FOUND IT! Post lift clunking and knocking.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtweezy, Dec 23, 2015.
  1. Feb 13, 2016 at 11:01 AM
    #201
    jtweezy
    jtweezy [OP] Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    That's what I was thinking. I may check it just to cross it off the list, but it wasn't causing the actual CV shaft to move. Looking at the diagram, it seems that assembly houses the joint. Wonder if it's under greased...
  2. Feb 13, 2016 at 11:01 AM
    #202
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Much appreciated! At least I know mine is moving relatively excessively.
  3. Feb 13, 2016 at 1:37 PM
    #203
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I checked it out bitch, and hey give me sometime I will find out who you are and send my Trooper buddies to harass you :D
  4. Feb 13, 2016 at 1:39 PM
    #204
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    *some time
    *Trooper
  5. Feb 13, 2016 at 1:40 PM
    #205
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Great another grammar PoPo
    llibrm and CurtB[QUOTED] like this.
  6. Feb 13, 2016 at 1:42 PM
    #206
    CurtB
    Curt
    Kansas
    2010 Tacoma SR5
    Nah, just beating OZ-T to it ;)
    Unchained 5150 likes this.
  7. Feb 13, 2016 at 1:42 PM
    #207
    Subway4X4
    Subway4X4 Shameless Copy Cat
    Lloyd
    NY/NJ
    05 Speedway Blue DCSB OR TRD
    Everything TW members recommend
    It's too cold for your Trooper buds to leave the doughnut shop to come out and find me...
    CurtB and Unchained 5150[QUOTED] like this.
  8. Feb 13, 2016 at 1:43 PM
    #208
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    So I have barely any movement on the Drivers and Passenger side. Pretty much equal.
  9. Feb 13, 2016 at 3:06 PM
    #209
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Sight unseen, I'm gonna guess yours are moving about as much as my passenger side. My driver side has enough play to actually make noise. The passenger side doesn't move enough...almost like it can't get enough speed to strike hard enough. I'm guessing this is why when I get a lateral jolt I hear the clunk because that thing is just freely sliding in and out (TWSS).
  10. Feb 13, 2016 at 7:21 PM
    #210
    brianrride
    brianrride Well-Known Member
    TN
    2014 TRD Off Road DC
    Mine was that bad after a 3" lift. Caused several issues. Had the TSB needle bearing replacement done yesterday...cannot believe how smooth the entire truck is now, even when its below freezing which is when it was real bad before.
    Blackout14 likes this.
  11. Feb 13, 2016 at 7:33 PM
    #211
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    The clunk on a turn isn't likely CV related since my prerunner did it. Might be a fix for some people maybe I guess.
  12. Feb 14, 2016 at 6:36 AM
    #212
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Right, and even maybe not for some 4x4s, but we've got a lot of ideas in this thread and a lot of things to check which is good. Hope it helps someone find their clunk.
  13. Feb 14, 2016 at 5:27 PM
    #213
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    So I am beginning to suspect that my clunking and rattling sounds are related to the body mounts. I have over 200K on the truck and although I don't have anything to compare them too they look kinda shot to me. Anyway I will be replacing them next.
  14. Feb 14, 2016 at 5:36 PM
    #214
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Ouch. Those look pretty beat up. As far as I can tell my rubber bushings are still touching the washer.
  15. Feb 15, 2016 at 4:14 PM
    #215
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    image.jpg image.jpg image.jpg image.jpg Changed out my LCA bushings today. Pops gone! Yay
    Crom and alphabravo like this.
  16. Feb 15, 2016 at 5:23 PM
    #216
    1rooster
    Georgia
    2007 Tundra crewmax
    I was actually gone do a complete rebuild. But both upper and lower ball joints were still very tight. Same with the tie rods. Later on down the road I will them if needed.
    Also the bottle jack worked like a charm! A little heat and those bad boys popped out like butter.
  17. Feb 16, 2016 at 6:07 AM
    #217
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Nice! Yea my LCA bushing don't look bad at all. Yours look pretty terrible.
  18. Feb 16, 2016 at 6:46 AM
    #218
    1rooster
    Georgia
    2007 Tundra crewmax
    You can see the shinny parts on the bushings. I'm guessing that's where they were shifting around.
  19. Feb 16, 2016 at 6:48 AM
    #219
    1rooster
    Georgia
    2007 Tundra crewmax
    Jtweezy I checked my driver cv and it moves identical to yours
  20. Feb 16, 2016 at 7:25 AM
    #220
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Hmm. I guess I should go rent that GoPro and see if my LCAs are moving. I just don't think a 2014 would need it yet.
