FOUND IT! Post lift clunking and knocking.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtweezy, Dec 23, 2015.
  1. Mar 14, 2016 at 10:55 PM
    #401
    HB Taco
    HB Taco Well-Known Member
    Curt
    Huntington Beach, CA
    2019 F150 FX4 S Crew 3.5 TT
    Not sure if my post was very clear. I believe my problem was the shocks themselves (5100's - mainly drivers side). I bought all the hardware to assemble my OEM shocks cause a few years ago I used all the original hardware on the 5100's. So basically I replaced the whole shock assembly. Put the originals back in with some small spacers and new hardware. Hope that clears up my situation.
  2. Mar 14, 2016 at 11:07 PM
    #402
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I need to do EBC Yellow Kevlar brakes on mine, and when I do that will determine if it indeed is my brake pads and hardware allowing shifting within the calipers.
    Polyurethane motor mounts and power steering rack bushings first though.
    Racetruck before noise hunting. #priorities
  3. Mar 15, 2016 at 1:47 PM
    #403
    mouse007
    mouse007 Well-Known Member
    Mauricio
    Weston,Florida.
    2014 TRD Off-Road 4x4
    ICON Vehicle Dynamics Uni-Ball UCA, ICON Vehicle Dynamics Extended travel remote reservoir coilovers, with 700# Coils and CDC (Compression Damping Control) Clicker Valves. Dakar Leafs Old Man Emu Nitro Sport Shocks Toyotech U-Bolt flip kit, Goodyear F. & R. extended Stainless Steel Brake lines. aFe Pro Dry drop in air filter. ARB Bull Bar. Weld on AVID Off-Road Rock Sliders W/ Kick Out. Tires: 285/75 R16 BFGoodrich KO/TA's. Light Force Blitz 240's 12v. Warn M-8000 W/ Viking Off-Road Synthetic winch line.
    NICE...!! @jtweezy I just ordered my bushings from @Wheeler's Off-Road, Inc let's see if this solves my problem... I was under the truck the other night and saw what you mentioned. I did't try and move them as i dint have any tools with me but I did see that the front leaf eye bushings were slightly off-centered. Will report back..!!
  4. Mar 15, 2016 at 3:52 PM
    #404
    jtweezy
    jtweezy [OP] Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Did you get the bushings for front and rear spring eyelets? I'd suggest doing them both. I tried to figure out a way to drop one side of the leaf pack and keep the other side bolted in, but it just wasn't happening. If you do one, do 'em both!
    mouse007[QUOTED] likes this.
  5. Mar 15, 2016 at 4:01 PM
    #405
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    OP updated...
  6. Mar 16, 2016 at 1:13 AM
    #406
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    Whelp. No luck on the shock tower pads. I like having them in there but I still got a rattle. Gonna have to borrow/steal a GoPro or maybe have a buddy drive it slow while I walk along side. At this point it has to be wheel bearings, tie rods, coil chatter, or maybe something completely simple like a body panel.
    FYI, If you use the ES pads they are not the right size. You will need to cut the skirt off flat since the skirt diameter is larger than the hole diameter on the bucket. Also you have to cut your own holes.
    Torspd likes this.
  7. Mar 16, 2016 at 4:55 AM
    #407
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    Gonna have to borrow/steal aGoPro. I would defiantly just steal one! Haha but seriously though that sucks that it didn't fix it. You got some nice high dollar suspension. Besides the rattle how does it drive and handle?
  8. Mar 16, 2016 at 5:56 AM
    #408
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Is there play in the top mount of the coilover (where the round thing is connected to the ball looking thing)? I was researching Fox coilovers and it seems some people have gotten noise because that top mount has too much side-to-side play.
  9. Mar 16, 2016 at 10:32 AM
    #409
    mouse007
    Mauricio
    Weston,Florida.
    @jtweezy In my case, the shop who installed them put the O.M.E. bushing's on the shackle hangers and the rear leaf eye's (Not sure if this is fine...). Yesterday I moved the front part of the leaf pack with a crowbar. You can also see the bushing O.M.E places in the front eye's sliding out to one side, the bushing is sliding/moving more on the Pass side thank the Driver. I really hope this solves my problem..!!
