Found a crush washer......oops
Discussion in '1st Gen. Tacomas (1995-2004)' started by Cheesycook, Dec 5, 2009.
  1. Dec 5, 2009 at 2:30 PM
    Cheesycook
    Cheesycook [OP] Geek with a gun
    Hermiston, OR
    01 4x4 DC Tacoma V6
    Just got done swapping my oil and differential gear oil to synthetic yesterday. Just as I was cleaning up I found a crush washer in the drain on my oil container. I think it is from my rear axle drain. No leaks at all. Is that just to keep the bolt in or is the washer also intended to keep the seal?
  2. Dec 5, 2009 at 2:40 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    X2. They form the seal
  3. Dec 6, 2009 at 5:45 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Never heard of a crush washer on a drail plug.
    Was it copper? Copper crush washers are used on brake lines.
  4. Dec 6, 2009 at 5:54 AM
    MikeyD
    MikeyD Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    Same thing happened to me when i did my oil yesterday. I keep checking and their are no leaks. Do you guys think it is necessary to put it back on?
  5. Dec 6, 2009 at 6:01 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  6. Dec 6, 2009 at 6:05 AM
    Janster
    Jandy
    Lancaster, PA
  7. Dec 6, 2009 at 6:13 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    My 98 had one. Were you the original owner?
  8. Dec 6, 2009 at 6:18 AM
    swise
    swise TRIFECTA!!!
    ohio
    08 4x4 dbl cab, TRD offroad
    mine has one on the oil pan drain plug - factory toyota filters have a new one in the bottom of the box. I reuse the old ones and never have leaks. They are made of some kind of black flexible material so they can stick to the pan at first then fall off in the draining stream of oil without you noticing.
    If your not leaking, dont worry about it and put one back on at next change
  9. Dec 6, 2009 at 11:49 AM
    monoman
    monoman Time to get dirty!
    Dave
    Exotic, San Jose, Cal.
    2003 Tacoma Dbl Cab 4X4
    Interresting, I've never seen one of those in the box....is this in the newer model truck filters?:confused:
  10. Dec 18, 2009 at 10:47 AM
    HBMurphy
    HBMurphy Ban Pending
    Paul
    So California Coast
    09 Off Road Delete Model
    None
    I have 2 other cars that every filter I have ever purchased for those cars came with a new one. Alternatively heat it on stove til it gets hot, then let it cool slowly and reuse - not the best alternative but it works - makes the copper soft.
  11. Dec 18, 2009 at 10:48 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Yep, the annealing process. Oven at 400-450 for 15 minutes works too.
  12. Dec 18, 2009 at 5:33 PM
    Mootsman
    Mootsman Active Member
    Gunnison, Colorado
    02 Tacoma SR5
    3" Fabtech Lift
    The oil pan, not differential, on my 02 has one, and I have found it in the oil drain pan before. I went through that oil change without it because it never leaked a drop. The next change I put a new one on. If there is no leak, I wouldn't worry about it.
    My Subaru outback on the other hand, will drip through the whole oil cycle if you leave the crush washer off.
