Fort Worth B.S. Thread
Discussion in 'Texas' started by Kavik, May 23, 2013.
  1. May 26, 2016 at 4:25 PM
    #2741
    EasyLivin
    EasyLivin Well-Known Member
    Jeff
    Euless, TX
    2014 White TRD OffRoad Double Cab
    Focal PS165AC / Focal PS165V / Alpine PDR V75 / Kenwood Excelon KFC-XW1000F / Leer 100XR shell / Bilstein 5100 lift
    Can anybody in here recommend a good shop to do install of my lift? I have a Bilstein lift from Headstrong, but I seriously just don't have the time to put it on right now. Between getting ready to move, work, school and family, I am super swamped but want this lift on!
  2. May 26, 2016 at 4:26 PM
    #2742
    hoarder23
    hoarder23 Truck fell over
    Shay
    NJ
    15 Pyrite Mica DCSB Sport
    Scratches
    You could piece a similar kit together for about $3k but that is a solid setup that would work together with zero issues. If you want to save some money you should narrow down what you are looking for and pay attention to the group buy forum.
    And do remember, while it is the same company mountain bikes are wildly different than trucks.
  3. May 26, 2016 at 4:28 PM
    #2743
    hoarder23
    Shay
    NJ
    Scratches
    Tandem Auto on 287 right off 20 does great work. Several members here have used them and both the owners are Toyota guys, they even have their alignment machine now so it's full service.
  4. May 26, 2016 at 5:29 PM
    #2744
    EasyLivin
    Jeff
    Euless, TX
    I'll have to give them a call. Any idea of what they would charge to do this install?
  5. May 27, 2016 at 5:23 AM
    #2745
    hoarder23
    Shay
    NJ
    Scratches
    This is the only actual price seen posted here but that seems about right at $100 an hour labor. The actual price will depend on exactly what you are installing.
  6. May 27, 2016 at 6:03 AM
    #2746
    EasyLivin
    Jeff
    Euless, TX
    Thanks man I appreciate the info. I am going to call a few shops and then honestly I will lose interest and will just install it myself lol :annoyed:
  7. May 27, 2016 at 2:15 PM
    #2747
    Jstaud
    Jstaud Well-Known Member
    James
    2016 Magnetic Grey SR5 4x4
    Yeah I'm going to have some time between now and when I have the cash to put down on this so I'll be looking out for deals. I might even buy a similar setup just one part at a time.
  8. May 27, 2016 at 2:30 PM
    #2748
    Jstaud
    James
    Nice pic.
    I'll definitely PM you once I get to the point where I'm ready to pull the trigger.
    Boogyman[QUOTED] likes this.
  9. May 27, 2016 at 5:26 PM
    #2749
    Duck_Hunter
    Duck_Hunter Well-Known Member
    Tejas
    2014 Tacoma TRD Off Road Manual
    ATC shell
    Just wanted to say hello. Today is my first day on the forum and I live in south Fort Worth.
  10. May 27, 2016 at 6:56 PM
    #2750
    ThomasMore66
    Dallas/Fort Worth & Durango
    Prepare to have your money taken from you. You will find that your life has been incomplete without all of the cool new toys you'll see on here.
  11. May 28, 2016 at 5:45 AM
    #2751
    Duck_Hunter
    Tejas
    ATC shell
    Thanks for the warning.
  12. May 28, 2016 at 7:38 AM
    #2752
    ThomasMore66
    I had just bought my TRD OR and thought I was content. Then I found this place. Started with Salex organizers (you'll want to get a set of those), then this thing called a Tech Deck (a must have), then things got out of hand. I think my next mod was one of these: http://www.diazfabrication.com.
  13. May 28, 2016 at 9:11 AM
    #2753
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    So true.
  14. May 28, 2016 at 9:12 AM
    #2754
    Duck_Hunter
    Tejas
    ATC shell
    All look like good places to start. The Salex organizers are brilliant.
  15. May 28, 2016 at 9:17 AM
    #2755
    ThomasMore66
  16. May 28, 2016 at 3:13 PM
    #2756
    Duck_Hunter
    Tejas
    ATC shell
  17. May 28, 2016 at 4:56 PM
    #2757
    ThomasMore66
    I've needed that little bolt tray a bunch of times. Not sure why I've waited so long.
    URD Y-pipe is also coming soon. I need that to finish up my AFR install.
  18. May 31, 2016 at 3:20 PM
    #2758
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
  19. May 31, 2016 at 6:23 PM
    #2759
    ThomasMore66
    Looks is what I was after.
    richardbui23[QUOTED] likes this.
  20. May 31, 2016 at 8:36 PM
    #2760
    Duck_Hunter
    Tejas
    ATC shell
    Nothing wrong with that!
