FOUND (rear bump stops)
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by TommyBoy51, Sep 10, 2023.
  1. Sep 10, 2023 at 5:57 PM
    TommyBoy51
    TommyBoy51 [OP] Well-Known Member
    Tom
    2022 Tacoma SR SX Access Cab Longbed 4x4
    Looking for both driver and passenger factory rear bump stops that sit on top of the rear leaf springs. Located in northern Ohio.
    I am putting on air bags, and i want to have a set to put back on if i ever take the airbags off. The airbags require to cut the rubber stops off.
    Thanks -Tom
  2. Sep 11, 2023 at 5:07 AM
    rolled93slc
    rolled93slc Well-Known Member
    Jerry
    Lynchburg VA
    16 Tacoma TRD Sport DCSB MGM
    I have a set you can have. Check DM.
  3. Sep 11, 2023 at 1:14 PM
    N minus 1
    N minus 1 Ruff Road Designs
    San Diego, CA
    2014 TRD Off Road
  4. Sep 11, 2023 at 1:17 PM
    TommyBoy51
    Tom
    I saw your post. I'm looking for the factory bump stops that sit on top/middle of the leaf springs.
  5. Sep 11, 2023 at 1:24 PM
    bkhlrTaco's
    bkhlrTaco's “expletive deleted”
    Brian
    Eau Claire, WI
    2016 OR AC MGM
    These are off my '16 OR AC. I could probably part w/ them if you haven't found any.20230910_202440.jpg 20230911_152102.jpg
    You mentioned driver and passenger. Are they supposed to be different?
    Other than 1 number being off on the stamp, they appear identical.
  6. Sep 11, 2023 at 1:51 PM
    TommyBoy51
    Tom
    Exactly what I'm looking for, but I have a lead on a set. If it falls through I will let you know. They should be the same/identical. Thanks
    bkhlrTaco's[QUOTED] likes this.
  7. Sep 18, 2023 at 6:09 PM
    TommyBoy51
    Tom
    Acquired. Please remove.
