found this little guy hanging on for dear life
Discussion in '1st Gen. Tacomas (1995-2004)' started by donlogan, Jul 18, 2017.
  1. Jul 21, 2017 at 11:10 PM
    daryl lict
    daryl lict Well-Known Member
    arizona
    $open diffs for life$
    You really should try and get that check engine light off. If it weren't importantg it would be a "maybe consider checking the engine light.
  2. Jul 22, 2017 at 9:00 AM
    donlogan
    donlogan [OP] Well-Known Member
    I used a hex die to get the bolt nice n clean. The nut goes down perfectly.
    Do I need to put a washer in there? I tried pulling up some pictures online but didn't find any that were clear.
    At this point I'm thinking about replacing the O2 sensor itself. It look very easy.
  3. Jul 22, 2017 at 11:10 AM
    ghs57
    ghs57 Well-Known Member
    Chops
    Catskill Mts. NY
    '17 Grey TRD OR xtracab 3.5L 4WD
    Pretty much stock right now
    There aren't any washers on the OEM setup, but their nuts have a flat bottom where they contact the sensor. The hard part about replacing the sensors is usually removing the old one. You have that beat. I would see if that one still works first. You'll know in about 100 miles if the MIL stays lit, and there are no other codes registering.
    donlogan[OP] likes this.
