of a tire will depend on how much your willing to cut/trim
  14. May 25, 2016 at 4:09 PM
    #2714
    Naveronski
    Fort Worth
    I need to order new air filters. What do y'all use?
  15. May 25, 2016 at 4:13 PM
    #2715
    hoarder23
    Shay
    NJ
    Scratches
    After reading on here I ordered a Toyota filter, best bang for the buck.
    richardbui23 likes this.
  16. May 25, 2016 at 4:23 PM
    #2716
    hoarder23
    Shay
    NJ
    Scratches
    265/70R17 is the same size that comes on the truck but with a more aggressive AT tire it will look better or at 275/70R17 is slightly bigger. Both you should be able to get away with without a lift. Search here and you can probably find a picture of the tire/wheel combo you like on a 3rd gen.
  17. May 25, 2016 at 5:28 PM
    #2717
    xJuice
    xJuice My spoon is too Big!
    Josh
    N. Texas
    19 Tundra MGM
    TRD Front & Rear Sway Bar, TRD Pro LED Headlights, Undercover SE, Rear diff. Relocate, console organizer, debadged, color matched handles, mirror caps, and grill
    engine or cabin?
  18. May 25, 2016 at 5:28 PM
    #2718
    Naveronski
    Fort Worth
    Both
  19. May 25, 2016 at 5:43 PM
    #2719
    xJuice
    Josh
    N. Texas
    19 Tundra MGM
    I use Rockauto for most of that stuff. Usually buy a set of filters (engine air, cabin, oil, maybe wipers too) for both the truck and Camry at the same time to save on shipping.
    For the cabin I go with the TYC. It's cheap and works.
    I've tried several different types, but I just picked up a Denso for the engine, and it looks nearly identical to OEM
  20. May 25, 2016 at 5:48 PM
    #2720
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Looks fun!
    I have a K&N engine filter. Wouldn't do it again. Cleaning and re-oiling is annoying
