FOUND IT! Post lift clunking and knocking.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtweezy, Dec 23, 2015.
  1. Jan 18, 2016 at 7:00 PM
    #81
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    I'm glad you finally got it on camera! I'm sure that gace you some piece knowing what it is now
  2. Jan 18, 2016 at 7:23 PM
    #82
    patbegley
    patbegley Well-Known Member
    The Kootenays
    '22 DCLB
    Yes great shot. Satisfying I bet
  3. Jan 18, 2016 at 7:32 PM
    #83
    jtweezy
    jtweezy [OP] Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    Ok...anyone found a way to diagnose the LCA bushing without removing the LCA or a camera mounted?
  4. Jan 18, 2016 at 7:52 PM
    #84
    totmacher
    totmacher automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    I still had some clunk after new LCA bushings in my prerunner. Like I said before, there seems to be a number of sources so you fix one but still hear/feel another.
    I had done a lot of stuff trying to chase it all down in my old prerunner and sort of wonder if maybe the angle of the lower ball joint changing after lifting does something. Like maybe the it doesn't ride centered in it's pocket anymore so it less stable? Just guessing...
  5. Jan 18, 2016 at 10:14 PM
    #85
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    I have been lifted for years, and this clunking has been very recent. And yes, Very happy to find the culprit. I was so focused on the UCA, I took the front end apart 3 times :oops: Good to know my upper is even better now :D
    Been happening since I put 285s and let the guys at Goodyear do my alignment. Twice. They fucked it up the first time, so I took it back to make it right. So now i'm not sure if I get some factory bushings, or go all out and get the Total Chaos stock length LCAs :cool:
  6. Jan 19, 2016 at 5:53 AM
    #86
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    I'm pretty sure all this post-lift racket isn't from a single cause. Even up front, relocating the sway bar got rid of SOME noise, but not all of it. Your thought reminds me of a post I read somewhere about the caster angle causing the clunking noise. The caster on my driver's side is not within spec...the alignment guy said he couldn't get it in spec with the stock UCA. However, he was able to get the passenger side in spec with stock UCA. I don't know enough about alignments, but that sounds like a cop out answer to me. The two sides should be nearly identical, no? Anyway, most guys running aftermarket UCAs are running them maxed out, which might explain why the clunking seems to be independent of stock/upgraded UCAs.
  7. Jan 19, 2016 at 5:56 AM
    #87
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    I looked into replacing LCA bushings with Energy ones last night. Seems like it CAN be a PITA to press out old bearings, though mine don't look rusty, so I toyed with the idea of new LCAs. The TC are $$$$. I'm not putting that much into the LCAs of my mostly stock truck right now. Makes sense for you judging by the look of yours, though!
  8. Jan 19, 2016 at 8:33 AM
    #88
    1rooster
    Georgia
    2007 Tundra crewmax
    I agree that some can be a pain in the ass to remove. Since your pretty low milage I hope yours ain't seized. I hope mine ain't either!
    Once I remove my LCA, I'm just going to take the whole accembly to my mechanic to do all the dirty work. He's got all the right presses that I don't and can make a hard job look easy. So I would rather pay him a little instead of those LCA whooping my ass for hours on end
    Unchained 5150 likes this.
  9. Jan 19, 2016 at 10:30 AM
    #89
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    I think with a press with different adapter sizes, and an impact wrench (which I have)...I can press out the old bushings. My 887 springs get here on Friday, so I need to decided if I want to go ahead and do the bushings at the same time. Then I'll need to find some ES bushings and probably get the greasable Moog cam bolts, too.
  10. Jan 19, 2016 at 11:15 AM
    #90
    1rooster
    Georgia
    2007 Tundra crewmax
    It's never ending huh!
  11. Jan 19, 2016 at 11:59 AM
    #91
    AustinPizzini
    AustinPizzini Well-Known Member
    Austin
    Huntersville NC
    006 ACLB SR5 ON KINGS
    285/75/16 Micky Thompson Baja MTZ P3, king 2.5 Resi coilovers, spiderTrax, cbi hood brackets, caliraised led pods, caliraised led bar in lower valance, UWS tool box, blacked out emblems, 18% tint, lots of audio stuffs
    New u joints fixed my clunk!!!
  12. Jan 19, 2016 at 1:29 PM
    #92
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    U joints in the rear?
  13. Jan 19, 2016 at 1:32 PM
    #93
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Got under the truck again this morning and cranked the LCA cam bolts to 100ft-lbs (4x4 spec) plus a few degrees. Nothing was loose. While I was under there looking around, I remembered that the rack and pinion bushings on the 2nd gen suck and a lot of people have replaced the bushings with ES or some other aftermarket poly bushings. Been thinking about it, and since my clunk results from steering and lateral forces, the rack & pinion shifting makes more sense than LCA bushings. I don't get a clunk when I start/stop, and from the videos of bad LCA bushings it seems like that's a definite symptom. Could also explain why I pass the figure-8 test.
  14. Jan 19, 2016 at 1:35 PM
    #94
    Adventurous
    Adventurous Well-Known Member
    Colorado
    15 DCLB SR5
    I haven't read through the whole thread, but I got a clunk over bumps from my OME setup because the top nut on the strut wasn't tightened down fully. It allowed the shock to drop a bit going into the bump then return with a clunk on the other side.
  15. Jan 19, 2016 at 1:36 PM
    #95
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    I've checked the top nylock nut on each of my front struts. My clunk isn't always caused by suspension articulation, but some other folks here might benefit from checking those nuts. Thanks!
  16. Jan 19, 2016 at 1:40 PM
    #96
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport
    Stock
    mine usually happens on bumpy roads going really slow, after coming to a stop and at take off, not so much on turns. pretty sure its the lca bushings.
    redtacoma88 likes this.
  17. Jan 19, 2016 at 1:42 PM
    #97
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    That sounds more like LCA bushings. I get nothing on starts/stops. Every video I've seen of worn LCA bushings, the LCA slides forward/backward on the cam bolts and knocks on the frame on either end.
  18. Jan 19, 2016 at 1:50 PM
    #98
    AustinPizzini
    Austin
    Huntersville NC
    Yes sir. The u joint connecting my driveshaft to my rear differential was shot.
  19. Jan 19, 2016 at 2:20 PM
    #99
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Did that leave any witness marks on the LCA or Frame? Seems like it should be taking of paint...
  20. Jan 21, 2016 at 7:59 PM
    #100
    mouse007
    mouse007 Well-Known Member
    Mauricio
    Weston,Florida.
    2014 TRD Off-Road 4x4
    ICON Vehicle Dynamics Uni-Ball UCA, ICON Vehicle Dynamics Extended travel remote reservoir coilovers, with 700# Coils and CDC (Compression Damping Control) Clicker Valves. Dakar Leafs Old Man Emu Nitro Sport Shocks Toyotech U-Bolt flip kit, Goodyear F. & R. extended Stainless Steel Brake lines. aFe Pro Dry drop in air filter. ARB Bull Bar. Weld on AVID Off-Road Rock Sliders W/ Kick Out. Tires: 285/75 R16 BFGoodrich KO/TA's. Light Force Blitz 240's 12v. Warn M-8000 W/ Viking Off-Road Synthetic winch line.
    @jtweezy any updates, I have gone over every bolt in my front end. Nothing... I recently swapped to ICON's on 700# springs with ICON UCA thought maybe with this new set up my slight clunk would go away.
    I feel it more on the passenger side than the driver. It's only on a slight latteral shift as you mentioned. My lower ball joints are slightly leaking, could this be the problem..? Where is the stearing rack bushing...? The 2 big ones in front of the rack...?
