Found the source of the noise, no idea how to fix it.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JCox, Jun 1, 2024.
  1. Jun 1, 2024 at 6:50 PM
    JCox
    JCox [OP] Well-Known Member
    Justin
    2021 Tacoma SR5
    Took this morning to spend some time locating a nasty “creek”
    The creek happens when it’s cooler, if I lift up on my steering wheel I can hear a slow “creek” it doesn’t matter which position the steering wheel is in and it isn’t the steering wheel itself. It is a bracket up behind the steering wheel that is mounted to the fire wall. The bolt feels tight but it creeks as if it is metal on metal. If it weee metal on metal why would it go away when it gets warmer? I’m perplexed - getting to it looks almost near impossible I don’t even know if I could take a picture. It’s pretty bad tbh, the sound.
    is their a diagram of some sort for me to be able to place direct location and how to remedy it? The bracket I think must also have an exterior location but I’m not sure if it’s accessible.
    edit also the sound happens when going over bumps as well, not just when I lift up on the steering wheel.
    Ty
  2. Jun 1, 2024 at 7:08 PM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    It probably goes away when warmer as the metal components expand and tightens things up. When colder, the opposite happens and your noise returns. At least that's my theory.:) Can you tighten anything up down there?
    Greg-tacoma likes this.
  3. Jun 1, 2024 at 7:15 PM
    JCox
    Justin
    2021 Tacoma SR5
    awe yes! Good point - :) well there is a nut down there on the bracket, but getting to it man.. I don’t even know it would take allot.. I’ll look into it tomorrow. Would love a diagram of some sort to be able to show which bracket it is
  4. Jun 1, 2024 at 7:18 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Could it be the steering U-Joint making noise?
  5. Jun 1, 2024 at 7:23 PM
    JCox
    Justin
    2021 Tacoma SR5
    nope :) the noise transfers up into the dashboard area.. near that bracket. Steering is flawless no sounds no nothing but if I put pressure on the steering wheel you can then begin to hear the slow creek. Like a metal to metal or tinny creek
    TA2016[QUOTED] likes this.
  6. Jun 1, 2024 at 7:36 PM
    JCox
    Justin
    2021 Tacoma SR5
    I looked it up. It’s in the instrument panel crossmember and it’s a metal brace that is attached the firewall right over the steering wheel.
  7. Jun 2, 2024 at 12:37 PM
    JCox
    Justin
    2021 Tacoma SR5
    If I removed the tweet/vent cover up by the dashboard does anyone know how much access I can gain to the top of the dashboard? Might be able to get to it from there if I remove the tweet speakers.
  8. Jun 2, 2024 at 12:51 PM
    JCox
    Justin
    2021 Tacoma SR5
    I’ll upload the sound later when I’m in better service.
  9. Jun 2, 2024 at 3:50 PM
    JCox
    Justin
    2021 Tacoma SR5
  10. Jun 2, 2024 at 4:38 PM
    T.BROCK
    T.BROCK Well-Known Member
    NorthEast Tennessee
    2022 Barcelona Red 4x4 Off Road
    Would WD40 help?
  11. Jun 2, 2024 at 4:40 PM
    JCox
    Justin
    2021 Tacoma SR5
    im thinking it’s higher up than I thought so I think my only option is to start taking stuff apart on the interior and really get a good look at what is rubbing. I hope so that or maybe a rubber washer and some lithium grease or something not sure
    wilcam47 likes this.
  12. Jun 2, 2024 at 6:30 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    If you removed the gauges would that give you access to the suspected area? If so, that is very easy to do. There are lots of threads detailing the removal of the gauges. Particularly for the installation of the speedometer calibrators.
  13. Jun 2, 2024 at 6:32 PM
    JCox
    Justin
    2021 Tacoma SR5
    im thinking maybe that would be the best thing to do! Is there enough slack in the wire to pull it out and set it aside enough to get my hand in there and feel around?
  14. Jun 2, 2024 at 6:35 PM
    JCox
    Justin
    2021 Tacoma SR5
    Also are there any air bags in there?
  15. Jun 2, 2024 at 6:38 PM
    Toycoma2021
    Once you get the two trim pieces removed, unplug the two connectors from the back of the gauge cluster and set the unit aside. There is a wire retaining clip on the back that is the only thing that is hard to remove. Once you get the cluster removed there is enough room to stick you head in there!!
  16. Jun 2, 2024 at 6:39 PM
    JCox
    Justin
    2021 Tacoma SR5
    I will absolutely be doing this this week! I’m confident I can fix this thing :) If I remove the wires will it mess anything up?
  17. Jun 2, 2024 at 6:40 PM
    Toycoma2021
    NO. The steering wheel airbag and the knee bag are the only ones in front of the driver. Side airbags aside.
    JCox[QUOTED][OP] likes this.
  18. Jun 2, 2024 at 6:42 PM
    Toycoma2021
    You are just disconnecting two electrical connectors.
    Many people will say to disconnect the battery before fooling around with anything electronic on these vehicles. I have not.
  19. Jun 2, 2024 at 6:42 PM
    JCox
    Justin
    2021 Tacoma SR5
    Thank you. Will report back after doing so.
  20. Jun 2, 2024 at 7:10 PM
    Dryvah
    Dryvah Well-Known Member
    MA
    2019 Tacoma TRD
    That sounds like the same noise I had.
    Remove the shroud under the wipers. You'll find a bolt behind a plastic grommet. Mine was loose. I put some blue locktite on it and tightened it up. No more noise!
    Greg-tacoma and JCox[QUOTED][OP] like this.
