"Four-wheel-drive usage frequency"
Discussion in 'Technical Chat' started by ChadVKealey, Mar 11, 2017.
  1. Mar 11, 2017 at 6:34 AM
    ChadVKealey
    ChadVKealey [OP] Well-Known Member
    Philadelphia, PA
    2017 Silver Sky Tacoma SR5
    None (yet)
    So I was reading the owner's manual for my '17 SR5 (V6, 4WD, DCSB) trying to learn about the "Auto LSD" indicator on the dash and found a section called "Four-wheel-drive usage frequency". According to that, the truck should be driven in 4WD mode for about 10 miles per month to keep things properly lubricated.
    How necessary is that, really? The reality is that my normal commute and driving is entirely on paved roads. Not that I *never* drive off-road, but it's not 10-miles-a-month-worth. If this is an important thing to the longevity of the drivetrain components, I'll try to find someplace close by to get 10-miles a month in. It'll probably take 20 miles of driving to find a place to do that around me (Eastern Montgomery County, just north of Philly).
  2. Mar 11, 2017 at 6:42 AM
    Hondah
    Hondah Revelations 6:8
    Newnan, Ga
    '13 RC 4x4
    Doesn't have to be off road for ten miles.
    Just ten miles in a straight line at less than 60 mph is better than nothing.
    And yes, its pretty important for longevity of the drive train.
  3. Mar 11, 2017 at 7:02 AM
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    Exactly what I was going to say. Just put it in 4wd while driving. As long as you're not doing tight turns on pavement you'll be fine.
  4. Mar 11, 2017 at 7:07 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    It says the same thing for the first gen trucks and second gen tundras.
    I have never done monthly 4WD engagement on any of my Toyota trucks. They have all worked normally and all easily go 300,000 miles.
    Dalandser, outlawtacoma and Blkvoodoo like this.
  5. Mar 11, 2017 at 7:21 AM
    Blkvoodoo
    Blkvoodoo a Hooka smoking caterpillar has given me the call
    Kevin
    Near Clayton NC
    08 PreRunner SR5 DCSB
    IF it does anything it warms up the t case and the front diff to evaporate any condensation that may have gotten into the cases. maybe works the seals to try and keep them plyible.
    I've had numerous Toyota trucks and rarely ever did engage if i wasn't using 4wd for a purpose, never had issues.
    had more issues with rusted parking brake bell cranks that WERE used often and then seized
  6. Mar 11, 2017 at 7:41 AM
    Clearwater Bill
    Billy
    Largo Florida
    Proud of you for reading the owners manual!
    That puts you ahead of many of your fellow new Tacoma owners.
    Kev O, su.b.rat, Dalandser and 5 others like this.
  7. Mar 11, 2017 at 7:44 AM
    Blkvoodoo
    Kevin
    Near Clayton NC
    RTFM should be a requirement of ownership, it would help prevent a lot of stupid
    Clearwater Bill likes this.
  8. Mar 11, 2017 at 11:19 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Where those actuator-aided trucks? I've been reading up on the actuators failing from not engaging 4by every-so-often..
  9. Mar 11, 2017 at 12:39 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Some people just have good luck except for 30A`s
    I try and put my ADD system in gear about once a month and 4low for a few laps around my driveway
    I would rather find a problem before it made it an emergency
  10. Mar 11, 2017 at 1:51 PM
    ChadVKealey
    Philadelphia, PA
    None (yet)
    I was mainly trying to figure out where and when the LSD automatically came out ("Auto LSD").
    But seriously, I take one or two trips a month on the PA turnpike (mostly straight line, 15-20 miles), so on one of these, I should just engage 4-high, then disengage before I get off the TP?
  11. Mar 11, 2017 at 1:57 PM
    Brian007Taco
    Brian007Taco 007Taco
    If you ask. You don't know me very well!
    Mesa, AZ to NM to OK to UT back to Mesa
    2012 Red TRD OR 4x4 DCSB (aka Clifford the Big Red Truck)
    12 OR DCSB 4x4 265/75/16 Goodyear Ultra Terrain wrapped on MB352's. OME 886's w/5100's front and back, and Dakars. Derped Emblems. KM Fab sliders, Mobtown Front and back bumpers w/tire gate, KM Fab Bed Rack, Bestop Supertop, Matt Gecko bed lights. Tree Smashed Taco 06 OR AC Prerunner! OME 885 with 5100's in front, TSB and AAL with 5125's in back. 30" light bar in the valance.
