Found coolant leak shop caused?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ywen, Nov 22, 2010.
  1. Nov 22, 2010 at 7:14 PM
    ywen
    ywen [OP] Well-Known Member
    Please see these images of the leak from the driver side hose that's coming out of the radiator. I disovered it while changing oil. There also seems to be a whitish spray that got on the oil pan.. which I persume is from the leak. What would cause such a leak?
    I recently had a shop rea-tighten the alternator belt.. I see the pully for that belt is right next to the hose.. could they have bumped it?
    The end that goes into the engine
    The white spray on the oil pan
    The radiator end of the hose
    Thanks
  2. Nov 22, 2010 at 7:17 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren bump stops, Crown braided/extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch,
    Looks like a great excuse to replace the hose.
  3. Nov 22, 2010 at 7:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    replace the hose or just replace the clamp and see if it quits leaking then. those clamps are throw aways anyway......they lose their ability after a few years.
  4. Nov 23, 2010 at 6:09 AM
    ywen
    thanks I"ll try to replace the clamp+hose.. how do I know whether coolant will pour out when I remove that hose?
  5. Nov 23, 2010 at 6:11 AM
    98tacoma27
    Ben
    Not Beech Creek
    Is this the one on the top of the rad?
  6. Nov 23, 2010 at 6:21 AM
    ywen
    It's the lower radiator hose on the driver side. The engine end of the hose is underneath the alternator.
    When the car is sitting shut down, where is the majority of the coolant? inside the radiator? If so, then looks like I will need to drain the entire radiator to do this job... :(
  7. Nov 23, 2010 at 6:33 AM
    98tacoma27
    Ben
    Not Beech Creek
    Yes, the entire rad is full of fluid at all times. So, you will need to drain.
  8. Nov 23, 2010 at 6:44 AM
    ywen
    where is the drain cock on the taco's radiator?
    EDIT: nevmind I found it.. The taco has two of them!?
  9. Nov 23, 2010 at 6:53 AM
    98tacoma27
    Ben
    Not Beech Creek
    One drains the engine. I wouldn't worry about that one too much.
  10. Nov 23, 2010 at 6:57 AM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Personally, I would just put on a screw type clamp and not remove the hose. If it fixes the leak, great. If it doesnt and you need a new hose, no real loss. Just saves you draining and filling the rad.
  11. Nov 23, 2010 at 9:17 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    X2
    I had to replace my lower hose a couple weeks ago again because of a small pinhole(cheap hose)......so I had to drain the rad. out completely. And definitely use the screw type band clamps.....factory clamps wear out after some time and don't clamp well.
  12. Nov 23, 2010 at 9:48 AM
    ywen
    I'll try the screw type.. but how do I remove the factory spring-style clamp without taking out the hose? :)
  13. Nov 23, 2010 at 1:07 PM
    Snowman
    Craig
    Somewhere in Canada
    Check out my build
    I would just push it back a little and put the new on on next to it. Again, if it works, great. If it doesnt, no loss, just replace the hose.
  14. Dec 3, 2010 at 8:38 AM
    ywen
    So I put a couple of screw-clamp on both ends of the lower radiator hose and it seemed to have stopped the leak! I just moved back the original spring clamp and put the new one on front of it. Thanks for the suggestion!