  10. Mar 16, 2016 at 11:27 AM
    #410
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Well I'm witholding final opinion until I get the noise issue sorted out. I will be a little sad if it turns out to be the coils chattering. Not sure what I could do about that except maybe increase preload or figure out some way to pad them. Otherwise I am really loving the ADS gear front and rear.
    I was noticing that too. Everything seemed to be tight but I will double check.
  11. Mar 28, 2016 at 7:35 PM
    #411
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My issue is solved and done.
    Turns out my brakes were indeed toast. I swapped them out today for the EBC Yellow Kevlars, lubed up the pins (which were bone dry mind you) and slapped it all back together. Took it for a quick test drive and tested the forwards/backwards clacking sound. I am SO pleased to say that it is GONE!!! GONE GONE GONE! The only thing I need to still do is add an extra brake pad retention spring on the upper as you can see in the picture, everything else is set to go, and the pads have a lot more initial bite and clamping force to stol the truck over the OE pads.
    62K. It's been a fantastic run with OE with about 15% remaining on the pads, but it was time to swap them out and I solved the inertia based clacking issue I used to have in the process!!! I am BEYOND happy!!! :D
    In time I will swap out to SS brake lines and change the fluid to ATE Super Blue fluid. In time though.
  12. Mar 29, 2016 at 6:14 AM
    #412
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    SWEET! Glad to see everyone's getting their noises figured out and fixed. I'm at 43K and my front pads still have quite a bit of material on them, but let us know how those EBCs work out for you. I used to run EBCs on a previous vehicle and loved them. I'm also interested in doing SS brake line upgrades when the time comes to flush the brake fluid.
  13. Mar 29, 2016 at 6:57 AM
    #413
    12TRDTacoma
    Rob
    Concordia
    Boosted
    This is actually my first set of these pads ever. I used to run Hawk LTS pads I think with slotted rotors on my old GTO. It was an awesome setup and gave the car so much better stopping power! What sucked about that car though was that the car had floating calipers compared to the fixed ones these trucks do.
  14. Mar 29, 2016 at 7:11 AM
    #414
    HB Taco
    Curt
    Good to know. I'll need to do my brakes soon. I'm at 53k but have done some towing. I've never been happy with the brakes and I've had the clacking noise on brake application for a couple of years now. Just gotten used to it I guess. So no noise and better braking? I need to do that!
    12TRDTacoma[QUOTED] likes this.
  15. Mar 29, 2016 at 8:46 AM
    #415
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I got used to it as well, though it still annoyed the hell out of me. Do it and you'll love it all over again!
  16. Mar 29, 2016 at 8:56 AM
    #416
    neverstuck
    neverstuck Well-Known Member
    Guido
    Lebanon
    13 DCLB sport
    slide-in camper, OME Nitros w 884's and Dakars, Michelin A/T2, Pro EFX heated towing mirrors, Timbren HD bumpstops, KB VooDoo bed rails and tailgate cap, ImMrYo rvm bracket, G-Tek Fab door sill protectors, Ultragauge, window visors, hood deflector, Wet Okole seatcovers, in-vehicle safe.
    Have you done the squeaky leaf fix yet? I did mine before install and have never heard the slightest sound from them.
    Also re: the front end clunk, I torqued my too-loose LCA cam bolts after the knobs at the tire shop did an alignment and left them loose. So far that has done away with my front end clunk when the front end is flexed. :thumbsup:
  17. Mar 29, 2016 at 10:03 AM
    #417
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Where did you find the poly motor mounts?
  18. Mar 29, 2016 at 12:08 PM
    #418
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    That's the setup I want to do.
  19. Mar 29, 2016 at 12:32 PM
    #419
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Talk to @Bonzen and @Supermoto they are awesome!
    They should work a lot better on our trucks then on my old GTO's dual piston floating calipers. We got 4 piston fixed.
    Bonzen likes this.
  20. Mar 29, 2016 at 4:48 PM
    #420
    Bonzen
    Bonzen Solid Offroad motor & transmission mounts
    Lake Havasu City
    The Silver Bullet
    Everything.
    Looks like you could benefit from some badass motor mounts if you wanna keep jumping like you avatar!