    Taken from a tread just like this! @Benson X is a genius when it comes to knowing how and when to use the 4x4 part of the truck.
  12. Mar 13, 2017 at 8:12 PM
    Beerline123
    Beerline123 Well-Known Member
    07 Tacoma access 4x4
    Welcome Chad, I live in phila and travel turnpike also but that road is to high a speed limit of 70 mph. I turn my 4 wheel drive on smaller straight roads where max speed is 45 to 50. Also it doesn't have to be a 10 mile straight run I turn 4 wheel on and off as road conditions change in regards to turns. Just find straight runs and keep speed under 50. Good luck
  13. Mar 13, 2017 at 8:16 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    There is no need to limit speeds in 4hi. You dont have to drive in a straight line, just avoid making tight turns such as pulling in a parking space.
  14. Mar 14, 2017 at 6:47 AM
    Beerline123
    Thanks for info. Wasn't sure on speed so wanted op to be conservative. On dry pavement I tend to be very cautious because of some articles I've read about talking about the stresses that occur in the driveline if not going straight. I'll do so more reading about that. Thanks for inputting always trying to learn.
  15. Mar 14, 2017 at 7:02 AM
    tgear.shead
    tgear.shead Well-Known Member
    There is absolutely no reason or benefit to it. In fact, the 4wd parts are ALL moving during normal driving -- not a positive lock, but rather dragged along by the motion of oil and inertia of other parts, so they ARE being lubricated.
    Kiloyard likes this.
  16. Mar 16, 2017 at 9:16 PM
    o0oSHADOWo0o
    o0oSHADOWo0o Just lurking in the darkness
    Shadow
    Va Beach
    2012 Double Cab Short Bed 4x4 TRD Sport
    Just a few LEDs...
    Never drive off road? No Problem.
    Just go down to your favorite service center, have the techs there put your truck up on a lift. All four wheels are now in the air so you are technically "Off Road" so start it up and engage 4WD. :rofl:
    Brian007Taco likes this.
  17. Jul 14, 2017 at 9:45 PM
    TRVLR500
    TRVLR500 Well-Known Member
    Wyoming
    Tacoma SR5 4X4 2.7 4CYL
    I have a 2004 4X4 RC. I bought it from my dad because he hurt his back and couldn't drive a stick anymore. When I first got it since it had been sitting and the 4WD hadn't been used in about a year it wouldn't go into 4WD or come out of it right away.
    Since I bought it I usually run about 20 or 30 miles a month in 4WD. At least. It's easy for me since I have numerous roads going where I want to go anyway to another city nearby where I do some shopping. I have a unique situation where the majority of people in this country don't because I live out west and dirt roads are 3 minutes away leading in every direction.
    However, these dirt roads are pretty much impassible in the winter but it makes no difference because the interstate turns into an icy, slushy "dirt-road" with regularity during the winter so I use my 4WD regularly on paved roads in the winter due to mainly ice and the once in a while 2 feet of unplowed snow on the interstate.
    My point being? Use the 4X4 every chance you get and it will work far better. Even when I don't want to I engage 4WD as much as I can. Even if I have to use a perfectly straight stretch of pavement or a paved road with very gentle turns. As others have mentioned. Turning on pavement with 4WD engaged is a real bad idea but if the road is straight it's fine. It's best to keep the speed low though even in 4HI. I don't go above 55mph although I have run at 65.
  18. Jul 15, 2017 at 2:28 PM
    TOMB
    TOMB Well-Known Member
    Tom
    Newington Ct. 06111
    2013 Access cab Sport -super white
    Changed all drain plugs to Dimple Magnetic plugs UNI filter on air pump
    I engage my 4 wheel drive every time it rains so it gets cycled pretty much on a qusi regular basis . At the same interval I also engage 4lo also so it gets cycled .
    TOMB
  19. Jul 15, 2017 at 2:30 PM
    koditten
    Kirk
    Central Michigan
    I call bull shit.
    Engaging 4 low requite a speeds less than 10 mph. You won't be doing that on the interstate on the way home from work.
  20. Jul 15, 2017 at 2:32 PM
    su.b.rat
    su.b.rat broken truck
    I also engage when it rains and i have a straight road. in DFW i use every chance, just not to stress the truck I'll turn it off if not on a straight road. i use the crap out of it, just not in DFW obviously.
