Found a good deal on craigslist and would like opinions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mikey1892sjr, Jan 23, 2011.
  1. Jan 23, 2011 at 9:32 AM
    mikey1892sjr
    mikey1892sjr [OP] Well-Known Member
    League City/Houston, Texas
    07 PreRunner DoubleCab
    removed front mud flaps, weather-tech floor mats, viper keyless entry. Next is 5100s!!
    Okay I found a guy willing to get me 5100s, ome 885s and 1.5" AALs all for $320 this is a good deal right? it should level out the front then lift the rear too right? just checking the numbers on this sorry if its been answered just need to find out soon because he wants to meet here pretty soon for me to pick em up
  2. Jan 23, 2011 at 9:36 AM
    Natetroknot
    Natetroknot Def Leppard Sucks!
    Nate
    Dubuque, IA
    '11 Black Access Cab
    Billy's @ .85, 1.5 Progressive AAL, Leer 100xl, BFG KO2's
    sounds like a good deal but for your situation might not work out....if I'm not mistaken the 885s are the heavier coils and are meant for heavy bumpers....someone please chime in if I'm wrong.
    Check what the 5100s are set at. Heck, just ask the guy how it worked for him/what he had on his truck and you'll get a good idea. Definitely sounds like a good deal though, especially if they're in good cond.
  3. Jan 23, 2011 at 9:38 AM
    mikey1892sjr
    he says they are pretty much brand new and hes going with a different lift. he also says it will give me 3" of lift up front and with the 5100s and the 885s. and 1.5" in the rear to level it. is this right?
  4. Jan 23, 2011 at 9:42 AM
    Hoyal
    Hoyal Whiskey bent and hell bound.
    Devin
    N 39.2249 W -106.16974
    2013 Tundra
    Big tires, big lift, Lots of stuff's.
    The 885 and the 886 coils were not designed to work with the 5100's. Which is why I did not but them I went with the Eibach springs. I know some people run that set up with the 885/886 coils with the 5100's on here but I would not.
  5. Jan 23, 2011 at 9:47 AM
    Natetroknot
    Nate
    Dubuque, IA
    ^^^that's what I meant!:D
    If they're in good condition I'd still jump on 'em, replace the 885 coils with your stock springs, set it at 2.5, throw in the AAL and you'd be level.
    If the coils are kosher you'd get a decent chuck of change on here for them I bet. I dunno.
  6. Jan 23, 2011 at 10:12 AM
    Gabex35
    Gabex35 Shinty Killer
    Gabe
    San Diego
    2014 4 Runner Trail Premium
    King OEM Performance Series with compression adjusters, Custom rear coils drom CSS, 22% Tint, Method Race NV's 17x8.5, 285/70-17 MTR's, AllPro welded Sliders, Cobra CB, Gobi stealth roof rack, Rigid 40" e series & duallys out back
    I have a 2010 4X4 Access Cab with the 5100's (set at zero) and the OME 885's and 1/2" spacer and it yielded exactly 3" of lift. I think the ride is slightly stiffer (up front) than stock.
    I have the Toytec 1.5" AAL in the rear and i think it makes the rear a quite a bit stiffer than stock. I don't have a problem with it though, as i am consistently hauling my racebike.
  7. Jan 23, 2011 at 10:12 AM
    mikey1892sjr
    well i have a pre runner so my stock springs arent so hot lol but I'm for sure jumping on it here pretty soon. but i might try the stock springs and see how they ride for a while then sell the 885s for some cash
  8. Jan 23, 2011 at 10:14 AM
    mikey1892sjr
    so where did you get the 1/2" spacer from? because i might just do that
  9. Jan 23, 2011 at 10:20 AM
    Hoyal
    Devin
    2013 Tundra
    Are you looking for 3 inches of lift or just more than you have now? Go look at toytecs web site.
  10. Jan 23, 2011 at 10:20 AM
    Gabex35
    Gabe
    San Diego
    i just re-read your post, and saw you were looking for numbers...
    Before Lift,
    FL:34.5
    FR:35
    RL:37.75
    RR:37.75
    After Lift,
    FL:37.5
    RR:38.25
    RL:39.5
    RR:39.25
    *measurements were from ground to bottom lip of fender flare with stock OR wheels/tires
    BTW, i took these measurements about 150 miles after i installed the lift so things may have settled since then. Hope this helps
  11. Jan 23, 2011 at 10:22 AM
    Gabex35
    Gabe
    San Diego
