Four 1500 mile road trips this year?
Discussion in '1st Gen. Tacomas (1995-2004)' started by ayemmus, Sep 21, 2022.
  1. Sep 21, 2022 at 8:49 AM
    ayemmus
    ayemmus [OP] Member
    Colorado
    So last month I drove from Colorado to Virginia for school. It's about a 1500 mile drive. I really would like to have my 2001 during our five week winter break so I can drive up to the mountains and ski while I'm back home in CO. My parents' cars aren't equipped or available for that. I also plan on working full time for that period so a vehicle would be very helpful. My question is, after driving here to Virginia from Colorado, with 260k miles on the odometer, can my taco take that drive home to Colorado and then back to Virginia in December? And then again, back home for the summer in May? Would it be wise as I would like this truck to get me through at least the next 3 years? Anyone have experience doing long distances multiple times a year? This is a very nuanced question so I'm just looking for opinions.
    The initial drive out here posed no serious issues. It idles in park a bit rough but that's the only thing I notice different after the drive. I have a 2001 Tacoma DC Auto V6.
  2. Sep 21, 2022 at 8:52 AM
    BigEasy
    BigEasy Well-Known Member
    Rob
    PNW
    2020 Tacoma TRD/OR DCLB
    Nada
    Very interesting question, with so many unknown variables to consider.
    My vote is have it checked out at a shop... YMMV
  3. Sep 21, 2022 at 9:00 AM
    Just_A_Guy
    Just_A_Guy Rain is a good thing
    On the hunt
    A truck
    Can it make the drive? Sure. Might get stranded in the middle of Kansas or something, but you can certainly get in the truck and start driving.
    At that kind of mileage, I would be weary about that kind of driving. You need to know your truck well to trust it on those kind of trips, especially in December in cold weather areas.
    With the amount you’d be spending on gas and hotels, consider a rental SUV for skiing and using your parents vehicle for work when possible.
    TACOTU3 and BigEasy like this.
  4. Sep 21, 2022 at 9:04 AM
    Smokestacks
    Smokestacks Well-Known Member
    BayArea
    1996 3.4L 4x4 Tacoma extra cab MT.
    Eaton Truetac limited slip Bilstein 5100s struts set at 2” 5100s shocks Torch add a leaf B&M short throw shifter Hella h4 headlights Warn front hitch Curt rear hitch Sony DSX-GS900 Deck Custic 1000watt amp Alumpro 10” sub Lund Steel Gullwing tool box Broadway rearview mirror Weather tech window deflectors
    Yes long distance driving is better on a vehicle then a bunch of short distance trips. It’s heating up and cooling down that puts the most wear on a vehicle. As long as you keep up with maintenance. Might actually be good for it. Drive safe.
  5. Sep 21, 2022 at 9:15 AM
    Nessal
    Nessal Well-Known Member
    Texas/Bay Area
    2003 V6 4X4 TRD DCAB
    We drove from CA to TX and back which was 1700 miles a few months ago and will do it a few more times this year and the next. I don't see any issues if your truck is up to shape. We had the bed loaded down and towing 1,100lbs to boot.
    TragicBronson likes this.
  6. Sep 21, 2022 at 9:17 AM
    Boco10
    Boco10 Well-Known Member
    ADK
    I am in the same boat at 322k and I travel to Colorado from NY. Invest in roadside assistance. My back up plan would be to rent a trailer and U-Haul it back home. Also invest in a decent set of basic tools and check that you can drop your spare. (If not throw a spare in the bed with some straps). Also having some extra oil. brake fluid. steering fluid and coolant. Small compressor. can of fix a flat and some plugs.
    BigEasy likes this.
  7. Sep 21, 2022 at 9:26 AM
    Boco10
    ADK
    My old 2001 idled rough when throttle body was dirty.
  8. Sep 21, 2022 at 4:57 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    The only issues I would have concerns would be heat soak issues that appear after 10 plus hours of steady driving.
    Make sure all the drive train vents are clear and working!
    Keep an eye on the trans fluid and engine oil you should be good to go.
    Fuel costs are the only thing keeping me from trips like that.
    Wulf likes this.
  9. Sep 22, 2022 at 6:32 AM
    old grouch
    old grouch Well-Known Member
    Stan
    Colorado Springs, CO
    95 4x4 V6 Extra Cab
    E-Locker SS Skid 2" Lift
    My wife & I do multiple trips of over 1000 miles every year to off-road destinations. As long as you keep up with the maintenance you should have no issues.
    Road_Warrior likes this.
  10. Sep 22, 2022 at 10:20 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    I've driven to Florida and back many times over the years (~1k each way, plus around the area) and make the journey in one shot (roughly 15.5-17 hours depending on roads/traffic) and never an issue. with the air moving over the radiator and other components heat soak was never a concern
    as others have stated, maintenance is key. also do you trust your own truck and driving ability. if not then you have your answer :notsure:
  11. Sep 22, 2022 at 2:42 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    I did about 5,000 this summer and about 4 last. Just keep up on maintenance as others have said
