Fortin Evo-One & T-Harness for Remote Start
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SprtBkr, Feb 1, 2015.
  1. Feb 1, 2015 at 8:38 AM
    SprtBkr
    SprtBkr [OP] Average Member
    Scott
    Denver, CO
    2018 Tundra SR5 5.7L Double Cab 4x4 Inferno
    http://fortin.ca/en/vehicles/toyota/tacoma/2014/
    Have any of you installed a Fortin Remote Start? If so, how did it go? Would you recommend?
    On ebay I found the harness for $40, the remote start/immobilizer bypass (evo-one) for $140, and the flash link updater for $55. This should make the remote start plug and play into the Tacoma's wiring.
    I'd love to hear your thoughts on this. Thanks.
  2. Feb 2, 2015 at 7:15 PM
    SprtBkr
    Scott
    Denver, CO
    Anybody? I went ahead and ordered this along with a DEI DSM200 smartstart remote for iPhone and Android. I plan to program it to use the factory remote and iPhone over cellular.
  3. Feb 2, 2015 at 7:19 PM
    Pigpen
    Dan
    Northwest Montana
    Looks like you're the guinea pig. Gotta do a write up!
  4. Feb 2, 2015 at 8:18 PM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    Subed. Very interested in hearing how the install goes! !
  5. Apr 25, 2015 at 6:27 PM
    dooododoo
    dooododoo Active Member
    Northbrook, IL
    2015 TRD Sport
  6. Apr 26, 2015 at 11:27 AM
    SprtBkr
    Scott
    Denver, CO
    It is not supported by the Evo-One, so I'm guessing no on the Evo-All. It's a limitation of the Tacoma, I think. But call Fortin Tech support and ask. They are very helpful.
  7. Apr 27, 2015 at 7:11 AM
    topcathr
    topcathr Well-Known Member
    2015 limited
    I just installed a remote starter using the fortin t harness and idatalink bypass. I bought the kit on Amazon it was advertised as a plug and play.
    advanced auto security sells the kit all ready flashed and all the wires tagged. The one I bought was a crime stoppers the kitit was 199.00
    it is specifically wired for the 2013 to 2015 Tacoma. the best part is that you don't cut any wires they just plug into the ignition switch and you use the supplied tap connectors to connect the wires. It took me about an hour and a half I have a 2015 limited. Good luck
    RickTRDSport likes this.
  8. Jun 8, 2015 at 8:38 PM
    dooododoo
    Northbrook, IL
    2015 TRD Sport
    Can you post a photo of the instructions? I bought a remote starter, bypass, and USB flash device. I'm looking at all the wires and realize that I ef'ed up. From my understanding, these remote starters (wiring wise) are all the same because they are made by a few parent companies and resold as many brands. I'm hoping your instructions will apply to the kit I purchased and hopefully I can get it working. Thanks!
    BTW, did your kit come with any relays pre-wired?
  9. Jun 9, 2015 at 6:00 AM
    topcathr
    2015 limited
    I bought a remote starter kit for my 2015 Limited from Amazon it is made by crime stoppers... the kit came with the t harness and the fortin bypass you don't need a key. It was easy to install only connected 6 wire and it worked great Ground, horn, parking lights, immobilizer, tach, 12v I chose not to connect the remote lock... There is a video on you tube ......the kit was 199 or 250 with 2way 1500 ft range.
