Fort Worth Meet Up 10/30
Discussion in 'Texas' started by elgringoloco, Oct 6, 2015.
  1. Oct 6, 2015 at 6:21 PM
    elgringoloco
    elgringoloco [OP] Well-Known Member
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Anybody up for a meet that Friday night? A friend from CA is coming out and we haven't had one in a while. There's plenty of open parking here for a lot of us, and the bottomless fries are tasty.
    Where: Red Robin
    820 NE Mall Blvd, Hurst, TX 76053
    When: Friday October 30th, 7pm -?
    Who: Anyone that wants to hang out
    Why: Because we can
  2. Oct 11, 2015 at 8:45 AM
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    Have you posted this in the FW BS thread?
  3. Oct 14, 2015 at 6:59 AM
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Good call.
  4. Oct 23, 2015 at 5:16 AM
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
  5. Oct 28, 2015 at 9:04 AM
    elgringoloco
    Bryce
    Ft. Worth, TX
    09 TRD Off-Road
    Bump! Anyone else going?
