Found a used TRD supercharger - what should I be watching out for?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Andyvclifford, Aug 26, 2021.
  1. Aug 26, 2021 at 6:20 AM
    Andyvclifford
    Andyvclifford [OP] Member
    Hey,
    I recently found someone who is parting out their 1st gen Tacoma and are willing to sell their trd supercharger. Is this even a good idea ? What kind of things should I be looking for when looking at a used supercharger? He’s asking around 2000 for it.
    Thanks !
  2. Aug 26, 2021 at 6:27 AM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Bearings.
    Wear on the rotor volutes.
    Damage on the discharge port.
    End play.
    Gear backlash.
  3. Aug 26, 2021 at 6:31 AM
    1997tacomav6
    Denver
    Plan on having it rebuilt =1000.00 plus or buy it and take a chance
  4. Aug 26, 2021 at 6:42 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Assuming since you asking here, you might not be able to assess it without help. No offence intended. If you know someone who can, that's option 1. His price may be good if it's in good condition.
    That said,...if he had paperwork showing recent rebuild - bargain. If not, I offer $12-1500 (your call on negotiating) and tell him you have to assume the $1000 for rebuild.
    BeLance89 and 1997tacomav6 like this.
  5. Aug 26, 2021 at 6:54 AM
    Andyvclifford
    You are correct I’ve never dealt with a supercharger before so I really have no idea what kinds of things to look for. I rebuild old motorcycles so I have some mechanical understanding of vehicles but I have yet to dive into doing any work on my truck. If I were to have someone inspect it would thst be a Toyota dealership or would any decent mechanic be able to take a look at it ?
  6. Aug 26, 2021 at 6:55 AM
    1997tacomav6
    Denver
    X2,
    This is so true, there are plenty of people that have spent the long money on a used supercharger 2-2.5k
    only to find out the supercharger needs to be rebuilt for another 1000.00.
    My last rebuilt cost my 1500.00 with shipping because my rotors were damaged
    Wsidr1[QUOTED] likes this.
  7. Aug 26, 2021 at 6:59 AM
    1997tacomav6
    Denver
    You have to have it running on the truck to hear the bearings and it needs to be opened up to see
    the rotors and wear, no Toyota will not do this.
    Your better off planning on a rebuilt,
    For a little more you can buy a new one with a warranty,
    2000.00 for an as is supercharger is not a deal unless you know the history
    TWJLee likes this.
  8. Aug 26, 2021 at 7:56 AM
    Clay_916
    Clay_916 Well-Known Member
    Fort Collins, CO
    2000 x-cab 4x4
    5100's, All Pro 3" Standard leafs, 32" KM 2's
    2k is scam dude even if it was just rebuilt
  9. Aug 26, 2021 at 10:59 AM
    Andyvclifford
    Thank you for all the advice ! What do you think is an acceptable offer on it ?
  10. Aug 26, 2021 at 9:11 PM
    1997tacomav6
    Denver
    Whatever you decide and add 1000.00 because more than likely it will need a rebuild sooner than later
  11. Aug 27, 2021 at 1:33 AM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    Buy it for $2000 and spend $1000 on a rebuild kit, or spend $3500 for a brand new Magnusson SC kit.
  12. Aug 27, 2021 at 1:39 AM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    Also is it a gen 1 (gray squarish less aftermarket support harder to get parts less efficient) or gen 2? (Standard sleek black sometimes has the raised TRD casting in it more boost more options.)
  13. Aug 27, 2021 at 4:23 AM
    1997tacomav6
    Denver
    Yes, the grey ones parts new will be harder to find except bearings, those are available.
    Standard power is the same. The early grey models all have raised TRD in the castings.
    The early grey supercharger can be ported because it’s a two piece casting and you can
    get more potential power with the smaller pulleys.
    The newer supercharger is not a two piece casting and can not be ported inside the rotor upper housing section.
    If you have the extra money go new with a warranty,
    People ask too much money for used superchargers with no history or guarantees.
  14. Aug 27, 2021 at 7:10 AM
    Andyvclifford
    Thanks all! I offered 500 probably most I’m willing to pay based on all your advice and the fact that he has no history for it and it’s a gen 1
    1997tacomav6 likes this.
  15. Aug 27, 2021 at 1:40 PM
    1997tacomav6
    Denver
    Some rebuilding shops depending where you go we’re at one time this year 3 months or more behind for work to be done because of parts not available,FYI
