FOUND IT! Post lift clunking and knocking.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jtweezy, Dec 23, 2015.
  1. Feb 8, 2016 at 1:42 PM
    #161
    1rooster
    1rooster TACOMA31750
    Georgia
    2007 Tundra crewmax
    5100's ALL WAY AROUND, 885X COILS, DRIVER SIDE LEAN SPACER, ICON PROGRESSIVE AAL W/O OVERLOAD, 265/75/16 KENDA KLEVER M/T. 1 1/4 SPIDERTRAC WHEEL SPACERS, GEN 1 TRD COLD AIR INTAKE, STOCK MUFFLER WITH CHOPPED TURNDOWN, 5% TINT OVER FACTORY, DEBADGED, TOYOTA RUBBER BED MAT, WEATHERTECH MATS,UWS TOOLBOX, UNDERCOVER SE, LOCKER MOD, REAR BUMPER, PIONEER DOUBLE DIN WITH PARKING BREAK OVER RIDE, CUSTOM OIL CATCH CAN, FULL LED INTERIOR, ARB BUMPER REPLACEMENT. COVERKING SEAT COVERS. MORIMOTO H1 MINI COVERSION WITH MINI GATLIN GUN SHROUDS AND 5000K MORIMOTO BULBS. TRAILER PLUG RELOCTED TO BUMPER. 20 INCH LED LIGHTBAR MOUNTED BEHIND CUSTOM PAINTED GRILL. STUBBY ATNENNA
    X2
  2. Feb 8, 2016 at 1:43 PM
    #162
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Plus when my guys installed my complete lift we greased all the Zerks underneath.
  3. Feb 8, 2016 at 1:46 PM
    #163
    1rooster
    Georgia
    2007 Tundra crewmax
    When pulling out of work, all the guys make fun of me:pout:. Then call me a pos rice burner :anonymous:
  4. Feb 8, 2016 at 1:46 PM
    #164
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Why
  5. Feb 8, 2016 at 1:47 PM
    #165
    1rooster
    Georgia
    2007 Tundra crewmax
    Front end sounds like its about to fall apart!
  6. Feb 8, 2016 at 1:49 PM
    #166
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    You must have it real bad, mine is only slight
  7. Feb 8, 2016 at 1:53 PM
    #167
    1rooster
    Georgia
    2007 Tundra crewmax
    Well I know what my problem is, just got to find time to get it done. Iv got all the parts in my shop to replace. I'm hoping next week if it isn't cold as balls outside. I'm installing a new driver side lean spacer, new uca's, LCA bushings, lower bj's, and tie rod ends. If that don't work then I may just drive it off a cliff. :D
  8. Feb 8, 2016 at 3:46 PM
    #168
    jtweezy
    jtweezy [OP] Well-Known Member
    Austin
    2014 4X4 DCSB OR V6
    I don't think it's the slip yoke since (like @Unchained 5150 ) I can feel it under my feet. The slip yoke is back near the rear window. Plus, the only thing I did to the rear was the axle shims and CB drop. And I still had the clunk when those went in. Then after the front was removed/reinstalled the clunk disappeared for a while. No changes to the rear.
  9. Feb 8, 2016 at 5:26 PM
    #169
    MikeyMcFly
    MikeyMcFly This is heavy, Doc.
    I'm a Masshole
    2016 TRD Off-Road 6MT / 1999 Corvette 6MT
    Building a Broja
    UPDATE (for me at least).
    The driver's rear leaf front bolt (near the gas cap) was backing out to the point it was almost able to be turned by hand. I have NO clue how that occurred as I was meticulous with the torque wrench setting all the bolts. This solved my issue 100%.
    patbegley likes this.
  10. Feb 8, 2016 at 5:42 PM
    #170
    12TRDTacoma
    Rob
    Concordia
    Boosted
    OP. You may want to consider going over every bolt which ties to your suspension. Check the rear end first, the leaf spring retaining pins, then u bolts then the leaf spring fromt and rear eyelet mounts, after that for the front end, UCA/ LCA mounting bolts, spindle bolts to the actual control arms shock bolts. If that still doesn't remedy the issue check your crossmember by the T-case/ transmission for tightness. After that, spray some silicone spray or WD-40 on the bushings, one side at a time, one control arm at a time. If that still doesn't fix the issue, have the driveshaft checked, and or grease it yourself. You may also want to check your steering intermediate shaft to make sure it is doing ok. If it is stil there, you may have to just accept the fact that it will make noise. These Toyota suspensions are always kind of noisey for some reason and the noise issue dates back as far as th 95's and possibly even below.
  11. Feb 8, 2016 at 6:27 PM
    #171
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Thanks guys. I've gone over all the bolts mentioned, but not all at once. Maybe that's what I need to do. Go back to front in one sweep and get every bolt mentioned.
    I think it might be steering related because a while back I was parked in front of the house (in the street) and I turned the wheels (truck sitting completely still) and got this BAD clacking sound. It wasn't at full lock. Maybe one and a half full turns to the right, I'd go a quarter turn back and forth and "clack" every time I crossed "the point". Now I can't get it to do this again anywhere.
    Oh well, back to the drawing board. It has to be something because it's the same driveway, same motion every time. I just need to suck it up and find a GoPro or a brave soul to lie under the truck while I back up.
  12. Feb 8, 2016 at 7:12 PM
    #172
    1rooster
    Georgia
    2007 Tundra crewmax
    I made this ghetto metal bracket that connected to my skid and was able to lay my phone on it and try to catch my popping, but my phone fell off and nearly ran over the! I said screw it
    99TacoDriver likes this.
  13. Feb 10, 2016 at 4:09 PM
    #173
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    We need to find a small people person that we can hire to hang onto the undercarriage while we drive. Guaranteed solved in 5 min.
  14. Feb 11, 2016 at 11:39 AM
    #174
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Who is also not afraid to lose a few fingers grabbing onto moving parts.
  15. Feb 12, 2016 at 10:59 AM
    #175
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Tightened LCA bolt after my most recent alignment today. Then I tried just turning the wheels back and forth parked in the garage, got it to pop. Found that "spot" where crossing over left to right, right to left would cause the clunk. Put my phone under the front, tried again...silent. UGGGHHHHH!
  16. Feb 13, 2016 at 12:37 AM
    #176
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    I'm gonna check my body mounts more closely. I got the idea from another thread.
  17. Feb 13, 2016 at 4:36 AM
    #177
    1rooster
    Georgia
    2007 Tundra crewmax
    I feel your pain
  18. Feb 13, 2016 at 6:05 AM
    #178
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Gonna try to find someone in town with a GoPro I could borrow, or who wants to help me out finding the source of this. If not, there's a camera shop I go to that rents them for $50/day or $75/weekend. Hard to get motivated about paying to find this thing...
  19. Feb 13, 2016 at 8:50 AM
    #179
    jtweezy
    Austin
    2014 4X4 DCSB OR V6
    Ok, I may have found the source of the clunking. In this diagram it's labeled as the "Front Drive Inboard Joint Assembly". Basically, the inboard end of the driver's side CV axle (drive shaft).
    Here it is in context, if you don't already know where this is...
  20. Feb 13, 2016 at 8:54 AM
    #180
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    I get it on both sides so I don't know if that is what my clunking is. But glad you possibly found it.
